Transponder Question
Old December 2nd 03, 06:49 PM
log
Default Transponder Question
On a recent trip, ATC said my transponder was now showing my altitude. Is it
the altimeter or the transponder or the encoder?
BED
Old December 2nd 03, 07:06 PM
Steve Beaver
Typically either an encoding altimeter or a "blind" encoder provides
altitude info to the transponder. The encoding altimeter is by far the best
method but expensive hence most light aircraft use the encoder. Problems
with encoders are very common.
Encoders usually have a heater in them which keeps the pressure sensor at a
near constant temperature and in most cases, disables the altitude signal
until that temperature is reached. On a really cold day, this may take a
long time. If ATC report no mode C immediately after takeoff, you may just
need to wait for a while.
As an aside, in 30 years of flying "in the system", I have never once
observed a "recycle transponder" to be effective. I have have formed the
impression it is contoller-speak for "Turn it on, dummy!"
Steve
"log" wrote in message
it
BED
Old December 2nd 03, 07:08 PM
Orval Fairbairn
BED
It could be:
1.The transponder is scrambling the Mode C info from the encoder.
2. The encoder id malfunctioning.
3. The wiring harness from the encoder to TXP has a bad soldeer
connection. I take it the problem is intermittent?
4. You were in an area of marginal radar coverage and flew into an area
of better coverage.
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 09:03 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Someone gave me a Transponder ....... Ron Natalie Home Built 4 September 19th 03 02:10 AM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 04:20 AM
transponder check? Russell Duffy Home Built 10 August 15th 03 12:36 AM
