#21
Teacherjh,
AIM is not gospel, and although it represents distilled (good) judgement, it should not =replace= judgement. Of course not. But there was no judgement in your post. -- Thomas Borchert (EDDH) |
No, I only squawk on the ground. That way no one knows where I am ;-).
Guess it is old age catching up with me, huh? "Steven P. McNicoll" wrote: "Ray Andraka" wrote in message ... I put mine in the alt position after clearing the runway. That way, next time I turn on the avionics I'm not squawking an IFR code that might be in use. I assume you meant to write "stby" in place of "alt". -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Sure there was. I made the judgement that it was better for me to briefly not reply to a ping than to reply inappropriately as I was switching numbers. Jose -- (for Email, make the obvious changes in my address) |
Ray Andraka wrote: I put mine in the alt position after clearing the runway. That way, next time I turn on the avionics I'm not squawking an IFR code that might be in use. Doesn't matter as the software in the radar is calibrated so as not to display a code on the airport. We have ours set so no transponder returns show until you get more than 1/2 mile away from the antenna, otherwise the airport would be a clogged mess of returns. And you're not worried about a code that is in use but one that is not yet in use. |
Teacherjh wrote: But there was no judgement in your post. Sure there was. I made the judgement that it was better for me to briefly not reply to a ping than to reply inappropriately as I was switching numbers. It takes at least two sweeps and sometimes as many as 5 sweeps before the radar will tag you up on a code you're squawking. |
Newps writes:
It takes at least two sweeps and sometimes as many as 5 sweeps before the radar will tag you up on a code you're squawking. Is that true of all radar equipment? I've sometimes been assigned a new squawk code then heard "radar contact" within a couple of seconds (usually, though, it's more like 20-30 seconds, which would agree with what Newps writes). All the best, David |
Dark lonely night and you are the only airplane in the airspace
squawking VFR. You call up for service I'll give you a code and radar contact in the same breath. David Megginson wrote: Newps writes: It takes at least two sweeps and sometimes as many as 5 sweeps before the radar will tag you up on a code you're squawking. Is that true of all radar equipment? I've sometimes been assigned a new squawk code then heard "radar contact" within a couple of seconds (usually, though, it's more like 20-30 seconds, which would agree with what Newps writes). All the best, David |
"Thomas Borchert" wrote in message ... Ken, leave it on while switching. The AIM says so. This is a really silly argument. Does the AIM say when you can pick your nose or scratch your ass? Guess you better not then! What the heck are you guys getting all worked up about? It's people who rely on a book to do all their thinking that scare me....no ability to use common sense in an emergency, they'll be sitting there thumbing through the AIM or the FARs wondering what to do..... Its too bad there's not a way to test for the ability to differentiate between what is important and what is not. Wow.... -- Thomas Borchert (EDDH) |
#29
"unknown" wrote:
Its too bad there's not a way to test for the ability to differentiate between what is important and what is not. Wow.... There is. Look at the age on death certificates. |
#30
"Mike Beede" wrote in message
... The only time it really makes a difference is if you accidentally switch it to the 7500+ neighborhood. A good rule of thumb is to roll in the first number (which at least in the Minneapolis area is never 7) and then do the rest. Do people get 7xxx codes elsewhere in the United States? FWIW, in most of the rest of the world the conspicuity code ("VFR", in effect) is 7000 rather than 1200. There's rather more room for error of the sort you're thinking of. Moreover, when the question is asked on forums in Europe, controllers suggest that *any* random code can cause problems because if you happen upon one that has been assigned to IFR traffic, the radar system picks up the squawk and labels you as that airways flight, which is time-consuming for ATC to fix. Is there no similar issue in the US because of different ATC systems? The issue is less about momentary selection as you pass through the digits and more about cockpit distraction meaning that the wrong code gets left on for a while. Julian Scarfe |
| Thread Tools | |
| Display Modes | |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| FS: Narco AT-50A Transponder with ACK Encoder | JR | Home Built | 0 | April 29th 04 12:33 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| For Jim Weir: Transponder Installation | Ron Wanttaja | Home Built | 11 | February 3rd 04 04:26 PM |
| transponder check? | Russell Duffy | Home Built | 10 | August 15th 03 12:36 AM |
