It actually happened today!! Vacuum failure in IMC.
Old October 7th 05, 07:46 PM
Robert M. Gary
What was the reason for the 7700? Were you in controlled airspace?
Didn't ATC already have a positive ID on you before you changed the
transponder code?
-Robert, CFI
Old October 8th 05, 02:02 AM
skym
It is my understanding that 7700 is what we are supposed to dial into
the xpdr when we declare an emergency. I was in controlled airspace.
Does that make a difference?
Old October 8th 05, 02:47 AM
Mark Hansen
You only need to do that if you need to get someone's attention.
If you're in radio communications already, all you need to do is
declare it. There is no *requirement* to change your xponder code.
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old October 8th 05, 04:57 AM
Newps
If you're already talking to ATC just tell the controllr what the
problem is, no need to change the transponder. Doesn't matter what
airspace you are in.
Old October 8th 05, 11:41 PM
skym
Thanks to both. Didn't know that. Hope I don't ever need it again!!
Old October 10th 05, 02:12 AM
You did nothing wrong by squawking 7700. Better to error on the
conservative side, and that is what you did.
Also, the 7700 squawk really wakes up the system to work in your behalf.
Old October 10th 05, 09:04 AM
David Cartwright
"skym" wrote in message
Yes - it lights you up distinctly (a different colour, I believe) on the
radar screen. So although the controller would see you no matter what code
you were transmitting, if you switch to an emergency code (7700, 7600, 7500,
etc) the equipment makes you more prominent and so lightens his workload a
little.
D.
Old October 10th 05, 02:52 PM
Newps
little.
That's funny. Completely wrong, but funny.
Old October 7th 05, 07:54 PM
Scott Moore
skym wrote On 10/06/05 17:26,:
3. An STEC A/P which runs on the TC, rather than the vacuum
instruments, is the way to go.
I agree, the STEC even has a separate altimeter (actually a
differential pressure transducer) with its on dual air inlet
placed midsection.
One question: was the A/P engaged during the AI fail ? Do you
think that would have made a big difference in keeping the
aircraft under control ?
If it wasn't engaged, did you engage it immediately ? Did you
wait to get the aircraft under control with the T&B before
engaging it ?
Thank you, and congatulations on your sucessful handling of
the situation.
My first in-flight mechanical failure Peter R. Piloting 52 October 5th 04 09:05 PM
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
