Water in our oil, or just alot of hot air?
Old April 23rd 06, 06:56 AM posted to rec.aviation.owning
Default Water in our oil, or just alot of hot air?
Water evaporates very well
even at sub-freezing temperatures
Sublimates that is.....
Rusty
Old April 23rd 06, 04:25 PM posted to rec.aviation.owning
Dave Stadt wrote:
Dave Stadt wrote:
"mikem" wrote in message
Dave Stadt wrote:
12 years, 235K miles and still the original exhaust system.
But I bet you drive it at least 3 mi each time you start it.
That's true most of the time but it still doubles your estimate for
muffler
life.
How about the moisture in auto engines without crankcases vented to the
outside world? How does it get out? Once it floats upward and bursts
free,
as you say, where does it go? Don't hear about auto engines with
corrosion
problems even collector cars that are only driven a couple of times a
year.
All crankcases are vented somewhere.
Usually to the intake manifold through the PCV valve in modern cars.
Which is a closed loop. So how does the moisture escape?
Are you serious?
The intake manifold goes to the combustion chambers which goes to the
exhaust manifold which goes to the exhaust pipe.
Jim Pennino
Remove .spam.sux to reply.
Old April 24th 06, 02:55 AM posted to rec.aviation.owning
Drew Dalgleish wrote:
Running an engine on the ground is bad. It's boring and wastes gas
just go do some circuits to get the oil warm.
What proof is there that it is bad? And sometimes weather and
circumstances don't allow people to fly. I believe that ground running
is better than bare metal corroding. My engine would have been corroded
a long time ago if the oil from a ground run would do that, and it
hasn't been.
Blue skies,
Rusty
One of the things we (at an auto company) have to do is make sure that cars
cold start well. And, nowadays, we even have to meet emission regulations at
lower temperatures. Now, the problem is that it's hard to get a lot of cold
starts into a short period of time. So, what to do? One technique is to use
cold fluids (water, oil, even air) to force cool an engine and get multiple
cold starts per day. When some dynomometers were set up to do cold start
after cold start, we started to grenade the engines in short order - largely
due to oil dilution from gasoline - you get some in the crank case with
every start and if you don't warm up, it builds up. Moisture from blowby
builds up too. Repeated short starts are, in general, not a good thing. What
you propose isn't nearly as severe, but short, repeated runs are not likely
to get you to the maximum TBO.
There's nothing magic about 180 degrees - but the warmer it is, the higher
the vapor pressure from the water, and the more it dries out. Aircraft
engines are at a bit of a disadvantage since they still just use a breather
tube so the only "air" going into the crankcase is from the blowby which is
loaded with water and CO2 (all engines have blowby - it's just a question of
how much). The positive flow from the PCV system on cars has been shown to
increase the longevity of the engines, but just sticking one on an aircraft
engine won't have the same benifit since aircraft run at high manifold
pressures (little or no vacuum) for extended times so you wouldn't get much
flow from a PCV so all you can do is warm it up enough and run it long
enough for things to dry out.
Oil needs to be changed because the long chain hydrocarbons break down and
viscosity changes. Also, there are a lot of additives for friction and wear
reduction, foam supression, etc. that tend to break down. Carbon particles
are not a problem for gasoline engines since there is almost no soot
generated. Diesel's on the other hand, make lots of soot, and some of it
makes it's way into the oil.
If you really want to circulate some oil, crank without starting . If you
want to run it, run it long enough to warm up. Short runs aren't an instant
disaster, but they really aren't what you want to do for a long TBO.
But, it's your engine...
Geoff
Old April 24th 06, 03:05 AM posted to rec.aviation.owning
One reason for not running a car or airplane for short periods is that you
have initial startup wear. Most of the wear in cars, and perhaps airplanes
too, happens at startup, when there is zero oil pressure, minimal oil on the
surfaces, and the presence off some condensed moisture. If you could only
run an engine on the ground for 5 minutes at a time, you would definitely
not want to run it once a day. On the other hand running it like this 4
times a year would probably increase the life by making sure there is some
oil on the interior surfaces. I don't know of any data that will tell us
where the sweat spot is that causes the least wear. One point of evidence we
do have is that engines that are not run for extended times do corrode in
tell tale ways. You never want to buy a plane that has sat for extended
periods.
I just watched a program about the huge Oresund bridge between Denmark
and Sweden, and there was a segment about how the corrosion problem for
the bridge was dealt with. Instead of painting, they use sealed
compartments that have the air humidity kept below 60%. This they said
eliminates corrosion. This started me thinking about the corrosion we
aircraft owners are told to guard against, since I have personally been
told by an overhaul shop, that half of all the engines he sees that
need work, need it because of corrosion. There are several "facts" that
I am beginning to question as to their validity. The ones that come to
mind a
1) You have to get the oil up to 180 deg F or the water in the oil
won't evaporate.
2) Starting and ground running the engine for a minute or so is the
"worst" thing you can possibly do.
3) Flying for an hour will "clean" the oil (or at least evaporate the
water, preventing acid formation) so that it doesn't turn to acid and
dissolve the engine while sitting idle.
There are probably some others, but these three stand out the most
to me. Now I am sure that what I am about to say will not go over well
with some people, but I have the asbestos suit ready and waiting.
My take is that these three "facts" are a bunch of poppycock. Why
or how they got started is anyone's guess, but the reasoning behind
some of them is understandable, for others I wonder what they were
smoking at the time. My thoughts are along these lines, and I admit I
could be wrong, but I don't think so.
Concerning fact #1...Why does someone think that the water has to be
brought to a boil before it will evaporate. Water evaporates very well
even at sub-freezing temperatures,much less at the warm to hot temps
created in a running engine. And at say 140 F, I can't help but believe
that any water or moisture in the engine will be purged quickly. With
water at that temp you can literally see clouds of vapor escaping, and
this is well below boiling. Not that the hotter the engine gets the
water doesn't evaporate more quickly, it does I'm sure. It's just that
in the engine cases which are open to the air at the breather tube and
elsewhere, any heat above say 85 F or so will be more that enough to
dry out the oil in the crankcase. As evidence of this, I ground run my
engine all the time and have for many years. I live in a VERY humid
climate. The oil analysis reports I have done on a regular basis by
Blackstone have never shown any trace of water or moisture. I recently
tore done the engine for rebuild after more then 15 years of perfect
service, and the cam lobes, lifter faces, and every part in the engine
was shiny and totally free from rust or any other corrosion.
Concerning fact #2.... We all constantly clean and oil many of the
things we own such as tools, etc. It is the layer of oil that prevents
the rust. I accept that if the oil is too acidic it could corrode or
"chem mill" the metal, but it takes highly acidic liquid to do that,
and the oils I use have acid buffers in them to deal with mild acidity.
Running is the only way to re-oil all the parts in the engine,
especially the cam and lifters. Just like oiling the machinists tools
that I own keeps them rust free, oiling the engine keeps it rust free I
would think.
Concerning fact #3.... This is the one that really makes me wonder. If
oil needs to be changed every 25-50 hours, how does flying for an hour
clean it? I can't help but think that the longer the oil is used the
dirtier it gets. I guess they think that it's "really" dirty just after
starting, and you "clean" it as you fly.
In closing, it seems to me that many of the things we are told are
contradictory on this subject. I have witnessed many OWT come and go in
my time, so common knowledge isn't always correct, lean of peak
operation comes to mind. Some blockheads still don't think George Braly
has it right.
Blue Skies
Rusty
Old April 24th 06, 03:27 AM posted to rec.aviation.owning
Good Post, Captain!
Water in our oil, or just alot of hot air? [email protected] Piloting 9 April 24th 06 05:30 AM
Airbus A380 water purification john smith Piloting 1 July 7th 05 02:50 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
