#21
Oh, I agree wholeheartedly and have been lucky enough to have an
instructor who would work that way with me. However, and this is the biggie, the piece of knowledge we're talking about...simply ain't taught if you're in a 172, for instance!! If the POH has a published best glide speed, the instructor and the examiner expect you to know that value and fly it. If you can explain a variation, great! Go for it! You're still going to be asked to fly the airplane to the POH spec. So perhaps my assumption is the fault in my reasoning: I assumed an airplane where the POH publishes a value and, as you examine the curriculum, it becomes apparent that the POH and the candidates familiarity and observance of the data seem to be treated as paramount. Check out the PPL knowledge guides for the written exam and you'll note that this subject isn't even part of the curriculum! I was once on a check out flight in a 172 over water next to Paine field. Winds at altitude were gusting to speeds higher than the published best glide. Instructor pulls the throttle, predictably, and I react using the published data. He notes this and I observe to him, "We aren't going to make that field upwind and 2 miles from us because we're going backward." "So what are you going to do?", he says. "I'm going to trade altitude for speed to make that field as there are no other clear areas reachable from this altitude including downwind.", I reply. "Fine, do it.", says he. Same theory, same issue. I think it would be good for Nik to chase that data down and teach his instructor something he might need to know. But I don't think it will do him much good if his examiner has a similar hole in knowledge. So I'm suggesting should the situation repeat itself, he should demonstrate competence in the expected manner and then consider a conversation on the topic later. Should save him some trouble and he'll still have useful knoweldge he can exercise should he really need it at some point. No instructor's knoweldge is perfectly complete, similarly, the same is true for examiners, students or any other pilot. The situation of one knowing something the other doesn't is normal. Attempting to share that knowledge is good and commendable. But if doing so is going to cost you, suppress it, get through the exercise, achieve your goal, teach later. That is, unless you enjoy arguing it...like we obviously do! ![]() Greg Chapman Peter Duniho wrote: wrote in message ups.com... [...] In other words, for what you're trying to get done, please the professor first. Engage in the debate after you get your license. Odds are that you'd have the same tough sell in front of you if you attempt the same argument during your checkride. You can prove you're right later. Does that seem sensible? That advice makes some sense for someone in Schiff's position. I don't agree that it makes sense for a student who is actually hiring his instructor to teach him something. In this case, the student knows the answer, understands the answer, and is confident in that knowledge. But what if something else comes up in which the instructor is *also* mistaken, and in which the instructor refuses to consider the possibility that he's wrong? If it turns out in that situation that Nik either doesn't know for sure what the right answer is, or doesn't even have reason to suspect the instructor is wrong, then Nik will be at a disadvantage, being taught by an instructor who should not be instructing in the first place. I have had situations with instructors in which I was only to fly with the instructor once, for the purpose of showing some competence in an airplane or type of flight or something like that and in which the instructor said or did something that I disagreed with (and most of the time, it turned out I was right ![]() flow, and let the instructor have his way (assuming it's not a safety of flight issue, of course...I had to terminate an IPC prematurely, because of an instructor who was so bad, he was interfering with the safety of the flight). But for someone with whom you expect to have an on-going relationship, even if for a few lessons but especially for a primary student, it's important to a) resolve every single issue to the point of truthful consensus, and b) to know that you can trust your instructor to not tell you something is absolutely true when in fact it's known to be absolutely false. I don't know whether the flight in question was a one-time thing, or is part of on-going instruction that Nik is taking from the instructor, but in absence of that knowledge, I think it's important to make sure that no one thinks it's okay to just let an instructor say wrong things, especially if one is doing more than just the one flight with that instructor. Pete |
![]() Nik wrote: Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik Once the engine quits, the power plane is a glider, albeit one with a really sucky glide ratio. As someone else pointed out, ask the instructor what the best glide speed is if there is a headwind that equals the POH recommended glide speed. This is just one area in which I have come to believe that pilots with glider experience have an edge over power pilots. I truly believe that glider pilots have to know a lot more about their airplanes, micro-weather, etc. Instructors are people. Sometimes they are wrong. Since they are in something of an authority position, there is a tendency to defend an idea. Attempting to teach them something can be a learning experience--the student will gain some experience in diplomacy, and might find out that HE is wrong himself. Usually, I've found that the instructor and student are looking at two slightly different things, and that continuing a rational conversation will iron things out. If not, there are lots of instructors out there. Avoid getting bent out of shape. |
well.. glide speed adjustments into a headwind applies to every thing that
moves through the air.. just ask the birds. do the math.. what is his effective L/d over the ground if he does not increase speed and.. my New C-182T POD does give "best glide" speed. "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
I'll bet that instructor will get dizzy looking at that web page and stick
to his guns... even though he's carrying blanks. BT "Gary Drescher" wrote in message ... "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. ... But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? You might try pointing him to http://www.av8n.com/how/htm/power.ht...nd-penetration. Or you might try to convince him to let you fly it both ways and see which way gets you further. If that doesn't persuade him, you might decide do it his way when you fly with him, and do it the right way at other times. --Gary |
That rule of thumb doesn't quite work, as the wing loading is different.
I would guess 4 to 6 knots but I've not the time for the maths right now. Nik wrote: Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Richard Collins. Thanks! -Nik |
![]() Nik wrote: Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik Most airplane training books don't discuss this concept, and POH rarely ever mention this. We are taught by a system that enforces the view that we should follow the POH exactly and not improvise anything. So it is not unreasonable that this instructor never gave much thought to this concept until you challenged him. However, most intelligent people will realize this as soon as you point it out. You owe him at least that much. If he doesn't turn around, then you have to start wondering what other uncorrected misconceptions that he is passing on to you. Everyone makes and has misconceptions, but stubbornly holding on to them in the face of opposing evidence is what distinguishes an intellect from others. |
![]() "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Without trying to second guess your instructor, I am not convinced from your discussion that this represents a lack of knowledge on the part of your instructor. He may simply be trying to keep things as simple as possible. The idea of frequent practiced forced landings without power is to hopefully give you the skills to do it without thinking in the event that it happens to you in real life when you will likely be racked with shear terror. Practicing at the published best glide speed , roughly gives you a constant attitude "picture" that enables you to focus more outside the aircraft than on the airspeed indicator. You could have a similar argument about weight as the best glide speed will be significantly lower if you are flying solo and especially if the reason for engine failure was no fuel! But are you going to get out the calculator and calculate the weight corrected best glide speed when the noise stops? Should an instructor tell you that flying a Warrior solo would have a best glide speed closer to 65 kts than the published 73kts? There is enough to learn already without over finessing things too early in the learning. After all we know the learning really starts after you get the license. terry |
#29
Jay Beckman writes:
Sure as hell, some student pilot will believe his increadible bull**** and go get themselves killed. That is far less likely than a student pilot being killed by his unquestioning acceptance of misinformation from a flight instructor whom he has been told not to question. It amazes me that students are being advised here to accept misinformation and inaccuracy just for a piece of paper. However, it does explain the misdeeds of some pilots. And it does resemble the credentialism that afflicts society in general--a belief that the paper is more important than what it putatively represents (because restrictions address the paper, not the qualities it is supposed to document). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Air Force seeks to increase military participation in 8th annual . | Otis Willie | Military Aviation | 0 | June 18th 04 10:53 PM |
