The Approach in question is SDF RWY 2 at KISW. I was coming in from the
south, nearly lined up with the inbound course of 021 degrees. I was in touch with ATC. The LOM/IAF is called NEPCO. The ATC asked if I wanted "direct NEPCO." I said yes. Within about 10 miles of the airport, the controller said that frequency change was approved. I believe I was out of radar contact by this time (radar coverage in the area is spotty). 1. Since there is no "NO PT" indicated on the chart, does that mean that I am required to do a 180 deg turn when I reach NEPCO so I can track outbound (201), then do a PT, then come back? That seems a little odd to me. 2. If so, and I am assuming it is, should I have positioned myself to approach NEPCO at an intercept that did not require a 180 deg turn to get to the outbound course? Maybe come at it from the east? 3. Suppose that when I reach NEPCO (IAF), I am below the cloud deck. Assume that I have switched over to unicom frequency at that point. Is it permissible to abort the IFR approach and turn inbound for a visual approach. Presumably, you would have to ask ATC permission to do this. What if you can not raise ATC on the radio? Can you go visual on your own? -Sami N2057M, Piper Turbo Arrow III |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Why an NDB approach with a miss to an intersection? | Ben Jackson | Instrument Flight Rules | 10 | March 25th 04 03:53 AM |
Changes to Aircraft Approach Categories?! | skyliner | Instrument Flight Rules | 10 | February 9th 04 08:55 PM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
