#21
Matt Barrow wrote:
WAAS will provide about 10 feet, but that only for approaches with WAAS augmentation. WAAS actually works anytime the satellite correction signal is available, you don't have to be flying an approach. My Garmin 60CS, as well the eTrex Vista I previously owned, both use WAAS corrections. I can't remember the last time I didn't get the corrections. |
Paul Tomblin wrote:
As a former surveyor, I can tell you that the altitude requirements for surveying are a lot more precise than for aviation - if my bridge abutment is built 2 feet high, I'm getting fired. If my plane is 2 feet high, nobody is going to notice. Looks as if I'm missing something central here, as usual ![]() If there is a 4-hour flight that passes over some 10 waypoints and if the FMGS keeps getting data that's off by 50 meters or so, am I to understand that the aircraft will still make heading changes, etc. that'd be in accordance with the programmed flight plan and that none of the waypoints will be missed or indeed the final destination precisely arrived at? And someone mentioned an acceptable accuracy of 0.1 foot in property surveying. If surveyors in my industry had that much latitude, there'd be a lot of equipment skids that'd get installed quite inappropriately, with lots of patched modifications thereon ![]() Ramapriya |
B A R R Y wrote:
Matt Barrow wrote: WAAS will provide about 10 feet, but that only for approaches with WAAS augmentation. WAAS actually works anytime the satellite correction signal is available, you don't have to be flying an approach. My Garmin 60CS, as well the eTrex Vista I previously owned, both use WAAS corrections. I can't remember the last time I didn't get the corrections. A friend bought a 60CS recently and we noticed that my old Garmin-12 got better reception and seemed more accurate. We called Garmin and the fellow we talk with was surprised because both units use the same chips inside! |
("Andrew Sarangan" wrote)
In addition to what every one else mentioned, aviation GPS also has a feature known as RAIM which stands for Receiver Autonomous Integrity Monitoring. It warns you of any problems with the satellite signals. Some have RAIM prediction as well. How does RAIM prediction work, I wonder? The GPS unit knows where you are, knows where you're heading, and knows where x number of signals will be - based on the satellites' "predictable" orbits.... g Ok. No clue. Montblack |
In a previous article, (Jay Masino) said:
Paul Tomblin wrote: Years and years ago, I was told how to access some diagnostic modes on my Garmin GPSMAP 195. The diagnostic mode showed the state of all sorts of Paul, Do you happen to remember what the keystrokes were to get to the 195's diagnostic mode? I'd be curious to see what mine is saying. Don't remember - it was probably 10 years ago, and probably on this newsgroup. You might want to see if Google Groups has it. There were two combinations of three buttons you could hold down as you started it - one wiped all your routes, tracks and user waypoints, and the other started a diagnostic mode. Don't get them confused. -- Paul Tomblin http://xcski.com/blogs/pt/ "All life is transitory. A dream. We all come together in the same place at the end of time. If I don't see you again here, I will see you in a little while in the place where no shadows fall." - Delenn |
In a previous article, Stubby said:
I had my property surveyed and asked what the accuracy was. The surveyor replied that 0.1 foot is the standard for most applications and 0.01 foot is required for commercial, high-precision applications. They use GPS (DGPS??) but I don't know how. You need a better surveyor. When I was doing road construction layout, we were expected to get the marks within 5-7 millimeters. And when they actually did the construction, they were allowed to be within 2-3 centimeters. (You've heard the expression: measure with a micrometer, mark with chalk, cut with an axe.) Legal surveyors were supposed to be *far* more accurate than us. For instance, we just held the chain (that's the "measuring tape" to you) or laid it down on the ground. Legal surveyors had a special device to make sure they were holding exactly the right amount of tension on the chain because that's what it was calibrated for. -- Paul Tomblin http://xcski.com/blogs/pt/ ALL programs are poems, it's just that not all programmers are poets. -- Jonathan Guthrie in the scary.devil.monastery |
Matt Barrow wrote:
Aircraft GPS systems are accurate to about 30 feet; how well do you think that would work if your building a bridge, or more importantly, a tunnel? If I was owner, I'd end up with two tunnels for the price of one ![]() Ramapriya |
#29
In a previous article, B A R R Y said:
My Garmin 60CS, as well the eTrex Vista I previously owned, both use WAAS corrections. I can't remember the last time I didn't get the corrections. I have a Garmin 296 with WAAS, and I get WAAS nearly every time when I'm flying (but not always), but I only seem to get it about half the time when I'm driving. But I live, fly and drive up near the Canadian border, so maybe the coverage isn't as good up here. -- Paul Tomblin http://xcski.com/blogs/pt/ Real Time, adj.: Here and now, as opposed to fake time, which only occurs there and then. |
#30
oups.com... Looks as if I'm missing something central here, as usual ![]() Could be. ![]() If there is a 4-hour flight that passes over some 10 waypoints and if the FMGS keeps getting data that's off by 50 meters or so, am I to understand that the aircraft will still make heading changes, etc. that'd be in accordance with the programmed flight plan and that none of the waypoints will be missed or indeed the final destination precisely arrived at? That is correct. The presumed 50 meter accuracy is constant throughout the flight. It's not as though it's additive for each waypoint (or worse, as a continuous function along the flight). Though frankly, even if it were, you'd only be off by 500 meters after 10 waypoints which is still "no big deal". That's one of the many nice things about GPS. It is a continuous readout of one's current position and any forward-looking navigation solution can be derived from the instantaneous position information, without any previous position information affecting the future calculations. And of course, again...being 50 meters off in aviation just isn't that big of a problem. Heck, being a mile off in aviation isn't that big of a problem most of the time. And someone mentioned an acceptable accuracy of 0.1 foot in property surveying. If surveyors in my industry had that much latitude, there'd be a lot of equipment skids that'd get installed quite inappropriately, with lots of patched modifications thereon ![]() Well, as that poster pointed out, it depends on the situation. But property surveying for non-commercial purposes isn't likely to be used for any sort of actual construction (except possibly locating a building, and for sure no one is going to care if a building is off one inch one direction or another, especially in a non-commercial situation). As for equipment skids and such, since I don't know the details of your industry I can't really comment on that. But it seems to me that if you require that level of detail and are using GPS to accomplish it, you must be dealing with positioning these skids at a significant distance from wherever they are referenced to. Otherwise, I'd think one would use more "conventional" surveying techniques to determine position, orientation, etc. The only surveys I've ever hired were strictly property surveys, in which property boundaries are determined, locations of roads, trees, terrain contours, etc. Getting the results to within an inch is perfectly sufficient for that type of survey. It's not hard to imagine a wide variety of surveys for which the same holds true. Just because some situations demand higher precision, that doesn't mean all situations do. Pete |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Airmens' Freedoms Threatened by Harsh Congressional Proposals | Larry Dighera | Piloting | 24 | July 29th 05 06:15 PM |
Aviation Books&CD Roms FS | [email protected] | Home Built | 0 | April 10th 05 10:29 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
