On 03/02/07 08:04, Steven P. McNicoll wrote:
On Mar 2, 9:15 am, Mark Hansen wrote: What's VIFNO? Google says: "Void IF Not Off by". FAAH 7340.1 says CVINO You asked what he meant and I told you. Sheeesh. |
On Mar 2, 10:35 am, Mark Hansen wrote:
On 03/02/07 08:04, Steven P. McNicoll wrote: You asked what he meant and I told you. Sheeesh. I didn't ask YOU what he meant. What qualifies you to speak for someone else? Sheeeeeesh. |
On Mar 2, 5:11 am, "Steven P. McNicoll"
wrote: On Mar 1, 11:51 pm, wrote: Recently I tried to depart from an non-tower airport that has no instrument approach procedure, and hence no instrument departure. I was told that I could not get a clearance on the ground, even with VIFNO etc., and that I would have to depart VFR and pick my clearance up while airborne. The recommendation made to me by both TRACON and local FSDO for departing IFR with a low ceiling was to get a special VFR clearance into the towered airport 6 miles away [which has an approach and then depart IFR from there. My question is, if I take responsibility for staying away from the rocks [assume a low ceiling, above the tops of small hills, but below minimum vectoring altitude], shouln't I be able to get a clearance on the ground? What's VIFNO? Did they say why they couldn't issue a clearance while you were on the ground? It's not prohibited by FAAO 7110.65. VIFNO = Void if not off by [sorry- old habits...] Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. I heard from both the controller and local pilots that zero-zero departures used to be permitted until about 2 years ago and since then clearances while on the ground have been unavilable. Now the airport is only 10 NM SE of Ontario...so I'm guessing that my IFR departure off Flabob negatively impacts their inbounds into ONT until they have identifed me on radar or I'm through the MVA. I have suspected this is the funcamental I'm not permitted a clearance and that until 2 years ago there may have been a Letter of Agreement between ONT tower and SoCal departure that permitted Flabob IFR departures. If so, am I not getting a raw deal on "first come, first, served"? BTW, the FSDO guy was the least helpful: "No instrument departure, no clearances on the ground." When I protested that this was clearly in error he just repeated what he said, adding some impatient attitude. That was the end of that conversation. |
On Mar 2, 8:41 am, Sam Spade wrote:
wrote: Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. Runway 24 takes you into the KRAL Class D almost immediately. I am sure no one likes that when they can't see you. Runway 6 is pointed towards terrain that causes the MVA to rise to 4000 quite close-in. The airport is in a terrible location both airspace and terrain-wise for IFR procedures. If you takeoff on 6 not only do you have a terrain problem there is an issue of the Ontario Class C with a floor of 2700 in that area, below any MVA. The issue witih KRAL is a non-issue as far as my question is concerned. There are many cases in which multiple towered airports are near each other and you can still get an IFR departure; both Northern and Southern California have many examples: SFO and SQL, HWD and OAK, SJC and RHV, HHR and LAX. The TRACON works it out; that is part of their job. Regarding terrain: I'm talking about a departure off 24 with a ceiling high enough to see and avoid all obstacles which, in any event, is not or should not be ATC's issue. I don't think either of these concerns is the cause of the issue here. |
On Mar 2, 10:41 am, Sam Spade wrote:
Runway 24 takes you into the KRAL Class D almost immediately. I am sure no one likes that when they can't see you. Runway 6 is pointed towards terrain that causes the MVA to rise to 4000 quite close-in. The airport is in a terrible location both airspace and terrain-wise for IFR procedures. If you takeoff on 6 not only do you have a terrain problem there is an issue of the Ontario Class C with a floor of 2700 in that area, below any MVA. None of which precludes the issuance of an IFR clearance from RIR. |
On Mar 2, 10:41 am, Sam Spade wrote: Runway 24 takes you into the KRAL Class D almost immediately. I am sure no one likes that when they can't see you. Runway 6 is pointed towards terrain that causes the MVA to rise to 4000 quite close-in. The airport is in a terrible location both airspace and terrain-wise for IFR procedures. If you takeoff on 6 not only do you have a terrain problem there is an issue of the Ontario Class C with a floor of 2700 in that area, below any MVA. None of which precludes the issuance of an IFR clearance from RIR. I didn't say that it necessarily does. I can also understand why SoCal and KRAL tower don't want to do it. |
On Mar 2, 9:53 am, wrote:
Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. I heard from both the controller and local pilots that zero-zero departures used to be permitted until about 2 years ago and since then clearances while on the ground have been unavilable. Now the airport is only 10 NM SE of Ontario...so I'm guessing that my IFR departure off Flabob negatively impacts their inbounds into ONT until they have identifed me on radar or I'm through the MVA. I have suspected this is the funcamental I'm not permitted a clearance and that until 2 years ago there may have been a Letter of Agreement between ONT tower and SoCal departure that permitted Flabob IFR departures. If so, am I not getting a raw deal on "first come, first, served"? The current SOCAL SOP specifies a procedure for clearances for two airports without published departure procedures, Flabob and Perris Valley. The RIR procedure is, "Cleared to (destination), enter controlled airspace southwest of Fla-Bob. When entering controlled airspace, proceed direct RAL VOR, direct PDZ (remainder of route), maintain 4000' MSL, expect (filed or TEC altitude) 10 minutes after departure." I can find nothing else which mentions IFR departures from Flabob. BTW, the FSDO guy was the least helpful: "No instrument departure, no clearances on the ground." When I protested that this was clearly in error he just repeated what he said, adding some impatient attitude. That was the end of that conversation. Your experience with FSDO is not unusual. |
On Mar 2, 9:49 am, "Steven P. McNicoll"
wrote: On Mar 2, 9:53 am, wrote: Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. I heard from both the controller and local pilots that zero-zero departures used to be permitted until about 2 years ago and since then clearances while on the ground have been unavilable. Now the airport is only 10 NM SE of Ontario...so I'm guessing that my IFR departure off Flabob negatively impacts their inbounds into ONT until they have identifed me on radar or I'm through the MVA. I have suspected this is the funcamental I'm not permitted a clearance and that until 2 years ago there may have been a Letter of Agreement between ONT tower and SoCal departure that permitted Flabob IFR departures. If so, am I not getting a raw deal on "first come, first, served"? The current SOCAL SOP specifies a procedure for clearances for two airports without published departure procedures, Flabob and Perris Valley. The RIR procedure is, "Cleared to (destination), enter controlled airspace southwest of Fla-Bob. When entering controlled airspace, proceed direct RAL VOR, direct PDZ (remainder of route), maintain 4000' MSL, expect (filed or TEC altitude) 10 minutes after departure." I can find nothing else which mentions IFR departures from Flabob. BTW, the FSDO guy was the least helpful: "No instrument departure, no clearances on the ground." When I protested that this was clearly in error he just repeated what he said, adding some impatient attitude. That was the end of that conversation. Your experience with FSDO is not unusual. Steven: Thanks. That makes sense and is what I would have expected. Is this SOP publicly available? I guess now I just have to find out why they won't issue it... Alan |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
