Loss of Mode C and Transponder Reply
Old February 27th 04, 01:32 AM
mikem
Default Loss of Mode C and Transponder Reply
Lost Mode C and Transponder reply while in Class B airspace the other
day. After landing, was looking at all of the simple obvious things,
like transponder not seated in tray etc. Little voice told me
to look at the antenna, too.
Seems the whip broke at the base and just fell off. It is mounted on the
bottom of the boot cowl just aft of the firewall on the PA22/20, and
probably gets subjected to some buffeting from the propellor pressure
pulses.
Mounting a new one further back from the propellor might be better, but
that would put it closer to the landing gear legs. Alternatively, it
would have to go all the way back to mid fuselage where there is a
16x16" metal access plate for the elavator trim jackscrew. The strobe is
mounted on this plate. Otherwise the fuselage is covered with fabric.
Any ideas?
MikeM
Pacer '00Z
Old February 27th 04, 01:45 AM
G.R. Patterson III
mikem wrote:
Any ideas?
I would probably put the new one in exactly the same place. They aren't real
expensive, and I think that's the best place for it on that plane (mine is in
the same place on my Maule).
How long did it last? Maybe the best bet is to replace it periodically before
it fails, like some people replace dry vacuum pumps.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 27th 04, 01:52 AM
pulses.
Any ideas?
MikeM
Pacer '00Z
Go to an avionics shop that knows how to properly install a metal backing
plate in a fabric aircraft.
Ask how much to replace the existing antenna and how much to move it back.
Jim Pennino
Remove -spam-sux to reply.
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 06:56 AM
Narco AT-50 Mode C Transponder for sale Jay Honeck Aviation Marketplace 0 June 28th 04 07:48 PM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 02:31 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Mode S Transponders - Can ATC tell the difference? Doodybutch Owning 2 August 10th 03 07:21 AM
