On Jul 28, 6:44 am, wrote:
A question: How does Winscore calculate finish altitude on a cylinder finish? Winscore calculates altitudes and finish heights according to SSA Contest rules 6.7.4.3 and 11.2.1.5.1. .... Guy Byars Author of Winscore Winscore calculates altitudes and finish heights according to SSA Contest rules 6.7.4.3 and 11.2.1.5.1. ... Guy Byars Author of Winscore What does winscore do about 6.7.4 Altitude recording 6.7.4.1 A Flight Recorder may record altitude derived from a calculated position. The estimated altitude inaccuracy shall be applied in a way unfavorable to the pilot (if the flight log does not include a reliable estimate of this inaccuracy, a value of 75 feet shall be used). 6.7.4.2 A Flight Recorder may record a calibratable pressure altitude. If such a device is used in circumstances where altitude is needed, the altitude inaccuracy determined from the best available calibration data shall be applied in a way unfavorable to the pilot. 6.7.4.3 If a Flight Recorder records both calculated and pressure altitude, pressure altitude will be the primary data source and calculated altitude will be the backup data source for flight evaluation. I've never really understood these rules. Does winscore subtract 75 feet from GPS altitude in deciding if you get a penalty (or add it for start gates and 17500?) I've never submitted calibration data at a contest, does 6.7.4.2. apply anywhere? John Cochrane |
At 01:48 28 July 2007, Marc Ramsey wrote:
BB wrote: In my opinion the clock should stop as soon as the pilot enters the cylinder. We shouldn't have pilots in the finish cylinder still racing. You haven't met enough contest pilots. If the rules change in this way, pilots will aim to finish one mile out, 50 feet, 90 knots and then float in to the landing, european-style. Applying an appropriate penalty for finishing below the Minimum Finish Height would eliminate that behavior. I was actually surprised to find that the SSA competition rules provide no guidelines as to how to penalize pilots who don't make it into the finish cylinder. Given the difficulties of knowing precisely how high one is finishing, missing by 50 or so feet shouldn't result in a huge penalty, but it should also never be beneficial to intentionally finish low... Marc DISCLAIMER: I understand under the new rules speed points are no longer allocated pro-rata so as to create bit more spread at the top of the scoresheet. My math may, therefore, be a bit off. The worst case scenario for making marginal final glide decisions is on a short task where a pilot is climbing slowly trying to make it up to final glide altitude. The slow climb takes up lots of minutes per foot gained and every minute drags down your speed relatively more on shorter tasks. So, say you are climbing at 2 knots. It will cost you about 4 points for every hundred feet you climb, or about 40 points to go from a white-knuckle 2-knot glide to 0' at the finish up to a 2-knot glide to a 1000' AGL arrival. For a 4-hour task the 4 points per 1000' drops to 2 points per 1000'. You could imagine a penalty structure that looks something like: 8 points per hundred feet divided by the minimum task time (or the winners time, or your time). This eliminates most of the incentive to cut a last thermal short since it is in the pilot's interest to keep climbing if he thinks there is any chance he will be under the minimum finish height and he is achieveing a climb rate of 2 knots or more. If you're climbing in your final thermal at less than 2 knots you are looking at a dicey glide no matter what, and probably are contemplating a rolling finish. It's not clear to me that a penalty structure built around slower than 2 knot climb rate would do any good - plus the penalties start to get kind of large (e.g. 16 points per 100 feet if you pick 1 knot as the climb rate). With the penalty structure I've described, if you finish at 500' below the minimum finish height (so you are at most 500' AGL) and actually fly to more or less a full pattern it would take about 2.5-3 minutes to get from the edge of a 1-mile cylinder to a full stop. This is based on looking at a couple of my contest finishes at Parowan where the runway is pretty long and they were asking us to roll all the way to the end. Guess what? The penalty as described above would work out to the equivalent of an additional 2.5 minutes, so the worst case scenario for a low flying finish, would be no worse than taking the time to landing and stopping. If you just barely miss the minimum height you are a lot better off. In terms of coming to a screeching halt in the middle of the runway on a rolling finish - it's worth 2-5 points in my estimation. You need to weigh that against all the other safety considerations and potential penalties that might be imposed of you were really ver-the-top about it. Plus the ill-will from your crew when they have to schlep your glider halfway across the airport. 9B |
In the good old days, there was a simple penalty structure. Finish one
foot low (one foot under the top of the airfiled fence) and you've landed out for the day, hopefully in the last field before the airport and not on the fence itself. It seems a lot simpler to simply move the good old days up 500 feet. Back then, each pilot set his own safety margin, and didn't expect anyone except his beer buddies to listen to "but I was only 10 feet below the finish height". If we go to fancy altitude-based penalties like JJ wants, or Andy's carefully figured penalties, then the race goes to guys like me and Andy who are willing to spend all winter figuring out the scoring formulas and how to game them. Even the current rolling finish plus x minutes leads to some fine calculations about thermal strength, chance of porpoising, and so on to optimally take advantage of the rolling finish option. Fine with me in a way, I need all the help I can get and I'm good at math. But simplicity also has its virtues. John Cochrane |
At 20:42 28 July 2007, Andy Blackburn wrote:
At 01:48 28 July 2007, Marc Ramsey wrote: BB wrote: In my opinion the clock should stop as soon as the pilot enters the cylinder. We shouldn't have pilots in the finish cylinder still racing. You haven't met enough contest pilots. If the rules change in this way, pilots will aim to finish one mile out, 50 feet, 90 knots and then float in to the landing, european-style. Applying an appropriate penalty for finishing below the Minimum Finish Height would eliminate that behavior. I was actually surprised to find that the SSA competition rules provide no guidelines as to how to penalize pilots who don't make it into the finish cylinder. Given the difficulties of knowing precisely how high one is finishing, missing by 50 or so feet shouldn't result in a huge penalty, but it should also never be beneficial to intentionally finish low... Marc DISCLAIMER: I understand under the new rules speed points are no longer allocated pro-rata so as to create bit more spread at the top of the scoresheet. My math may, therefore, be a bit off. The worst case scenario for making marginal final glide decisions is on a short task where a pilot is climbing slowly trying to make it up to final glide altitude. The slow climb takes up lots of minutes per foot gained and every minute drags down your speed relatively more on shorter tasks. So, say you are climbing at 2 knots. It will cost you about 4 points for every hundred feet you climb, or about 40 points to go from a white-knuckle 2-knot glide to 0' at the finish up to a 2-knot glide to a 1000' AGL arrival. For a 4-hour task the 4 points per 1000' drops to 2 points per 1000'. You could imagine a penalty structure that looks something like: 8 points per hundred feet divided by the minimum task time (or the winners time, or your time). This eliminates most of the incentive to cut a last thermal short since it is in the pilot's interest to keep climbing if he thinks there is any chance he will be under the minimum finish height and he is achieveing a climb rate of 2 knots or more. If you're climbing in your final thermal at less than 2 knots you are looking at a dicey glide no matter what, and probably are contemplating a rolling finish. It's not clear to me that a penalty structure built around slower than 2 knot climb rate would do any good - plus the penalties start to get kind of large (e.g. 16 points per 100 feet if you pick 1 knot as the climb rate). With the penalty structure I've described, if you finish at 500' below the minimum finish height (so you are at most 500' AGL) and actually fly to more or less a full pattern it would take about 2.5-3 minutes to get from the edge of a 1-mile cylinder to a full stop. This is based on looking at a couple of my contest finishes at Parowan where the runway is pretty long and they were asking us to roll all the way to the end. Guess what? The penalty as described above would work out to the equivalent of an additional 2.5 minutes, so the worst case scenario for a low flying finish, would be no worse than taking the time to landing and stopping. If you just barely miss the minimum height you are a lot better off. In terms of coming to a screeching halt in the middle of the runway on a rolling finish - it's worth 2-5 points in my estimation. You need to weigh that against all the other safety considerations and potential penalties that might be imposed of you were really ver-the-top about it. Plus the ill-will from your crew when they have to schlep your glider halfway across the airport. 9B Typo: For a 4-hour task the 4 points per 1000' drops to 2 points per 1000'. Should read: For a 4-hour task the 4 points per 100' drops to 2 points per 100'. 9B |
![]() Good post Andy, but I believe we need a set penalty to discourage deliberately doing a rolling finish on a good day. I watched a well known pilot make a rolling finish every day for 5 days in a row (1000 feet and 2 mile finish cylinder). I have recommended the rules committee consider the following: up to 100 feet low = 5 point penalty up to 200 feet low = 10 point penalty up to 300 feet low = 15 point penalty up to 400 feet low = 20 point penalty rolling finish = 25 point penalty JJ Should read: For a 4-hour task the 4 points per 100' drops to 2 points per 100'. 9B |
Lots of good points made.
I went flying yesterday and found that my SN10 has a beatiful digital pressure altimeter readout, that is automatically calibrated before takeoff to field elevation, and can be reset inflight to the latest altimeter setting if desired. I also found that my mechanical POS alitmeter lags about 100' during a final glide, showing me that much higher that the SN10's no-friction digital readout. Guess what I'll be using from now on! Back to the original subject (actually a spin off): I still think the current hard cutoff at 500 ft is a poor setup, due to the difficuty for the pilot to accurately judge his altitude at the time of crossing the line. If the goal is to make pilots finish higher (for whatever reason), then there needs to be a finish window the pilot can aim for that if he accurately figures his final glide, will not be penalized. Let's assume we can hit a 200' window - and assume that 300' agl is the cutoff for a safe pattern. Setup the scoring so anywhere in the 200 ft window (300'agl to 500'agl ) is neutral - if below the nominal 500', then add the time it would have taken to climb in (based on the climb rate in the last thermal). That would remove any incentive to finish lower than 500', but give a reasonable window to shoot for before a bigger penalty (automatic rolling finish score) kicks in. Comment? Obvious problems? Kirk 66 |
kirk.stant wrote:
I still think the current hard cutoff at 500 ft is a poor setup, due to the difficuty for the pilot to accurately judge his altitude at the time of crossing the line. If the goal is to make pilots finish higher (for whatever reason), then there needs to be a finish window the pilot can aim for that if he accurately figures his final glide, will not be penalized. Let's assume we can hit a 200' window - and assume that 300' agl is the cutoff for a safe pattern. Setup the scoring so anywhere in the 200 ft window (300'agl to 500'agl ) is neutral - if below the nominal 500', then add the time it would have taken to climb in (based on the climb rate in the last thermal). That would remove any incentive to finish lower than 500', but give a reasonable window to shoot for before a bigger penalty (automatic rolling finish score) kicks in. Comment? Obvious problems? I'd suggest the opposite. I think I should be rewarded for every foot that I have over the minimum finish height of, say, 500' AGL. So, if I finish at 2000' AGL, I should get the actual time I spent climbing the last 1500' deducted from my task time. It's more accurate, and it favors my chosen strategy, what's not to like? 8^) In reality, any halfway decent glide computer, or software with access to pressure altitude, will prior to takeoff either automatically determine the field elevation or let the pilot set it manually. The same sort of problem exists with the start cylinder if one can climb to the top. The glide software I use (which I wrote) automatically determines field elevation just prior to takeoff. It monitors my altitude in the start cylinder, signals me if I climb through the top and does a countdown when I reenter, provides progressive warnings as I approach the hard altitude limit (usually 17500' MSL out here), and automatically adjusts my arrival altitude based on the minimum finish height, all based on that initial field elevation measurement. I'm confident that this will work within a margin of 10 or 20 feet, as it using the pressure altitude that will ultimately show up in the IGC file, and I don't have to pay much attention to any of it. The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? Marc |
On Jul 29, 4:01 pm, Marc Ramsey wrote:
The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. Andy |
WinScore Question | Ray Lovinggood | Soaring | 2 | June 5th 07 03:15 PM |
calculate last point of diversion | jaws | Piloting | 1 | July 5th 06 04:19 PM |
How to calculate TOC and TOD? | Andrea da lontano | Piloting | 3 | October 21st 04 09:24 PM |
Weight and Balance Formula, Can one calculate the envelope | Joe Wasik | Piloting | 12 | September 29th 04 08:15 AM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
