AH, but the real question is... would a 302 or other GPS be capable of
generating the data that could be fed to a Mode S transponder? Yeah, yeah all the illegal stuff and your insurance would never pay if you ground looped..., but would it work or are the certified GPS units sending out a different data protocol? hans wrote: Hi Tom! your 302 does not qualify as a certified GPS for the mode S transponder. Best Regards Hans Tom N. schrieb: I live in San Antonio, Texas, USA. We fly out of a field 15 nautical miles away from San Antonio International airport and are basically on final approach for a lot of jet traffic. There are also two Air Force bases in the immediate area. There is no requirement in the U.S. to have mode S as there will be in Europe. However, if there is less power consumption due to fewer interrogations or if there is more accuracy on TCAS, I would be willing to go with it. I use a Cambridge 302 for GPS. Stefan wrote: Tom N. schrieb: Any opinions? I plan to install a new Becker transponder in my ASW-28. Should I go with the old mode C unit or pay extra for the new mode S unit? Thanks. Tor answer this question, it would be extremely helpful to know in which part of the world you intend to fly. |
I can't remember any requirement of NMEA output for aviation certified
GPS receiver. Mode S transponder are at least required to work with ARINC input. I have to check whether the ARINC input is the only permitted input to the mode S transponder. Gary Emerson schrieb: AH, but the real question is... would a 302 or other GPS be capable of generating the data that could be fed to a Mode S transponder? Yeah, yeah all the illegal stuff and your insurance would never pay if you ground looped..., but would it work or are the certified GPS units sending out a different data protocol? hans wrote: Hi Tom! your 302 does not qualify as a certified GPS for the mode S transponder. Best Regards Hans Tom N. schrieb: I live in San Antonio, Texas, USA. We fly out of a field 15 nautical miles away from San Antonio International airport and are basically on final approach for a lot of jet traffic. There are also two Air Force bases in the immediate area. There is no requirement in the U.S. to have mode S as there will be in Europe. However, if there is less power consumption due to fewer interrogations or if there is more accuracy on TCAS, I would be willing to go with it. I use a Cambridge 302 for GPS. Stefan wrote: Tom N. schrieb: Any opinions? I plan to install a new Becker transponder in my ASW-28. Should I go with the old mode C unit or pay extra for the new mode S unit? Thanks. Tor answer this question, it would be extremely helpful to know in which part of the world you intend to fly. |
Why would you want a Mode S transponder to be fed by a GPS? The
Extended Squitter variation of ADS-B does layer on top of the Mode S downlink protocol, but simply feeding GPS data to a Mode S transponder will not make it ADS-B compliant. An entirely new box will be needed. The only reason to use a Mode S transponder in the US (outside of the categories of aircraft for which it is mandated) is to take advantage of the uplinked traffic and weather information, which needs an expensive and power hungry multi-function display. Since some of those services are now being shut down in anticipation of ADS-B deployment, even that reason is slowly being rendered meaningless. Also, do not forget that it costs roughly twice as much to recertify a Mode S transponder, and you may have to go farther to find a shop that has the right test equipment. In response to the original poster, if you spend extra money to install and maintain a Mode S (instead of C) transponder in a glider operating in the US, you're simply wasting money... Marc Gary Emerson wrote: AH, but the real question is... would a 302 or other GPS be capable of generating the data that could be fed to a Mode S transponder? Yeah, yeah all the illegal stuff and your insurance would never pay if you ground looped..., but would it work or are the certified GPS units sending out a different data protocol? hans wrote: Hi Tom! your 302 does not qualify as a certified GPS for the mode S transponder. Best Regards Hans Tom N. schrieb: I live in San Antonio, Texas, USA. We fly out of a field 15 nautical miles away from San Antonio International airport and are basically on final approach for a lot of jet traffic. There are also two Air Force bases in the immediate area. There is no requirement in the U.S. to have mode S as there will be in Europe. However, if there is less power consumption due to fewer interrogations or if there is more accuracy on TCAS, I would be willing to go with it. I use a Cambridge 302 for GPS. Stefan wrote: Tom N. schrieb: Any opinions? I plan to install a new Becker transponder in my ASW-28. Should I go with the old mode C unit or pay extra for the new mode S unit? Thanks. Tor answer this question, it would be extremely helpful to know in which part of the world you intend to fly. |
A Mode S transponder does not need any inputs from a GPS.
Mike Schumann "Gary Emerson" wrote in message t... AH, but the real question is... would a 302 or other GPS be capable of generating the data that could be fed to a Mode S transponder? Yeah, yeah all the illegal stuff and your insurance would never pay if you ground looped..., but would it work or are the certified GPS units sending out a different data protocol? hans wrote: Hi Tom! your 302 does not qualify as a certified GPS for the mode S transponder. Best Regards Hans Tom N. schrieb: I live in San Antonio, Texas, USA. We fly out of a field 15 nautical miles away from San Antonio International airport and are basically on final approach for a lot of jet traffic. There are also two Air Force bases in the immediate area. There is no requirement in the U.S. to have mode S as there will be in Europe. However, if there is less power consumption due to fewer interrogations or if there is more accuracy on TCAS, I would be willing to go with it. I use a Cambridge 302 for GPS. Stefan wrote: Tom N. schrieb: Any opinions? I plan to install a new Becker transponder in my ASW-28. Should I go with the old mode C unit or pay extra for the new mode S unit? Thanks. Tor answer this question, it would be extremely helpful to know in which part of the world you intend to fly. |
US military fighter type aircraft do not currently have TCAS
Do not rely on TCAS to keep you safe BT "Tom N." wrote in message ups.com... I live in San Antonio, Texas, USA. We fly out of a field 15 nautical miles away from San Antonio International airport and are basically on final approach for a lot of jet traffic. There are also two Air Force bases in the immediate area. There is no requirement in the U.S. to have mode S as there will be in Europe. However, if there is less power consumption due to fewer interrogations or if there is more accuracy on TCAS, I would be willing to go with it. I use a Cambridge 302 for GPS. Stefan wrote: Tom N. schrieb: Any opinions? I plan to install a new Becker transponder in my ASW-28. Should I go with the old mode C unit or pay extra for the new mode S unit? Thanks. Tor answer this question, it would be extremely helpful to know in which part of the world you intend to fly. |
BT wrote:
US military fighter type aircraft do not currently have TCAS Do not rely on TCAS to keep you safe This is correct. However, there is no doubt a TCAS will keep you safeR! But then again, you must have a transponder to be see on their screen. It's an overkill on a 2-33 going around the pattern all day long, but certainly not in a modern glider within 30 miles of a class B or C airspace. I fly for the same company involved in the mid-air. Trust me, at the speed we fly, gliders are hard to see. Heck, even thermalling in a glider, other gliders can be hard to spot! Richard Phoenix AZ |
"jeplane" wrote in message ups.com... BT wrote: US military fighter type aircraft do not currently have TCAS Do not rely on TCAS to keep you safe This is correct. However, there is no doubt a TCAS will keep you safeR! But then again, you must have a transponder to be see on their screen. It's an overkill on a 2-33 going around the pattern all day long, but certainly not in a modern glider within 30 miles of a class B or C airspace. I fly for the same company involved in the mid-air. Trust me, at the speed we fly, gliders are hard to see. Heck, even thermalling in a glider, other gliders can be hard to spot! Richard Phoenix AZ I will agree on the safeR part.. but only from part of the variety of aircraft flying. Gliders are hard to see.. so are T-38s coming at you nose on. T-38s don't have TCAS. Would it have made a difference if it was a Cessna Single Engine at cruise altitude instead of a glider? Probabily not.. there still may have been an accident.. granted the Cessna Single would more likely have a transponder, so the BIZ Jet would have gotten a TCAS return.. but that Cessna with no TIS display would never have gotten a return on the Jet or the Glider. I do fly 2-33s inside the Mode C Veil and up to 12K MSL in summer.. and other gliders much higher. Not just around the traffic pattern. The 2-33, Grob 103 and LS-4 all show up on approach radar with no transponder. Center's tend to filter non transponder returns to reduce clutter. BT |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Breaking News.... (?) | john smith | Piloting | 1 | August 19th 05 03:13 AM |
| Loss of Mode C and Transponder Reply | mikem | Owning | 4 | February 27th 04 06:52 PM |
| WTB: Mode C Transponder | Chris Batcheller | Aviation Marketplace | 0 | February 21st 04 02:31 PM |
