in my PPL training it was drummed in to me the importance of always doing
the w & b calcs with the fuel you were taking and also the zero fuel case. I posted sometime ago that with the Warriors I flew it was impossible to go outside the w & b envelope by burning fuel. I have just finished my transition to the C172 and have extensively investigated different loading scenarios and found exactly the same thing, at least with this N model I am flying. Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? Terry PPL downunder |
"d&tm" wrote in message
... [...] Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? Sure. Any airplane in which the CG moves as fuel is burned has that potential, depending on what other aspects of loading exist. I haven't looked at the 172 case recently. Possibly due to weight restrictions for baggage or seats you can't load it close enough to the critical end of the CG range with full fuel for the CG to move outside the range by using up fuel? I don't know off the top of my head. What I do know is that I own a single-engine airplane (Lake Renegade) that can wind up with the CG out of range after fuel has burned. I also know from my friends who own Bonanzas that at least some models of Bonanza have a similar issue. I am sure there are a number of smaller single-engine airplanes that have the same requirement to pay close attention to weight & balance. Of course, there's a difference between the potential for problems generally, and the potential for problems with specific loadings. Generally speaking, I've found that the issue of CG moving out of range with fuel burn still only happens in specific loading configurations. For example, in my airplane the issue is most pronounced when the airplane is heavily loaded to start with, and when that weight is mostly up front. Even at higher weights, there are loading configurations that are generally assured to not wind up outside the CG range as fuel burns. As long as you've done enough W&B calculations to check the various configurations and be very familiar with how the CG moves according to loading and fuel, then to some extent it's not necessary to do a full W&B calculation for every flight, assuming you've otherwise ensured you're not overweight and have a loading configuration for which fuel burn isn't an issue. But, it's certainly not safe to say that one need not worry about fuel burn for single-engine airplanes, even if you limit that statement to the smaller ones (two- and four-seat). Pete |
![]() "Peter Duniho" wrote in message ... "d&tm" wrote in message ... [...] Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? Sure. Any airplane in which the CG moves as fuel is burned has that potential, depending on what other aspects of loading exist. Both the Warrior and the C172 c of g moves forward with fuel burn but so does the allowable limit, at the same or greater rate, which is why it is not possible to go outside the envelope under any loading conditions. I haven't looked at the 172 case recently. Possibly due to weight restrictions for baggage or seats you can't load it close enough to the critical end of the CG range with full fuel for the CG to move outside the range by using up fuel? I don't know off the top of my head. What I do know is that I own a single-engine airplane (Lake Renegade) that can wind up with the CG out of range after fuel has burned. I also know from my friends who own Bonanzas that at least some models of Bonanza have a similar issue. I am sure there are a number of smaller single-engine airplanes that have the same requirement to pay close attention to weight & balance. Of course, there's a difference between the potential for problems generally, and the potential for problems with specific loadings. Generally speaking, I've found that the issue of CG moving out of range with fuel burn still only happens in specific loading configurations. For example, in my airplane the issue is most pronounced when the airplane is heavily loaded to start with, and when that weight is mostly up front. Even at higher weights, there are loading configurations that are generally assured to not wind up outside the CG range as fuel burns. As long as you've done enough W&B calculations to check the various configurations and be very familiar with how the CG moves according to loading and fuel, then to some extent it's not necessary to do a full W&B calculation for every flight, assuming you've otherwise ensured you're not overweight and have a loading configuration for which fuel burn isn't an issue. this is basically why I do the analysis, to break it down to simple rules that will not require me to have to do the c of g calcs each time. conclusion with the C172N is that, with the weight restrictions satisfied 1. it is impossible to get c of g too far forward. 2. the only way to have c of g too far back is with more weight in back seat than front. ( most unlikely situation for me) 3. it is impossible to go outside by burning fuel. So my simple rule becomes stay within the wt constraints and do a c of g check only if I want more wt in the back seat than the front. - which is likely to be never. But, it's certainly not safe to say that one need not worry about fuel burn for single-engine airplanes, even if you limit that statement to the smaller ones (two- and four-seat). I certainly wouldnt assume that without doing the same analysis on the particular aircraft. It seems to me that the aircraft I have referred to ( warrior and C172N) are probably designed so that fuel burning will not cause an adverse c of g . I would also be curious to know if other models of C172 or the higher performacne C177, C182 C206, C210 follow the rules I outlined above. Excuse my ignorance but I hadn't heard of a Lake Renegade, but I did do a google and note that it is a beautiful looking amphibious aircraft whch obviously has some specific design characeristics for its intended application, namely an engine above and behind the cabin, which makes it a little different from the aircraft I am likely to fly, but I take your point that fuel burning may be an issue in some small planes. terry PPL downunder |
that will not require me to have to do the c of g calcs each time. Try this - start at the bottom of the envelope, and pretend that each corner represents a zero fuel loading. Then add fuel and see where you end up. Draw that line on the envelope. The inner envelope is defined as the the most restrictive envelope from all these lines and the existing envelope. So long as your loading (with fuel) is within this inner envelope, you'll be ok to zero fuel. (at least w&b wise. ![]() Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
d&tm wrote:
in my PPL training it was drummed in to me the importance of always doing the w & b calcs with the fuel you were taking and also the zero fuel case. I posted sometime ago that with the Warriors I flew it was impossible to go outside the w & b envelope by burning fuel. I have just finished my transition to the C172 and have extensively investigated different loading scenarios and found exactly the same thing, at least with this N model I am flying. Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? Terry Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. As fuel is burned, the weight ahead of the spars decreases while the weight behind the spar remains the same, hence the cg moves aft. At some point, the cg moves out of the envelope (the ability of the horizontal stabilizer to provide sufficient lift). Piper PA32's will can also develope this situation. Cessna's seem to have a broader range. You have to look at each aircrafts envelope. Van's tandem seat RV-4's had a bad string of fatal accidents until the word got out and builders became more aware of the potential danger. |
![]() john smith wrote: Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. In my 64 S35 all weight in the plane is behind the fuel. The fuel is at 75 and the front seats are at 85. Rear seats 121 and baggage at 150. |
![]() Newps wrote: john smith wrote: Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. In my 64 S35 all weight in the plane is behind the fuel. The fuel is at 75 and the front seats are at 85. Rear seats 121 and baggage at 150. Any idea where front seats are in the 36 series? |
Same place. Although the fuel is the same arm as the front seats in the 36.
john smith wrote: Newps wrote: john smith wrote: Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. In my 64 S35 all weight in the plane is behind the fuel. The fuel is at 75 and the front seats are at 85. Rear seats 121 and baggage at 150. Any idea where front seats are in the 36 series? |
![]() "john smith" wrote in message ... d&tm wrote: in my PPL training it was drummed in to me the importance of always doing the w & b calcs with the fuel you were taking and also the zero fuel case. I posted sometime ago that with the Warriors I flew it was impossible to go outside the w & b envelope by burning fuel. I have just finished my transition to the C172 and have extensively investigated different loading scenarios and found exactly the same thing, at least with this N model I am flying. Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? Terry Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. As fuel is burned, the weight ahead of the spars decreases while the weight behind the spar remains the same, hence the cg moves aft. At some point, the cg moves out of the envelope (the ability of the horizontal stabilizer to provide sufficient lift). Piper PA32's will can also develope this situation. Cessna's seem to have a broader range. You have to look at each aircrafts envelope. Van's tandem seat RV-4's had a bad string of fatal accidents until the word got out and builders became more aware of the potential danger. It is true that the CG moves aft with fuel burn on all of the 2 place Van's designs. It is also true that depending on the individual aircraft and the loading that you could run the CG beyond the aft limit. You certainly can in my RV-6. That said, please do some fact checking before you conjure up a "bad string of fatal accidents" for RV-4's due to CG issues. Didn't happen. There was one accident in the NTSB database between 1980 and today where CG was listed as a factor... Not jumping your kimchee or anything, but facts are facts, and making 'em up (or remembering 'em incorrectly) isn't a good idea when safety is at issue. KB |
(or remembering 'em incorrectly) isn't a good idea when safety is at issue. Kyle, I have personal knowledge of four, and first hand reports from others in the RV community. The rash of accidents happened in the late 80's/early 90's. They were the basis for Van revising the aft cg limit on RV-4's Just because the NTSB doesn't list it doesn't mean they didn't happen. I also know of other NTSB final reports where the report did not match the facts. You have to understand that the NTSB does not investigate all accidents. In most cases, they take the information from another agency and synthesize the results. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
"Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 03:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
