Procedure for calculating weight and balance
Old January 6th 07, 09:40 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Default Procedure for calculating weight and balance
Mxsmanic,
which nobody seems to care about except me)
Ah, time to take a clue, isn't it?
Why would "neutral trim" be important? For that matter, what would it
be?
What you get is a range of allowable CGs, which often depends on total
weight. This all has to do mostly with elevator authority. Trim (as in
the trim wheel) is not really important, trim is just a tool to relieve
the pilot. Trim as in weight distribution, well, see above.
Once you've figured this out, ponder why an aircraft will be faster or
consume less fuel if the CG is as aft as possible.
Thomas Borchert (EDDH)
Old January 6th 07, 10:51 PM posted to rec.aviation.piloting,rec.aviation.student
new_CFI
Mxsmanic wrote in
Stubby writes:
also check faa.gov AC-61-238 "Pilots' Handbook of Aeronautical
Knowledge" will answer all your questions (I hope).
Section 12 explains the principles behind it, but it didn't actually
say how to calculate the center of gravity, or how to achieve neutral
trim (which nobody seems to care about except me).
as you burn fuel your CG changes. Your 'neutral trim' wont last. read
about the benifits of forward/aft CG's.
Now if your doing areobatics I believe the placement of the CG becomes even
more importent (all I have done is spins) and my guess is that a 'neutral
cg' is not the best place?
Old January 6th 07, 08:15 PM posted to rec.aviation.piloting
Scott Skylane
Mxsmanic wrote:
/snip/ Can someone provide me
with a pointer to an explanation of the procedure on the Web
somewhere?
This site has good information:
http://www.amishrakefight.org/gfy/
Happy Flying!
Scott Skylane
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
