I know this question has probably been answered thousand times before
on this forum. I am based at s50 in washington with no instrument approach or departure procedure. It is class G to 1200 and then class e plus some class b around. How can I depart IFR from this airport? Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance, be responsible for my own obstacle clearance and separation and depart essentially at 0/0 (if i ever thought that was a good idea?) The minimum vectoring altitude is 2000 feet. Just thinking about those days where the ceiling is 800-1200 or a 400 feet fog layer where it would be nice to get out. |
Get a clearance by calling from your cell phone. Obstical clearance is your
responsibility. Mike MU-2 "endre" wrote in message om... I know this question has probably been answered thousand times before on this forum. I am based at s50 in washington with no instrument approach or departure procedure. It is class G to 1200 and then class e plus some class b around. How can I depart IFR from this airport? Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance, be responsible for my own obstacle clearance and separation and depart essentially at 0/0 (if i ever thought that was a good idea?) The minimum vectoring altitude is 2000 feet. Just thinking about those days where the ceiling is 800-1200 or a 400 feet fog layer where it would be nice to get out. |
"endre" wrote:
How can I depart IFR from this airport? Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance... Look in the back of the Airport/Facilities Directory for your FSS clearance delivery phone number. Call them for a void time clearance if you can't maintain VFR up to radar altitude. -- Dan C172RG at BFM (remove pants to reply by email) |
"Mike Rapoport" wrote in message ink.net... Get a clearance by calling from your cell phone. Obstical clearance is your responsibility. Mike MU-2 There is never a time on initial departure when obstacle clearance is not the responsibility of the pilot - controlled or uncontrolled. |
I will add to the suggestions you got,
If you have a tower near your airport, you can call them or, as when I was doing my instrument training, we flew into and out of cedar city Ut. no tower, so we called center and got our clearance from them. I fly out of HND and VGT, when the tower is closed, I call LAS. I looked up your airport, it looks like SEA is only about 7 miles from you, I would call them for your clearance. File with FSS, then about 15 minutes before your ready to go, call them on the radio and tell them who you are, where you are and what you want. endre wrote: I know this question has probably been answered thousand times before on this forum. I am based at s50 in washington with no instrument approach or departure procedure. It is class G to 1200 and then class e plus some class b around. How can I depart IFR from this airport? Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance, be responsible for my own obstacle clearance and separation and depart essentially at 0/0 (if i ever thought that was a good idea?) The minimum vectoring altitude is 2000 feet. Just thinking about those days where the ceiling is 800-1200 or a 400 feet fog layer where it would be nice to get out. |
I departed an airport recently (uncontrolled) and called fss and filed.
After taxi and runup called (cell phone) again and got clearance. Steve "endre" wrote in message om... I know this question has probably been answered thousand times before on this forum. I am based at s50 in washington with no instrument approach or departure procedure. It is class G to 1200 and then class e plus some class b around. How can I depart IFR from this airport? Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance, be responsible for my own obstacle clearance and separation and depart essentially at 0/0 (if i ever thought that was a good idea?) The minimum vectoring altitude is 2000 feet. Just thinking about those days where the ceiling is 800-1200 or a 400 feet fog layer where it would be nice to get out. |
Robert Henry wrote: "Mike Rapoport" wrote in message ink.net... Get a clearance by calling from your cell phone. Obstical clearance is your responsibility. Mike MU-2 There is never a time on initial departure when obstacle clearance is not the responsibility of the pilot - controlled or uncontrolled. When is there a time when obstacle clearance is not the responsibility of the pilot? The only difference at a VFR airport is the feds don't provide you a procedure to help you fulfill that responsibility. |
Yes thats true. I was referring to the fact that, without a obstacle DP,
you are on your own in determining whether or not you will clear obstructions. Mike MU-2 "Robert Henry" wrote in message news:MNy_b.2362$TT5.1291@lakeread06... "Mike Rapoport" wrote in message ink.net... Get a clearance by calling from your cell phone. Obstical clearance is your responsibility. Mike MU-2 There is never a time on initial departure when obstacle clearance is not the responsibility of the pilot - controlled or uncontrolled. |
endre wrote: I know this question has probably been answered thousand times before on this forum. I am based at s50 in washington with no instrument approach or departure procedure. In the Portland area there's a frequency for uncontrolled airports to use (119.95 iirc). At 7S3 there's one spot on the airport where it's usable, so you taxi over, get a void time, depart and call Portland Departure. I don't see anything like that in the Seattle area, though. Are such services common? Would SEA think you were off your nut if you managed to raise them on 128.0 and said 'on the ground at Auburn'? -- Ben Jackson http://www.ben.com/ |
"endre" wrote in message om... I know this question has probably been answered thousand times before on this forum. I am based at s50 in washington with no instrument approach or departure procedure. It is class G to 1200 and then class e plus some class b around. How can I depart IFR from this airport? I'd try calling Seattle approach on 119.2. You're only 8 miles from SEA, you may be able to get them on the ground at S50. Give it a try next time you're at S50. Incidentally, it's Class G to 700 MSL over S50, not 1200 Do i need to depart VFR and stay below 1200 and pick up my clearance or can I get a void time clearance, be responsible for my own obstacle clearance and separation and depart essentially at 0/0 (if i ever thought that was a good idea?) Controlled airspace begins at 700 AGL and the base of Class B airspace is 3000 MSL over S50. If it's VFR all you have to do is avoid Class B airspace until getting a clearance. If it's below VFR minimums you have to have an IFR clearance before you climb into Class E airspace at 700 AGL. |
| Thread Tools | |
| Display Modes | |
| SWRFI update... Moving again (argghh!!)... | Dave S | Home Built | 14 | October 15th 04 04:34 AM |
| Please help -- It's down to the wire | Jay Honeck | Home Built | 12 | July 14th 04 07:05 PM |
| The battle for Arlington Airport begins? | Paul Adriance | Home Built | 45 | March 31st 04 12:41 AM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 05:02 PM |
| Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 07:39 PM |
