#21
Don,
NONE of those aircraft or helos you mentioned are TRANSITIONAL craft. The V-22 has a lousy test record that the Marines falsified heavily to pass the a/c through and it IS a deathtrap in just "being" a transitional craft. Transitioning is like being a sitting duck ASKING to be hit in a highly vunerable moment, far worse than a helo set-down. I'm not the only person who has voiced this and want the V-22 cancelled. As for advancements in aviation, this is nothing new. The Germans had TWO transitional a/c designs during WW2 (from Focke-Achgelis and Weserflug). Neither were built. The Germans DID, however, have the Me-321 and 323 Gigant transports- the C-5s of the day able to lift artillery, tanks, and 100 men and it flew... but no one wanted to be inside the lumbering monster that was easy prey for Spits in the Med, despite 10 MG defense! There are a lot of special forces and other soldiers that don't want to climb into the V-22 for the same reasons- the a/c is a deathtrap. BTW, FYI, many believe that the XF-23 was better than the XF-22 but that the USAF is biased towards Lockheed products- same as Heinkel vs Messerschmitt. Now its Northrop vs Lockheed Martin- Whatever! I'm for axing both these aircraft but the am in favor of the F-35 and a reasonable new air superiority fighter- not some mess that costs the taxpayer almost $175 million per copy when a new Su-47 and the Euro-craft cost around $75-80 mil each. Hell, you COULD buy Flankers for around $50-60 mil each! And the F/A-22 performance claims are just that-company and USAF claims. They should have just continued work on the F-16XL and further F-15 development. The F/A-22 isn't justified at all. It went from F-22 to F/A-22 to naval F/A-22 and now a proposed F/B-22!!! Gimme a ****ing break... that turkey isn't selling. Axe it!!! Rob |
Rob Arndt wrote:
Don, NONE of those aircraft or helos you mentioned are TRANSITIONAL craft. The V-22 has a lousy test record that the Marines falsified heavily to pass the a/c through and it IS a deathtrap in just "being" a transitional craft. Transitioning is like being a sitting duck ASKING to be hit in a highly vunerable moment, far worse than a helo set-down. I'm not the only person who has voiced this and want the V-22 cancelled. As for advancements in aviation, this is nothing new. The Germans had TWO transitional a/c designs during WW2 (from Focke-Achgelis and Weserflug). Neither were built. The Germans DID, however, have the Me-321 and 323 Gigant transports- the C-5s of the day able to lift artillery, tanks, and 100 men and it flew... but no one wanted to be inside the lumbering monster that was easy prey for Spits in the Med, despite 10 MG defense! There are a lot of special forces and other soldiers that don't want to climb into the V-22 for the same reasons- the a/c is a deathtrap. BTW, FYI, many believe that the XF-23 was better than the XF-22 but that the USAF is biased towards Lockheed products- same as Heinkel vs Messerschmitt. Now its Northrop vs Lockheed Martin- Whatever! I'm for axing both these aircraft but the am in favor of the F-35 and a reasonable new air superiority fighter- not some mess that costs the taxpayer almost $175 million per copy when a new Su-47 and the Euro-craft cost around $75-80 mil each. Hell, you COULD buy Flankers for around $50-60 mil each! And the F/A-22 performance claims are just that-company and USAF claims. They should have just continued work on the F-16XL and further F-15 development. The F/A-22 isn't justified at all. It went from F-22 to F/A-22 to naval F/A-22 and now a proposed F/B-22!!! Gimme a ****ing break... that turkey isn't selling. Axe it!!! Rob My point is your opinions on tactics, strategy, individual equipment, weapons, weapons systems, utility of aircraft etc as posted here over the years have been way off base and are about as realistic as your claim Germany defeated a U.S. expeditionary force in Antarctica after the war. Something about a secret Nazi underground U-boat base in Antarctica. Dan, U.S. Air Force, retired |
Steve Hix wrote:
In article .com, wrote: Bob Moore wrote: Reed Judd-Dyer wrote How does more blades equal less efficiency? Those of us that flew rubber band powered contest model aircraft way back ('40s-'50s) KNOW that the most efficient propellor has only ONE blade...and a counterweight on the other side. :-) Bob Moore A Helo with one blade would have to be the most uncomfortable ride, until after a minute or so, when it had shook itself to pieces. quite a bit less than a minute... The single-blade prop with counterweight actually worked pretty well in testing. AND if you look at the model planes that are used in the International U control speed contests, each has only one wing with fuel inside, powered by an engine with prop of one blade and counterweight, faster it goes more Cf on fuel in wing to input to engine, which has funnel type air inlet to carb. Really screams, and speeds of over 230 klm hour running in a 33meter radius circle about a heavy pivot in the center. Year I saw it at Westover, Mass the Aussie team won it by a healthy margin.. more than 3% faster than old record.. |
Rather than follow the advice of Henry Jones Sr., Dan couldn't just let
news:qbTWf.2383$IG.2210@dukeread01 on 30 Mar 2006 go. Rob Arndt wrote: Best configuration for the V-22, you ask? In combat, a heap of burning wreckage or in peace time... a cancelled project piece of scrap metal. Transitional a/c are inherently dangerous no matter what, and if the primitive Iraqis can down an Apache how much more vunerable is the tilt-rotor Osprey... or rather "Easy Prey"? Imagine an Osprey loaded with troops as it transitions to take off or land in Iraq. One RPG or heavy MG fire to the rotor system and the US will be scraping the remains of its troops out of the dirt and sand with shovels. Why doesn't someone cancel this flying cemetery already? Like the F/A-22 seems the number "22" in US inventory= disaster. The Craptor and Easy Prey need the axe. Cancelling the Craptor will save money while cancelling Easy Prey will save lives. Rob This is from the fool who thinks Japan needs ICBMs, nuclear powered aircraft carriers and nuclear powered submarines to protect itself from China and North Korea. Then again he also believes a 34 pound weapon is an excellent E&E choice for downed air crews, the Earth is hollow, there's a secret still operational Nazi underground U-boat base in Antarctica.....etc. Delurking.....and this has to be one I do it with....sheesh. I usually just read because the activity in this group seems more oriented to air crew than ground crew. My history - 9 years USMC - former Sergeant of Marines - OV-10D/D+ FLIR tech - also A-6E IR portion of the TRAM and a squidge of F/A-18 IRDS. While there are some rather foolish criticisms regarding aircraft selection and policy, there are some sound ones as well. When the V-22 program first started going through initial trials, there were some legitimate, negative reactions to its catastrophic lack of air worthiness. Additionally, I read several pieces about how the Marine Corps didn't really want/need the V-22 early on. The general line of reasoning was that the Corps could break out the old patterns and build 5 to 10 CH-46 helicopters for the price of one V-22. The V-22 also compared poorly when it came to maintenance hours per flight hour. Yet the V-22 program was impossible to kill because the manufacturer(s) had carefully placed enough work in as many congressional districts as possible. Thus it was impossible to vote against the V-22 without voting against jobs for the folks at home. Of course we are now much further down the road and the money already spent makes it harder to kill a program that fails to perform as advertised. I'm sure the Corps has bought into the program if for no other reason than swallowing is an easier process than regurgitation. IMO, the Osprey was deployed well before prudence should dictate. The program doesn't have a few bugs to figure out (something every program has). It has one large bug in the primary mechanism that is supposed to give the Osprey unique capabilities. -- Regards, Dann Blogging at: http://www.modempool.com/nucleardann/blogspace/blog.htm A big enough hammer can usually fix anything. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Ivo Prop Blades - question | Dave S | Home Built | 6 | August 26th 05 04:20 AM |
Sport Prop blades needed | Ron | Aviation Marketplace | 0 | February 19th 04 11:12 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
