Just a warning for those who might consider purchasing Rapco dry vacuum
pumps. Make sure that your engine does not leak oil. If there is any chance of an oil drip onto the Rapco vacuum pump it may eventually stop working. The connecting shaft is vented to air. But if some oil drops on the shaft it may get sucked into the pump and after the oil dries it may seize the pump. I puchased a 216CW new pump from Spruce and after 20 hours of use it does not work. After returning it to Rapco they said it was "oil contamination" and not eligible for warranty service, but offered to replace it at a discount. They really ought to have a better seal there to prevent the problem. |
If you were really smart you would have ditched your pump and installed
the Aeon pump instead. More expensive than the normal dry pump but the next best thing to a wet pump. abripl wrote: Just a warning for those who might consider purchasing Rapco dry vacuum pumps. Make sure that your engine does not leak oil. If there is any chance of an oil drip onto the Rapco vacuum pump it may eventually stop working. The connecting shaft is vented to air. But if some oil drops on the shaft it may get sucked into the pump and after the oil dries it may seize the pump. I puchased a 216CW new pump from Spruce and after 20 hours of use it does not work. After returning it to Rapco they said it was "oil contamination" and not eligible for warranty service, but offered to replace it at a discount. They really ought to have a better seal there to prevent the problem. |
...you would have ... installed the Aeon pump instead
Actually I removed the vac pump and went to all electric - saved some weight. But I do think that Rapco or any mfg should prevent something like that with a seal. Did you check the Aen pump for oil drip problems? Do they warranty against oil entry? |
Rapco can't put any serious seal on that pump that would last any
time because it's a dry pump, and seals need some lube. Rapco does have a pump to fit the under-nose mountings like the O-200, where oil tends to get into the pump, and that pump has a flinger and a drain port to keep oil out. Washing the engine with solvent can also wreck the pump. It needs to be covered during spraydown. We use Rapco pumps exclusively on five airplanes, and have no trouble at all reaching 1000 hours. Basically, your oil leak need fixing. Oil leaks represent an attraction for dirt, which does no engine any good, and they're a fire hazard. And some oil leaks are warnings to fix something before it blows off completely and all the oil is lost overboard in flight. Dan |
Rapco can't put any serious "seal" on that pump...
... [They have a]... pump has a "flinger and a drain port" to keep oil out... I don't care what its called - it should be on there. Is the manufacturing cost of such feature so significant? I don't recall any warnings that came with my new Rapco pump about simple oil drip hazards or about a special pump model required. I only found out when warranty service was denied. ...Basically, your oil leak need fixing..... No kidding. But while you are trying to fix it or if you are unaware of oil leaks you take a flight risk with the pump. Engines can START leaking and ruin these "sensitive" pumps. A lot of homebuilders, like me, have initial leaks until they are found and fixed - its not a lack of trying. This post is a warning to others about the risk they may take with such pumps - unless they are 100% sure their engine does not leak and never will leak. Even if they find/fix the leak quickly they will not know if the pump is OK, since the pump tends to work for a while after oil gets in there. |
![]() "abripl" wrote in message oups.com... Rapco can't put any serious "seal" on that pump... ... [They have a]... pump has a "flinger and a drain port" to keep oil out... I don't care what its called - it should be on there. Is the manufacturing cost of such feature so significant? I don't recall any warnings that came with my new Rapco pump about simple oil drip hazards or about a special pump model required. I only found out when warranty service was denied. ...Basically, your oil leak need fixing..... No kidding. But while you are trying to fix it or if you are unaware of oil leaks you take a flight risk with the pump. Engines can START leaking and ruin these "sensitive" pumps. A lot of homebuilders, like me, have initial leaks until they are found and fixed - its not a lack of trying. This post is a warning to others about the risk they may take with such pumps - unless they are 100% sure their engine does not leak and never will leak. Even if they find/fix the leak quickly they will not know if the pump is OK, since the pump tends to work for a while after oil gets in there. Any good mechanic can find an oil leak its not that hard. |
I agree with you. I am in the vacuum pump business, and I don't
understand why they can't make the pump a little more reliable. I can't change the pump design myself, because it is certified the way it is. It would be to costly to redesign it. If you need any vacuum pump assistance, you can call me at 800-621-2531. Good luck to you. Ron |
![]() rons321 wrote: I agree with you. I am in the vacuum pump business, and I don't understand why they can't make the pump a little more reliable. I can't change the pump design myself, because it is certified the way it is. It would be to costly to redesign it. If you need any vacuum pump assistance, you can call me at 800-621-2531. Good luck to you. Ron I would bet that any seal material or design that might work, if it exists, would be so expensive that the pump price would rise just enough that it would lose its competitive place in the market. Or if there WAS a suitable seal, someone would have incorporated it by now and marketed their pump as a superior, new and improved, longer lasting oil- and solvent-proof design. Rapco HAS made small changes to their pumps, things that weren't part of the original certification, such as cooling fins, the inclusion of a small amount of salt in the vanes to absorb a small amount of moisture and increase the vane life (low humidity increases vane wear), and the flinger/oil drain idea for the Continental vertical mount. Such changes lead me to believe that the ideal shaft seal isn't available or affordable. Dan |
What I have learned from these posts is that dry vacuum pumps are a lot
more problematic than just the oil leak - as per http://www.casa.gov.au/airworth/aac/PART-1/1-098.HTM link. Its too bad that there is not more warnings before purchase instead of "wonderful" features. The one hard to find link is hardly a help for a homebuilder. I have perused these newsgroups frequently during building process and there is hardly anything mentioned about inherent dry vacuum pump problems. EAA has homebuilder vacuum systems help article http://members.eaa.org/home/homebuilders/building/instruments/A%20Gyro%20Instrument%20System_%20(Your%20Options) .html#TopOfPage with no operational warnings mentioned as in first article. I suspect, Dan, that you are not a builder but either a certified plane pilot or A&P making a living from repairs. I have eventually replaced the vacuum system with electric for about the same price and saved weight and expect a lot less problems. |
I suspect,
Dan, that you are not a builder but either a certified plane pilot or A&P making a living from repairs. Close, but not quite: -Canadian Aircraft Maintenance Engineer (AME) M1 -Commercial Pilot, Instructor rating -Homebuilder: building or restoration projects have included Taylor Monoplane, AMF-S14, Jodel D-11. Auster VI restoration project. -Since 1972 in homebuilts, flying since '73 I currently spend most of my time in the shop maintaining aircraft, but make no extra money from doing more work. I work in a College-based flight training program and teach a class on Aircraft Systems; between the maintenance and the teaching I have plenty of reason for research into aircraft problems. When I'm not doing that I'm flying, either to figure out some problem, or with a student, which isn't too often anymore, or in the Jodel. What's your experience? Dan |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
Dual vacuum pumps bad news | Javier Henderson | Owning | 3 | May 7th 04 09:06 PM |
Low vacuum at idle | Chad Lemmen | Owning | 1 | August 18th 03 09:24 PM |
