#21
![]() "Peter R." wrote in message ... My turbo Bo uses 15.5 gph in the warm summer air and 17.5 gph in the very cold winter air. Your Turbobo? |
![]() "Casey Wilson" wrote in message news:7RJxh.1999$5U4.453@trnddc07... "Matt Barrow" wrote in message In colder weather, your engine CAN develop more power. Power = Fuel. In cold weather you can go FASTER because your engine can develop more POWER. For a given engine, faster means less MPG. Let's beat this dog some more. Going faster also means less time required to get to the destination. Considering that as pilots we are more interested in fuel consumption, gallons per hour, than MPG is it more economical to fly faster/higher? Let's presume a 250NM trip at 10Kft [for the nitpickers, the wind is nil both ways]. According to the POH for the C-172M that I fly the trip will take 2.8 hours and burn 15.4 gallons at 89 KTAS. Shove the throttle to the firewall and the trip will take 2.1 hours and burn 15.9 gallons at 119 KTAS. Your TAS increases 33%, but your Fuel Flow increases only 4%? My fuel flow doubles between Econ Cruise and Max Cruise (9.4 gph/172kts vs 18.4gph/205kts). Check your data. |
On 2/6/2007 9:38:35 AM, "Matt Barrow" wrote:
"Peter R." wrote in message ... My turbo Bo uses 15.5 gph in the warm summer air and 17.5 gph in the very cold winter air. Your Turbobo? That be the one. -- Peter |
![]() "Peter R." wrote in message ... My turbo Bo uses 15.5 gph in the warm summer air and 17.5 gph in the very cold winter air. Temp 36 today at 4500. 190 MPH indicated on 14.5 gph in my S35 at 23/2500. Trues out to 200 mph even. Gotta love six new Milleniums. Don't need no stinkin' turbo. |
On 2/6/2007 2:33:12 PM, Newps wrote:
Temp 36 today at 4500. 190 MPH indicated on 14.5 gph in my S35 at 23/2500. Trues out to 200 mph even. Gotta love six new Milleniums. Don't need no stinkin' turbo. With six new Milleniums (well, OK, they now have about 300 hours on them) and a turbo I see speeds of 220 mph at 15.5 gph (2500/WOT and LOP by 70 degrees) in the summer months at a cruise of 15,000 feet. Don't need no stinkin' multi. ![]() -- Peter |
I'll assume 220 mph is a true airspeed as that would be well into the
yellow. I could lean to 14 gph but my indicated goes down by 8-10 mph. At typical summer temps I'll lose about 5-7 mph true. Peter R. wrote: On 2/6/2007 2:33:12 PM, Newps wrote: Temp 36 today at 4500. 190 MPH indicated on 14.5 gph in my S35 at 23/2500. Trues out to 200 mph even. Gotta love six new Milleniums. Don't need no stinkin' turbo. With six new Milleniums (well, OK, they now have about 300 hours on them) and a turbo I see speeds of 220 mph at 15.5 gph (2500/WOT and LOP by 70 degrees) in the summer months at a cruise of 15,000 feet. Don't need no stinkin' multi. ![]() |
On 2/6/2007 3:24:46 PM, Newps wrote:
I'll assume 220 mph is a true airspeed as that would be well into the yellow. Sorry, yes - that is true airspeed. Indicated is usually down around 145-150 or so at that density altitude. -- Peter |
![]() "Matt Barrow" wrote in message ... "Casey Wilson" wrote in message news:7RJxh.1999$5U4.453@trnddc07... Let's presume a 250NM trip at 10Kft [for the nitpickers, the wind is nil both ways]. According to the POH for the C-172M that I fly the trip will take 2.8 hours and burn 15.4 gallons at 89 KTAS. Shove the throttle to the firewall and the trip will take 2.1 hours and burn 15.9 gallons at 119 KTAS. Your TAS increases 33%, but your Fuel Flow increases only 4%? My fuel flow doubles between Econ Cruise and Max Cruise (9.4 gph/172kts vs 18.4gph/205kts). Check your data. Copied right out of the POH for the 172M, 1976 Skyhawk. Figure 5-7 Cruise Performance, pg 5-16. Got a fax number? |
#29
Peter R. wrote:
On 2/6/2007 2:33:12 PM, Newps wrote: Temp 36 today at 4500. 190 MPH indicated on 14.5 gph in my S35 at 23/2500. Trues out to 200 mph even. Gotta love six new Milleniums. Don't need no stinkin' turbo. With six new Milleniums (well, OK, they now have about 300 hours on them) and a turbo I see speeds of 220 mph at 15.5 gph (2500/WOT and LOP by 70 degrees) in the summer months at a cruise of 15,000 feet. Don't need no stinkin' multi. ![]() Until the single quits. :-) Matt |
#30
![]() "Casey Wilson" wrote in message news ![]() Let's presume a 250NM trip at 10Kft [for the nitpickers, the wind is nil both ways]. According to the POH for the C-172M that I fly the trip will take 2.8 hours and burn 15.4 gallons at 89 KTAS. Shove the throttle to the firewall and the trip will take 2.1 hours and burn 15.9 gallons at 119 KTAS. Your TAS increases 33%, but your Fuel Flow increases only 4%? My fuel flow doubles between Econ Cruise and Max Cruise (9.4 gph/172kts vs 18.4gph/205kts). Check your data. Copied right out of the POH for the 172M, 1976 Skyhawk. Figure 5-7 Cruise Performance, pg 5-16. Got a fax number? Yeah, but I'm not going to post it on the internet. Can you scan it and send a JPG file? Also, I misread your numbers (in terms of measures) - you go from 5.5 GPH, to 7.6 GPH. That's the way I'm used to calculating fuel loads. I'd still like to see the numbers, but my example (2X fuel flow for 18% better TAS is not too far from your 33% increase in TAS for 40% increase in FF. Getting upwards, then over, 200kts makes a big dent in fuel use. Another thing to look at it is this - it often doesn't pay to divert a long way to save a few buck on gas at a cheaper FBO. AirNav has this option on their fuel planner. |
Minimum fuel | Denny | Piloting | 31 | July 7th 06 02:37 AM |
Starting new C172s | navghtivs | Piloting | 76 | September 10th 05 09:33 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
fuel consumption Jabiru 3300 | John | Home Built | 10 | August 10th 05 07:22 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
