current small aircraft market????
Old May 21st 07, 05:44 PM posted to rec.aviation.owning
Allen[_1_]
Default current small aircraft market????
"Matt Barrow" wrote in message
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Matt Whiting wrote:
Ken Reed wrote:
NJAS3068 1966 CESSNA 210F
Insured Value $70,000
Premium for Aircraft NJAS3068 is $3,785.00
That's a major reason I didn't buy a turbo 210 I looked at a few
years ago. Insurance on any 210 was outrageous, according to my
broker. I'm paying less of a yearly premium than quoted above, have
1MM smooth, an airframe that's 25 years newer and a hull value
almost four times that quoted above. This for my Mooney Bravo.
Any idea of why the difference is so dramatic? I thought the 210 had
a decent accident rate.
I'll probably end up with a 182 again as that way I have the required
50 hours in type.
Matt
6 vs 4 seats at least on the later models.
When was the 210 a four-seater?
The first four model years were 4 seats, then the kiddie seats came as an
option I believe in 1964.
Old May 21st 07, 06:21 PM posted to rec.aviation.owning
Deadstick
That's a major reason I didn't buy a turbo 210 I looked at a few years
ago. Insurance on any 210 was outrageous, according to my broker. I'm
paying less of a yearly premium than quoted above, have 1MM smooth, an
airframe that's 25 years newer and a hull value almost four times that
Any idea of why the difference is so dramatic? I thought the 210 had a
I'll probably end up with a 182 again as that way I have the required 50
hours in type.
Matt
Generally the losses insurance companies see in Cessna 210 involve
landing gear failures, gear up landings, losing control on landing or
over-running the end of the runway. These losses themselves aren't so
bad, but the cost to repair a Cessna 210 is going up rapidly every
year.
$3785 annual premium for a Cessna 210 for a low-time pilot doesn't
seem out of line. If you can get through the first year without a
loss and fly a lot, your premium would go down substantially the next
year.
Old May 21st 07, 10:01 PM posted to rec.aviation.owning
John Galban
On May 20, 7:55 pm, Newps wrote:
That's a terrible quote. When I bought my Bo in the summer of 05 I had
zero retract time. About 1100 hours total, almost all in my 182. Hull
value $90K. Premium was $2800 for the same limits as you except the
medical payments are either $3K or $5K, I forget. Last year the premium
was $2300. This year I expect it will be less then $2K especially since
I won't forget to ask to have it insured for four seats only this time.- Hide quoted text -
You can usually get a policy with the $100K sublimits if you have no
time in type, but forget smooth coverage. Even when I bought my
lowly Cherokee over a decade ago, I had to go the first year with the
$100K sublimit because I had no time in type. After the first year,
all of the companies except Avemco would quote a smooth policy.
Avemco doesn't do smooth.
By the way Newps, I think you got a great deal on your policy. Most
low-rectract time pilots usually take it in the shorts on their first
retract policy.
Last year at a backcountry strip, I met a guy selling a pristine '61
210 with a new engine and interior for just under $60K. He said he'd
had it on the market for 6 months, but none of the interested buyers
could get a reasonable insurance rate, so he had to keep lowering the
price. I think there's something that insurance companies don't like
about the 210 / Newbie retract pilot combo.
John Galban======N4BQ (PA28-180)
Old May 22nd 07, 01:12 AM posted to rec.aviation.owning
Newps
retract policy.
And I am insured with Avemco. When I shopped around I got a slightly
lower quote with the company I had with the 182, Global. They were
about $100 cheaper but wanted 25 hours with an instructor. I told him
he was nuts and went with Avemco who only wanted 10 hours.
Struts, gear doors and an IO-470. What the hells the point?
He said he'd
I have a friend with a Turbine P210. Same deal with those, you can't
give them away. You going to make Schafer third weekend in July?
Old May 22nd 07, 01:22 AM posted to rec.aviation.owning
Matt Whiting
50 hours in type.
Matt
Ah, yes, I forgot that Mooney is a 4 seater.
Matt
Old May 23rd 07, 12:10 AM posted to rec.aviation.owning
flynrider via AviationKB.com
It's looking like I will make it this year. I'll probably arrive on Sat.
morning.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200705/1
Old May 23rd 07, 04:16 AM posted to rec.aviation.owning
Ken Reed
My broker just calls it a 'high loss rate.'
Ken Reed
M20M, N9124X
Old May 23rd 07, 06:01 PM posted to rec.aviation.owning
Newps
morning.
Good, look for the yellow and white V tail and stop by and say hi. We
always arrive Thursday morning as then we get a full day with the place
to ourselves.
  #29
Old May 24th 07, 04:25 PM posted to rec.aviation.owning
Paul kgyy
Still another factor is the emergence of used Cirrus and Diamond
models, moving down into the $200K range. This is depressing prices
for high end retractables made in the period 1975-1995, and this in
turn pushes everything else down.
  #30
Old May 25th 07, 05:02 PM posted to rec.aviation.owning
Dan Luke
Doesn't appear to be hurting the prices of the aircraft I'm interested in --
late '80s model Bonanza A36s.
Good ones are hanging right around $240-300K, where the've been for quite a
while.
Dan
? at BFM
Would ~ 500 planes depress the U.S. used aircraft market? OtisWinslow General Aviation 0 August 25th 05 10:42 PM
Would ~ 500 planes depress the U.S. used aircraft market? OtisWinslow Owning 0 August 25th 05 10:42 PM
Would ~ 500 planes depress the U.S. used aircraft market? [email protected] Owning 15 August 24th 05 10:40 PM
Would ~ 500 planes depress the U.S. used aircraft market? Dave S General Aviation 11 August 24th 05 01:19 PM
Would ~ 500 planes depress the U.S. used aircraft market? Dave S Owning 0 August 23rd 05 04:02 AM
