Oil on the windshield. What would you do?
Old January 28th 07, 02:25 AM posted to rec.aviation.piloting
BT
Default Oil on the windshield. What would you do?
touch nothing, divert to the nearest airfield,
monitor oil temperature and pressure, low oil levels will cause temperature
to increase,
you already know you are loosing oil but at what rate?
low oil pressure might mean the oil sump is about empty.
it would take a lot of oil for that to happen, you may not be able to see
out the front then
but remember that not all the oil will be on the windshield, some will be on
the belly etc
remain high for glide if the engine does quit
if there is a tower where you are going, call them early and request
priority, tell them you suspect an engine oil loss problem.
if it is only a uncontrolled field, call and let them know early, just in
case you have to land in that field one mile short, they will be looking for
you
the oil will "streak" in the slip stream
changing power prop settings "even to fine" will cause the seals in the prop
hub to flex, why move them more than you have too.
BT
"Tony Cox" wrote in message
Here's a question that anyone with a single
engine, constant speed prop might have to
deal with sometime.
You're cruising along happily when suddenly
oil drops start appearing on the windshield. There
is no "bang" or anything else to indicate catastrophic
failure. The nearest airport is out of gliding range.
What do you do?
I'd assume symptoms were caused by some prop seal
failure. I'd go to fine pitch (to minimize further oil
loss) & then reduce RPM to where I could still maintain
altitude (to further minimize oil loss, and to minimize
structural damage if the prop were about to disintegrate)
while heading for the nearest airport.
Can anyone think of a better response?
Old January 28th 07, 12:31 PM posted to rec.aviation.piloting
B A R R Y
I've heard a statistic tossed around at Wings seminars stating that
most engine failures occur during a change or adjustment. Guest
engine experts seem to always agree not to touch anything if it's
still running and high confidence of the exact problem isn't
available.
I wish I could find the detailed information. Has anyone else heard
this?
Old January 29th 07, 12:22 AM posted to rec.aviation.piloting
BT
I've heard the same thing Barry.. don't know where the stats are found
BT
"B A R R Y" wrote in message
available.
this?
Old January 29th 07, 01:56 AM posted to rec.aviation.piloting
Ron Natalie
BT
No supporting stats. Lycoming has researched it and it's a myth.
You can find the info in their tech briefs on their website.
Old February 4th 07, 08:07 AM posted to rec.aviation.piloting
Peter Dohm
BT
I heard it "around the airport" c1980. If there are stats, they are old.
About all I can add is that one of the locals had the engine drop to idle at
the first power reduction--probably at the crosswind turn--the clevis
connecting the throttle to the carburetor came loose. IIRC, he made a
successfull landing on the airport.
Old January 30th 07, 04:49 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Sun, 28 Jan 2007 12:31:51 GMT, B A R R Y
available.
Which would seem to indicate that if you can consistantly fly with
just two engine settings (full power and idle) you are less likely to
get unwelcome engine related surprises... grin
Old January 30th 07, 05:04 PM posted to rec.aviation.piloting
B A R R Y[_2_]
available.
Like the WW1 guys? G
Old January 28th 07, 02:02 PM posted to rec.aviation.piloting
Ash Wyllie
BT opined
Because the governor is constantly changing the blade angle, and thus
aggravating the leak. Going to fine pitch means that the blades will move
only once more for the rest of the flight.
-ash
Cthulhu in 2007!
Why wait for nature?
Old January 28th 07, 11:46 PM posted to rec.aviation.piloting
Jim Macklin
Prop seals leak because people use the blades as tow-bars on
the ground. Front crankcase seals leak because of blocked
case vents.
In-flight, centrifugal forces make the pressure on the seals
at right angles, does not cause leaks.
"Ash Wyllie" wrote in message
| BT opined
angle, and thus
blades will move
| -ash
| Cthulhu in 2007!
Ron Natalie
case vents.
That's a gross oversimplification. As I said, the old
Hartzell prop seals go because they are life limitted to
a few years. They aren't even anywhere near the blades.
While there's grease up there in the blade hubs, there
ain't any engine oil.
Had a crankcase seal blow out because the case was misassembled.
Had nothing to do witht he vents.
What?
OOPS! Got contact cement on the windshield Mike Rapoport Owning 12 November 13th 04 11:13 PM
Windshield Antenna Kits Scrabo Piloting 2 July 12th 04 04:58 PM
windshield wipers tony roberts Owning 8 June 1st 04 02:45 AM
Arrgh! I may have scratched my windshield! Peter R. Owning 7 April 28th 04 07:58 AM
Windshield sealant Mike Noel Owning 10 October 2nd 03 01:04 AM
