Just a comment... Last weekend I had to move a full load, five seats
and baggage, across three states with multiple stops... This required a light fuel load to make the W&B work out... For those who have not seen my postings on fuel before, I am a fanatic about not ever going into the last hour of fuel, for any reason... I have even, in the distant past, landed 20 minutes from home for gas to avoid busting my own one hour minimum rule... Given that the current bird holds six hours of fuel and my bladder range is four hours, it has been many years since I had less than two hours in the tanks... Anyway, this time the significant other was breathing down my neck about completing the flights on a fixed schedule... After beating up on my whiz wheel for 20 minutes it became clear I would have to suspend the fuel rule for the first time in decades, and go 15 minutes into the fuel reserve because there 'aint no' gas station in the middle of Lake Erie... I measure fuel by the clock and use the fuel gauges only as a 'how goes it' indicator, though I know from experience the gauge on the main tank is on the money... So, there we are going across Lake Erie on a gorgeous sunny day as the needle just touches the 1/4 mark which means exactly 60 minutes of fuel left.. The count down timer I normally use for approaches agrees with the gauge... What didn't agree was my pucker factor... Amazing what your nervous system can do when it wants your attention... In spite of my intellectual knowledge that I had 15 minutes until landing with 60 minutes of fuel on board, my parasympathetic nervous system threw a tantrum... I got a hollow in the pit of my stomach.. My palms got sweaty... I had that, 'something bad is going to happen' sensation... OTOH, the engines continued to do the Lycoming four banger, shake, rattle, and roll... They weren't nervous... And the flight ended with the usual squeak of tires on the concrete at Port Clinton... So what is the point of this post? Well not much, except rules can be broken ( NASA just did) if done carefully, but it still feels bad... It will be a long time before I break the 1 hour rule again, significant other not withstanding... denny |
Denny wrote:
For those who have not seen my postings on fuel before, I am a fanatic about not ever going into the last hour of fuel, for any reason... Not a bad rule. You won't get every bit of utility out of your airplane, but you're also not likely to ever run out of fuel. I think that's a perfectly reasonable way to fly. Anyway, this time the significant other was breathing down my neck about completing the flights on a fixed schedule... Don't let your SO talk you into breaking rules. Lie if you have to. Fudge your calculations to make it look like going non-stop will mean landing with 15 minutes reserve instead of 45. Or zero. Or halfway through the flight tell her you must be hitting unexpected headwinds because you keep hitting checkpoints further and further behind your flight planned estimates. Or that you've *really* got to take a leak NOW and you're not going to make it to your destination without wetting your pants. Once you're on the ground, you might as well take on another 10 gallons. If you really are committed to breaking a rule, I'd rather take on an extra 30 minutes of fuel and take off overgross. You didn't say what you're flying, but a "4-banger" is probably burning no more than 10 gph in cruise; 30 minutes is 30 pounds of fuel. Nobody ever died taking off 30 pounds overweight, but people have died being 3 pounds of fuel short of making the runway. Did you try planning different power settings? Cruising at 55% vs. 75% power can make a huge difference in range (especially with a tailwind). |
"Larry Dighera" wrote in message
... Don't let your SO talk you into breaking rules. Lie if you have to. There's no need to lie. Just assume your authority as PIC, and do what's right. That ignores the larger picture. Personally, I'd be incredibly disappointed if I found that I had to lie to my spouse in order to get her to be comfortable with my decisions with respect to maintaining the safety of a flight. However, from many discussions with other people, including many close friends, I recognize that, unfortunately, my situation is uncommon. Many people are in relationships, and quite happily so, where they rely on deception at times in order to keep things going smoothly. When you write "there's no need to lie", you are no longer talking about aviation. You are making a statement about the person's relationship with his SO, one that may or may not be true depending on the actual nature of the relationship (an aspect of the issue that I doubt you have personal knowledge of, unless you are their couple's counselor, or a very close friend, or something like that). I would say that your statement is more accurate when talking about passengers generally. There is less risk in simply making an outright "no" statement when not dealing with an intimate relationship. But when dealing with a spouse or similar, things are more complicated and lying may be the only way to ensure the safety of the flight *and* the integrity (such as it may be in such situations) of the relationship. All that said, I would also say that there is generally no need to educate one's passengers, spouse or otherwise, on the finer details of the regulations or of the flight planning details. If they don't know that 30 minutes during the daytime is the legal minimum, or if they don't know the precise fuel load and fuel burn, it's easy enough to truthfully say, simply, "we can't make this distance safely without stopping for fuel along the way". How often this will work obviously depends on the individual passenger, how much interest they take in the flight planning and execution, and how willing they are to accept the pilot's definition of "safely". I have also found that, even if the passenger does wind up taking an interest and looking into the details later, it still allows me to execute the flight as I see fit, delaying arguments until such time when they are rendered moot. After the fact, if there are still questions, I am more easily able to address them without getting bogged down in "but I really want to make this flight!" emotional issues. Using this method, I have yet to have a single passenger get upset with me regarding any decision I've made with respect to flying. Or at least, as far as I know. And that includes flights that were simply cancelled, as well as having to leave one person on the ground while I took two others sightseeing, due to balance considerations (granted, in that case, the guy was an unexpected tag-along, invited by my passengers and not me). All of my passengers have recognized my authority as pilot in command and while they may ask questions regarding why I make decisions the way I do, they have never complained about my right to make those decisions, or about the outcome of such decisions. Perhaps most of my passengers would be just as cooperative if I filled them in on all the little details, but some of them may not have been. I've found it's simpler, and easier to stick to my standards, when the passengers are volunteered information only on a "need to know" basis. I encourage interest, and do answer questions truthfully when asked, but I don't go out of my way to explain every little detail, and that includes not going out of my way to differentiate between issues that are regulatory in nature and issues that are my own personal safety requirements. (Of course, with the responsibility to ensure the safety of the flight, the pilot's own personal standards could be considered regulatory as well, I suppose ![]() Pete |
On Wed, 5 Jul 2006 10:57:02 -0700, "Peter Duniho"
wrote in :: When you write "there's no need to lie", you are no longer talking about aviation. You are making a statement about the person's relationship with his SO, one that may or may not be true depending on the actual nature of the relationship. Well, perhaps it's just me, but if I have to lie to my SO to assert my command authority as PIC, I would be looking for another SO pronto. |
... Well, perhaps it's just me, but if I have to lie to my SO to assert my command authority as PIC, I would be looking for another SO pronto. Me too. But like I said, that's not an aviation issue, and since you don't know the specifics of the relationship in question, you can't make a blanket statement about what "works" for them. |
Roy,
If you really are committed to breaking a rule, I'd rather take on an extra 30 minutes of fuel and take off overgross. Good advice, IMHO. However, don't make it much more than that. -- Thomas Borchert (EDDH) |
extra 30 minutes of fuel and take off overgross. Those are different kinds of rules. Breaking a personal minimum should be treated differently from breaking an FAR. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
Jose wrote: If you really are committed to breaking a rule, I'd rather take on an extra 30 minutes of fuel and take off overgross. Those are different kinds of rules. Breaking a personal minimum should be treated differently from breaking an FAR. Jose Would you rather be legal and dangerous or illegal and safe? Your choice. |
I see your point. However, the question is whether setting a conservative (fuel) minimum and then deciding for this flight to exceed it, remaining within FAA rules, does not make one unsafe. Becoming a test pilot by exceeding aircraft (weight) limitations is more likely to, IMHO. But each case is different. One can make personal minima as stringent as one wants (two hour fuel reserve, for example), but the FAA and the aircraft manufacturers probably do not (the manufacturers want to market the aircraft's capability, after all) Not all that is illegal is safe, and not all that is legal is unsafe. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
faith in the fuel delivery infrastructure | Chris Hoffmann | Piloting | 12 | April 3rd 04 01:55 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
