#21
![]() "Steve Schneider" wrote in message ... john smith wrote: d&tm wrote: Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for Piper PA32's will can also develope this situation. I'd previously posted links for some weight and balance info for a few aircraft I've flown over the years. One of them happens to be a PA32. This link http://www.4-fs.com/new/flying/N3000AWB.xls is to the W&B spreadsheet for the Piper Lance (PA32-RT300T) which we've been flying the last few years. I had included variables for fuel at departure and 'low fuel' for landing for just this reason. You can plug in the following plausible values for a real flight and end up with the CG in range (though precariously aft) at the start of the flight and have the CG aft of the limits with 15 gallons remaining at the end of a flight: Pilot+no front passenger: 180 lb Center Passengers: 0 Rear Passengers: 360 lb Fuel: 94 gal Front Baggage: 0 Rear Baggage: 90 The CG only moves 0.22 inches to the rear after burning 79 gallons of fuel, but it does take you 0.20 inches past the aft CG limit during the flight. Flying this plane with club seating does allow for some interesting weight shifting when passengers (wife and kids typically) swap seats in flight. You definitely do feel the change, and as such I always keep in mind which passengers sit in which seats. Imagine the above loading with the rear passengers (2x180lb) in the center row of seats and the rear seats empty. Once airborne they decide they don't like to fly 'backwards' in the club seating and 'help themselves' to the the empty rear seats. Suddenly we go from a very comfortable CG to a precariously aft CG. Not a situation one generally needs to worry about in 2 and 4 seat airplanes. That is part of why I find these spreadsheets so helpful in quickly looking at a bunch of 'what if' scenarios before we depart. Steve, thanks for that. I have made up similar spreadsheets for the Warrior and C172 , but perhaps a little fancier in that they are set up to select different reg numbers from a drop down menu, with the specific aircraft data ( useful for paupers like me who dont own their own plane), a clear button to clear all the input data and a message box to warn if any of the fuel, baggage or total wt restrictions are exceeded. But I like your idea of showing the low fuel point ( rather than just deleting the fuel as I do) I think I will steal this idea :) As I said in my previous post, it would be very unusual for me to have more wt in the back than the front, ( which is likely to test the aft cg ) but I could understand with club seating, the pax might be more inclined to want to ride in style, instead of up the front.with the driver. I notice even your 6 seater would struggle to take 4 adults with full fuel. ( the adutls would have to weigh on average less than 180 lbs - counts out a lot of my friends! Terry ppl downunder |
d&tm wrote:
Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? The Bonanza is the big example that comes to mind. The moment of the Fuel is forward of the main spar and as you burn your fuel off, the CG moves aft. If you have the 5th and 6th seats filled or have lots of aft baggage, you can end up aft of limits, which can bite when you are low/slow on approach. Dave |
Only when I fly naked.
tom Jay Beckman wrote: "tom" wrote in message oups.com... I weigh 170, so the only ballast I carry is around my ass. 8^) tom "Does this airplane make me look fat...?" ;O) Jay B |
![]() "john smith" wrote in message ... d&tm wrote: snip At some point, the cg moves out of the envelope (the ability of the horizontal stabilizer to provide sufficient lift). Aft c.g. violation makes the aircraft unstable in pitch. Forward c.g. violation is an ability of the stabilizer to control pitch, i.e. bring the nose up. Danny Deger |
As the wife and kids move around, I do need to re-trim -- but I haven't
casually noted a significant speed increase. I'll have to recruit some 'hefty' passengers and perform the experiment (our last experiment was for my son's 5th grade science class when we capped empty water bottles at various altitudes and he showed the class how much the bottles collapsed as we returned to the ground). Morgans wrote: "Steve Schneider" wrote Flying this plane with club seating does allow for some interesting weight shifting when passengers (wife and kids typically) swap seats in flight. You definitely do feel the change, and as such I always keep in mind which passengers sit in which seats. Imagine the above loading with the rear passengers (2x180lb) in the center row of seats and the rear seats empty. Once airborne they decide they don't like to fly 'backwards' in the club seating and 'help themselves' to the the empty rear seats. Suddenly we go from a very comfortable CG to a precariously aft CG. Not a situation one generally needs to worry about in 2 and 4 seat airplanes. With the passengers putting the CG at the most aft limits, do you notice any increase in speed, with the same power and prop settings? I would think the aft CG would take the downward lift away from the horizontal, and pick up some speed, but I don't know. It would seem like the ideal experiment; to be able to quickly change the CG with no changes in air density, power, or any other type of changes. |
d&tm wrote:
Steve, thanks for that. I have made up similar spreadsheets for the Warrior and C172 , but perhaps a little fancier in that they are set up to select different reg numbers from a drop down menu, with the specific aircraft data ( useful for paupers like me who dont own their own plane), a clear button to clear all the input data and a message box to warn if any of the fuel, baggage or total wt restrictions are exceeded. But I like your idea of showing the low fuel point ( rather than just deleting the fuel as I do) I think I will steal this idea :) As I said in my previous post, it would be very unusual for me to have more wt in the back than the front, ( which is likely to test the aft cg ) but I could understand with club seating, the pax might be more inclined to want to ride in style, instead of up the front.with the driver. I'll have to dust off an Excel manual and polish up my spreadsheets with some of your cool features! :-) I notice even your 6 seater would struggle to take 4 adults with full fuel. ( the adutls would have to weigh on average less than 180 lbs - counts out a lot of my friends! Terry ppl downunder True, though full tanks would far exceed the typical passenger's bladder range. Half tanks would still yield over 2 hours of flying time with reserves (close enough to the upper end of the random passenger's comfort limit per my experience) and let you carry a 5th person plus a bit of baggage some 300+nm. The Lance is by far the most practical aircraft I've ever had the pleasure to fly. As a coincidental but random trip example, we're heading off tomorrow to Santa Barbara with a full load of 6 people to make good on a trip we donated for an event at a local community college. This will be my wife and I plus 4 people who won the drawing. Fortunately, the passenger weights are a bit on the low side, so with partial fuel we can fly the ~300 mile round trip with fuel to spare. It always seems like our passenger load works out pretty well. One of the advantages of being a sole owner/operator is that you don't have to worry about the prior pilot/partner/club member topping off the tanks when you need to fly with partial fuel. I'd sure hate to drain 40 or 50 gallons before a flight because someone forgot _not_ to top off, or perhaps the prior scheduled flight didn't occur so the tanks are still full from the flight before that one. Steve |
You might also want to take a look at the one I did for our club. http://www.flying20club.org/planes8237B.html I did the "new style" spreadsheet a little differently from the others, take a look at the "how the spreadsheet works" part of the instructions tab. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message et... I'll have to dust off an Excel manual and polish up my spreadsheets with some of your cool features! :-) You might also want to take a look at the one I did for our club. http://www.flying20club.org/planes8237B.html I did the "new style" spreadsheet a little differently from the others, take a look at the "how the spreadsheet works" part of the instructions tab. Jose -- Jose, I like the way yours does flight envelopes for individual aircraft. I have separate sheets for warrior and C172 with the ability to select individual aircraft. my understanding was that different planes of the same type have different wts but the same envelope. I will post a link to my own spreadsheets, when I work out how to do that. can you explain how to do it - or point me to some help? thanks terry |
#29
Thank you. I did give it a bit of thought. ![]() my understanding was that different planes of the same type have different wts but the same envelope. This generally true; it can be trivially true by defining "planes of the same type" as requiring the same envelope. Marketers will make a plane of a different type if it's painted a different color, but company aircraft designers who deal with the FAA want all their planes to be the same type so they can piggyback on the old type certficates. Also, "type" and "name" are not to be confused, and "type" also has a specific FAA meaning, within which I believe it is possible to have a different envelope, uncommon though it may be for spam cans. But I don't know whether you mean "type" colloquially or regulationally. Confused yet, or should I try harder? ![]() I will post a link to my own spreadsheets, when I work out how to do that. can you explain how to do it - or point me to some help? If you go to a web site that has any such link, you can "view source" and see how they did it. As long as they don't use the mess of scripts that is becoming popular these days, it will be pretty clear. Step one: create the spreadsheet, set it up the way you want it to be seen when it loads (what tab you're on, what cell is active...), and then upload it to your web server, making note of where you put it. Step 2: put a link on the page which refers to this file. The format for such a link is the same as any other link, to wit: an open angle bracket, the letter 'a', a space, the letters "href", an equal sign, the target file name (enclosed within double-quotes), including the path if necesesary, a closing angle bracket, (all the aforementioned "begins" the anchor tag), the text you want to =be= the link (it will be blue and underlined by default in the browser), and then to "end" the anchor tag, an opening angle bracket, a forward slash (usually below the question mark on a keyboard), the letter 'a', and a closing angle bracket. I'm being long winded because some newsreaders will grab onto anything that looks like HTML and try to interpret it instead. Step III: Upload that page to the web site. Note that the client computer (the one that clicks on the link) will need to have an excel-compatible reader to be able to work with the file, and that some browsers will display the spreadsheet within their own window, others will simply call Excel to do the work. You can't control that. Alas, neither can you control whether the user sees your latest update to the spreadsheet, or their own, old, cached copy (or even a cached copy along the way). That's why I have the caution to empty the cache before proceeding. It's the way the web is designed - no way around it. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
"Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 03:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
