IFR hold short line at uncontrolled airports?
Old May 28th 04, 01:09 AM
Matt Whiting
Ron Natalie wrote:
"Matt Whiting" wrote in message ...
Then why do some runways have ILS critical areas and others do not?
All runways have an ILS critical area. The issue is whether there is a taxiway that passes
through it or not.
My home airport, N38, doesn't. :-)
Matt
Old May 28th 04, 01:15 AM
Teacherjh
The longer runways are more likely to have critical areas.
Why?
Jose
Old May 28th 04, 02:17 AM
David Megginson
Why?
The localizer will be closer to the (opposite) runway threshold.
All the best,
David
Old May 28th 04, 02:24 AM
Roy Smith
In article
ogers.com,
David Megginson wrote:
Why?
All the best,
David
Why should runway length affect how far the localizer antenna is from
the runway end?
Localizers are designed to have a fixed width (something like 700 ft
lateral displacement for full-scale deflection on the CDI) at the
arrival threshold, so longer runways will have narrower angular beam
widths. But (to the best of my knowledge) this is done by adjusting the
spacing of the transmitting elements on the localizer array, not by
adjusting the distance of the array from the runway end.
Old May 28th 04, 02:34 AM
Teacherjh
widths.
Doesn't make sense to me. Angular beam width should be constant - for the far
field. Then the antenna is placed at the distance from the arrival end (also
constant) that gives the proper width.
No?
Jose
Old May 28th 04, 03:01 AM
Newps
"Teacherjh" wrote in message
Why?
Because the localizer spreads out at a constant rate. The longer the runway
the wider it will be at the end of the runway.
Old May 28th 04, 05:51 AM
Tom Sixkiller
"Newps" wrote in message
The glideslopes are as they are all positioned to bring you to the same
spot
on every runway. The localizer is sited so it is a certain width at the
approach end of the runway, therefore they will move the localizer antenna
closer to or farther away from the departure end of the runway to achieve
that.
They can't "focus" or "tighten" the signal for longer runways???
Old May 28th 04, 12:33 PM
Steven P. McNicoll
runway
But the localizer critical area doesn't extend to the end of the runway.
For a category I ILS it typically extends only 2000 feet from the antenna
array.
  #29
Old May 28th 04, 02:02 PM
Steven P. McNicoll
The longer runways are more likely to have critical areas. Runways whose
taxiways get too close to the runway is also a factor. We have that
problem
here at BIL. The last 3000 feet of taxiway angles in toward the runway
creating the need for an ILS hold area because you get in the way of the
localizer.
The ILS hold at BIL is near the east end of runway 10L/28R. It's there to
protect the localizer for the ILS RWY 10L, not the localizer for the ILS RWY
28R.
  #30
Steven P. McNicoll
"David Megginson" wrote in message
le.rogers.com...
So what?
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
