STAR to nearby airport
Old May 12th 04, 11:12 PM
Steven P. McNicoll
"Roy Smith" wrote in message
I've had similar conversations with CD at White Plains. The gist of
them is usually something like, "unable 8000 due to icing", "OK, you
need to work it out with the departure controller once you're in the
air".
It's stupid, but at least you need to stick to your guns. I've done it
a few times. You take off, and check in with departu
"New York, Arrow 3875T, 1200 climbing 3000".
"Radar contact, climb maintain 8000".
"Unable 8000 due to icing"
"Nobody told me that, weren't you cleared to 8000 on the ground?"
"Yup, and I said unable, and the ground controller told me to work it
out with you"
eventually, they find something to do with you, but it sure doesn't seem
like the right way to run things.
What was your plan if departure couldn't find something to do with you?
Old May 12th 04, 11:30 PM
Roy Smith
In article . net,
air".
out with you"
Didn't really have one, but so far they've always managed to work
something out. I'm not saying this is a good (or particularly smart)
thing, but I see it more as a problem for ATC than for me (as long as I
don't let them talk me into climbing into the ice).
Old May 12th 04, 11:34 PM
Steven P. McNicoll
Didn't clearance delivery already talk you into climbing into the ice?
What's your plan if departure doesn't have an alternative for you?
Old May 12th 04, 11:49 PM
Ray Andraka
N12345: "White Plains departure, unable 8000 due to icing, request 3000 as
final today"
WPD: "Negative, climb and maintain 8000"
N12345: "N12345 declaring an emergency"....
The Feds would smile all the way to your hearing on this one...it is an
emergency of your own making
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old May 13th 04, 02:10 AM
EDR
In article , Ray Andraka
final today"
This was going to be my response.
The FARs prohibit you from flying into icing in an aircraft not
certified for icing. By accepting the clearance, you are violating the
FARs.
Which leads to another question...
If ATC issues a clearance which will cause you to violate the FARs, are
you legally bound to accept it?
Old May 13th 04, 02:27 AM
Steven P. McNicoll
"EDR" wrote in message
No, and that is made known to controllers.
FAA Order 7110.65P Air Traffic Control
Chapter 2. General Control
Section 1. General
2-1-1. ATC SERVICE
The primary purpose of the ATC system is to prevent a collision
between aircraft operating in the system and to organize and expedite the
flow of traffic. In addition to its primary function, the ATC system has the
capability to provide (with certain limitations) additional services. The
ability to provide additional services is limited by many factors, such as
the volume of traffic, frequency congestion, quality of radar, controller
workload, higher priority duties, and the pure physical inability to scan
and detect those situations that fall in this category. It is recognized
that these services cannot be provided in cases in which the provision of
services is precluded by the above factors. Consistent with the
aforementioned conditions, controllers shall provide additional service
procedures to the extent permitted by higher priority duties and other
circumstances. The provision of additional services is not optional on the
part of the controller, but rather is required when the work situation
permits. Provide air traffic control service in accordance with the
procedures and minima in this order except when:
a. A deviation is necessary to conform with ICAO Documents, National
Rules of the Air, or special agreements where the U.S. provides air traffic
control service in airspace outside the U.S. and its possessions or:
NOTE-
Pilots are required to abide by CFRs or other applicable regulations
regardless of the application of any procedure or minima in this order.
b. Other procedures/minima are prescribed in a letter of agreement,
FAA directive, or a military document, or:
NOTE-
These procedures may include altitude reservations, air refueling,
fighter interceptor operations, law enforcement, etc.
REFERENCE-
FAAO 7110.65, Procedural Letters of Agreement, Para 1-1-8.
c. A deviation is necessary to assist an aircraft when an emergency
has been declared.
REFERENCE-
FAAO 7110.65, Safety Alert, Para 2-1-6.
FAAO 7110.65, Emergencies, Chapter 10.
FAAO 7110.65, Merging Target Procedures, Para 5-1-8.
Old May 13th 04, 04:48 AM
Teacherjh
But be careful because ATC may have to have you at 8000. So if you are
unable you may be parked for a long while.
If I'm picking up ice, the laws of physics will take over, and whether or not
they "have to have me" at 8000, I won't be there.
Jose
  #29
Old May 13th 04, 04:52 AM
Teacherjh
No.
If you are in the air, you still fly your old clearance while you reject the
new one and you and ATC work it out. If you are on the ground however, ATC has
no incentive to work it out with you. You end up staying on the ground.
Jose
  #30
Old May 13th 04, 05:08 AM
Brad Z
ATC has
what old clearance? You were told told to expect 8,000 on the ground.
Taking off is by definition acceptance of a clearance.
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 03:34 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
