When do you use autopilots?
Old October 21st 06, 10:28 PM posted to rec.aviation.piloting
Mxsmanic
Default When do you use autopilots?
Do you use autopilots on short trips (along the lines of an hour or
so)? Do you use autopilots systematically on IFR flights?
Is it bad form to use the autopilot for a 25-minute flight? I've
tried KPAE-KTIW under IFR both by hand and with autopilot, and
autopilot is a breeze in any weather whereas flying by hand is
troublesome even without any wind or turbulence. I try to fly by
hand, but the lure of the autopilot is strong sometimes and I use it
to get some rest.
So how often do you use autopilots in real life? And to what extent
to you prefer to use them?
Old October 22nd 06, 02:53 AM posted to rec.aviation.piloting
Judah
Mxsmanic wrote in
to get some rest.
If flying by hand is difficult without wind or turbulence, you are either not
a very good pilot, or you don't have a very good simulator. Autopilot
certainly makes life easier, but you should be able to keep the plane flying
on course and altitude without it.
As an example, I recently flew 3 hours from South Carolina to NY without an
AutoPilot (it was temporarily out of service), and it really wasn't that
difficult or tiring. The wind was mild, and proper attention to the trim and
the heading was really all that was required.
Old October 22nd 06, 08:48 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Judah writes:
It's the former, and I think it is frustrating _because_ the
simulation is good. I do think it might be easier in some respects in
a real aircraft, since movements of the aircraft would remind you when
to look at which instruments, and you have better visibility out the
window and control pressures, etc. However, I think the overwhelming
reason in my case is lack of experience. Even on a short flight, it
gets tiring trying to hold a heading and altitude, but I'm getting
better.
Autopilot
Within what limits? I fly to a heading and then 30 seconds later when
I check it again I've drifted two degrees or so and have to move it
back. Altitude is a much bigger problem, with a constant
roller-coaster ride through as much as 150 feet or so for quite a
while. By the time I wrestle it onto a steady altitude, I'm being
told to climb or descend again.
I hope so.
Old October 22nd 06, 05:02 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
Mxsmanic wrote in
simulation is good.
How do you know it's good????? You have never been in a REAL plane to
have anything to compare to! So you don't know squat.
But I do.
I found on the contrary, SIMULATED FLIGHT on MSFS is NOT GOOD for
simulating REAL FLIGHT.
MSFS don't give you that head rush on steep turns.
MSFS don't give you spatial disorientation in IMC.
MSFS don't paint the sky as well as God can.
MSFS don't give you the sense of freedom as you fly in the canyons of
Cumulus clouds
MSFS don't give you the sensation of floating on air at cruise altutide.
MSFS don't give you anything when it comes to human physiology.
Whether you like it or not, human physiology is part of the joy of
flying. I sure as hell don't get the same feeling sitting in my lazy boy
chair in front of a flat panel comoputer playing the GAME OF MSFS.
MSFS don't give you that sense of accomplishment after a lesson of REAL
FLIGHT.
Crap, here I had "signed" a promise to not reply to your posts, but I
sure don't want FUTURE STUDENTS to even think that MSFS will be anything
close to flying a REAL plane. It's simply put, not even the tip of the
iceberg of what a REAL PLANE gives you.
Seeing how clueless on your other posts regarding the practicality
General Aviation and flying in general (Yes, I restrained myself from
replying to your other non sensible dribble), you really need to get your
head out of your computer screen and join the real 3D world of flight in
a REAL PLANE.
Allen
Old October 22nd 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
Mxsmanic wrote in
The accepted limits are documented in the Airmen Practical Test Standards,
which you can read online he
http://www.faa.gov/education_researc...ards/pilot/med
ia/FAA-S-8081-14A.pdf
The limits for Instrument flight are slightly "tighter" and are documented
he
http://www.faa.gov/education_researc...ards/media/FAA
-S-8081-4D.pdf
2 degrees of heading is acceptable. 150 feet of altitude, however, is not.
Old October 22nd 06, 08:23 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Judah writes:
he
-S-8081-4D.pdf
Thanks. I have saved these documents and will examine them in greater
detail as time permits.
Old October 23rd 06, 05:50 AM posted to rec.aviation.piloting,rec.aviation.student
Dan[_1_]
I find altitude much harder to hold steady on flight simulators than on
real aircraft. Something about the control pressures, I suspect.
--Dan
Mxsmanic wrote:
Judah writes:
he
-S-8081-4D.pdf
Old October 22nd 06, 02:58 AM posted to rec.aviation.piloting
The Visitor
Short answer.
Use it if you got it.
Save your energy for when things go wrong.
J
to get some rest.
Old October 22nd 06, 08:49 AM posted to rec.aviation.piloting
Mxsmanic
The Visitor writes:
Short answer.
Seems logical, but do you worry about getting out of practice in hand
flying?
Old October 22nd 06, 12:25 PM posted to rec.aviation.piloting
The Visitor
Working 14 days a month? Yes. But there is very little of it. Not even
on six month rides.
In lighter aiccraft there is lots of hand flying, all but the enroute
phase. I know people still flying large jets whose autopilot is so poor,
they do the terminal maneuvering and approach by hand, no choice. And in
some crummy locations (mountainous). And only having one simple one,
autoland is out.
Do you sit there at your sim, droning along for 3,4,5,6,7,8,9 hours
enroute, handflying? What aircraft/route are you asking about?
Mxsmanic wrote:
The Visitor writes:
Short answer.
flying?
Rudder for final runway alignment (?) Mxsmanic Piloting 124 October 2nd 06 09:39 PM
Piper Altimatic II autopilots - anyone? nobody Owning 12 February 8th 06 03:38 PM
DGs and Autopilots Andrew Gideon Owning 11 April 14th 05 06:04 PM
Autopilots... failure modes john smith Instrument Flight Rules 14 October 22nd 04 05:22 AM
Artificial Horizon/Autopilot Connection Jay Honeck Owning 2 September 7th 03 05:07 PM
