In rec.aviation.owning Peter wrote:
As posted here already, the UK government is proposing evicting its foreign registered GA aircraft: http://tinyurl.com/ar229 Most of these are N-reg, and many would end up on the U.S. market, within a short time of each other. To retain worldwide IFR privileges the pilots would have to do the European IR and my view is that most would not find the time to work through the ground school. They would thus lose their European IFR privileges and many would sell up. If this action does succeed, other European countries are likely to follow in a wholesale eviction of mainly US-registered aircraft. I just wonder what would happen to the used aircraft market, if it saw the arrival of that many aeroplanes; a mixture of piston singles and twins, turboprops and some jets. Most would not be old Pipers and Cessnas. There are 2262 piston single engine aircraft listed for sale on controller.com alone right now. Throw in all the other listings, discard the duplicates, and that's a lot of airplanes for sale. Unless the majority had some commonality, e.g. a lot of 182s over a narrow year range, I doubt it would make much difference and then only over that range. But then again, I could be wrong, and as I'm airplane shopping I wouldn't be adverse to prices falling for a while. -- Jim Pennino Remove .spam.sux to reply. |
wrote)
[snip] But then again, I could be wrong, and as I'm airplane shopping I wouldn't be adverse to prices falling for a while. Sorry if I missed the thread, but what kind of plane are you hunting for? What are some of your parameters: (...If you don't mind) Costs? Seats? Speed / Fuel sipping High wing / Low wing Cool factor...? Single? - Twin? Turbine :-) Where are you going to be flying your new plane? Thanks. Montblack |
In rec.aviation.owning Montblack wrote:
wrote) [snip] But then again, I could be wrong, and as I'm airplane shopping I wouldn't be adverse to prices falling for a while. Sorry if I missed the thread, but what kind of plane are you hunting for? Understandable since this is actually my first public mention of it. What are some of your parameters: (...If you don't mind) Costs? Seats? Speed / Fuel sipping High wing / Low wing Cool factor...? Single? - Twin? Turbine :-) Where are you going to be flying your new plane? Thanks. Montblack OK, here goes: I'd rather spend money on flying than insurance, maintenance, and recurrent training and I'd rather sit home in front of the fireplace with an adult beverage when the weather is nasty, so a simple, fixed gear, single engine. I'm waffling about a constant speed prop. I'd like to keep it under $100k and will probably keep it for decades unless I win the Lotto or lose my medical. 99% of my flying will be two people and small baggage on trips within about 200 nm, so a 2 place airplane would be suitable. I don't have the time to build a homebuilt. On the rare occasion I would have more than two people, I can rent a 182. Unfortunately, I'm not a FAA standard person, so 152s are out. I don't have any preference on high versus low wing, but I do find the Piper single door a pain in the butt. The location would be the Southwest to places where the density altitude can easily get to 8000+ feet, so horsepower is a concideration. Older airframes don't bother me much but old avionics does. Possible candidates a 172, marginal in horsepower 182, sucks a lot of gas for the application and is constant speed Tiger Sundowner, a bit on the slow side, but comfy 177, can be high maintenance from what I've read and constant speed Archer, Piper single door 172 PennYan 180 conversion, not a lot around Symphony 160, most of the used ones I've found are at TBO The planes highest on my list are the Symphony and the 172N or later followed by the Archer. One plus to the Symphoney is it eliminates all the "friends" coming out of the woodwork with 200 lb of baggage looking for a ride to Vegas. A high time, but not quite all the way to TBO 172 that I could drop the PennYan conversion into during the winter nasties is a thought. But, if I hit the Lotto, it will be 2 SkyMasters; one to fly and one to keep in the shop. -- Jim Pennino Remove .spam.sux to reply. |
Mooney M20C. You can get a good one for around $50-$60K. Burns less gas
than a 182 to go faster. An M20C will have a useful load around 1000lbs (but remember you don't need to carry as much gas as a 182). -Robert |
("Robert M. Gary" wrote)
Mooney M20C. You can get a good one for around $50-$60K. Burns less gas than a 182 to go faster. An M20C will have a useful load around 1000lbs (but remember you don't need to carry as much gas as a 182). He might not fit? How tight is an M20C if you're ...big? Unfortunately, I'm not a FAA standard person, so 152s are out. FWIW, I've heard very good things about Cardinals - though some people don't like them. It seems like getting the 'right one' is important with the 177 - and I don't know what combination that is. I do know they have an active owner's group. http://www.cardinalflyers.com/ http://www.aya.org/ Grumman owners seem to have a good group also. Good luck! Montblack |
Montblack wrote:
FWIW, I've heard very good things about Cardinals - though some people don't like them. It seems like getting the 'right one' is important with the 177 - and I don't know what combination that is. Basically, get one with the 180hp engine (later than 1968). They're a tiny bit faster than a 160hp 172 and carry about 16 pounds less. Better access, better visibility, and arguably prettier. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
I'm 6"4' and 230lbs and find the Mooney to be great. You really HAVE to
be a tall person to fly a Mooney because the rudders are VERY distant from the seat. |
I'd like to keep it under $100k and will probably keep it for decades unless I win the Lotto or lose my medical. 99% of my flying will be two people and small baggage on trips within about 200 nm, so a 2 place airplane would be suitable. Unfortunately, I'm not a FAA standard person, so 152s are out. You might look into a new Maule M-4. They've set it up with just 2 seats for insurance purposes, but it's got 180 hp and can haul. You might find it a bit slow, and it's got conventional gear, but it's a nice aircraft. With a fixed-pitch prop, it's $96K. http://www.mauleairinc.com/Maule_News/m_4_180v.html It comes with this standard equipment - http://www.mauleairinc.com/____Stand...equipment.html George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
On Wed, 24 Aug 2005 02:17:31 GMT, George Patterson
wrote: wrote: I'd like to keep it under $100k and will probably keep it for decades unless I win the Lotto or lose my medical. 99% of my flying will be two people and small baggage on trips within about 200 nm, so a 2 place airplane would be suitable. Unfortunately, I'm not a FAA standard person, so 152s are out. You might look into a new Maule M-4. They've set it up with just 2 seats for insurance purposes, but it's got 180 hp and can haul. You might find it a bit slow, and it's got conventional gear, but it's a nice aircraft. With a fixed-pitch prop, it's $96K. How about a nice Debonair in good shape with about 3700 hours? I'd part with the old Deb for a slightly exorbitant price. Equipment is a bit dated, but set up for IFR with coupled autopilot (both navs and DG) and has altitude hold. RNAV, VOR, ADF (King Silver Crown Stack) Bout 160 Knot cruise on 14 GPH at 24 X 24 out of a 260HP IO470N and 3 Blade prop. It does not use any measurable amount of oil between 25 hour changes. It does need new tip tanks. 70 gallons without them. Big, comfortable, fast, long range, but unforgiving. Insurance would probably be a bit steep for a low time pilot. http://www.rogerhalstead.com/833R/833R_frame.htm OTOH a good, but older, 182 has range, load carrying capability, *Room*, is stable, good instrument platform, and probably has *relatively* cheap insurance. :-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com http://www.mauleairinc.com/Maule_News/m_4_180v.html It comes with this standard equipment - http://www.mauleairinc.com/____Stand...equipment.html George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
| Thread Tools | |
| Display Modes | |
| Would ~ 500 planes depress the U.S. used aircraft market? | Dave S | Owning | 0 | August 23rd 05 04:02 AM |
| FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | December 30th 04 12:16 PM |
| FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | April 15th 04 07:17 AM |
| Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 01:17 AM |
| FS: 1989 "War Planes" (Of The World) Cards with Box | Jim Sinclair | Aviation Marketplace | 0 | August 23rd 03 05:43 AM |
