Mounting 396
Old August 20th 07, 09:51 PM posted to rec.aviation.piloting,rec.aviation.owning
Ray Andraka
Default panel Mounting 496
Newps, Thanks.
Newps wrote:
Ray Andraka wrote:
OK, I have a 496, and an air gizmo mount, which I'd like to put on my
panel. I'm curious to the signoffs needed:
The Air gizmo I think should be allowed to be installed by the
owner/pilot as an interior decoration as long as it doesn't involve
drilling or cutting the panel. Correct? If I have to cut the panel
or drill holes, do I need an A&P signature? The W&B change is
negligible I believe.
It is a minor alteration and needs to be signed off by an A&P as such.
An owner cannot do that. Drilling or cutting does not affect that.
In order to wire the power into the aircraft power (not through a
cigar lighter plug), I think I need an A&P signature, and all work has
to conform to 43.13, nothing more correct?
Yes. One other way to go is to have the A&P wire up a cig lighter plug
under the panel where you can't see it. That way when the next
latest/greatest comes out you're ready to go. I have two extra cig
lighters under the panel. I have one wired directly to the battery so
it is always hot, that way I can recharge a cell phone or whatever. The
other is wired to come on with the master, that way the GPS fires up
automatically.
How about running extension wires for the XM USB and remote antenna to
the top of the glareshield with the wires behind the panel? I imagine
that needs an A&P sign-off if the wires are tie-wrapped into place?
No, it wouldn't.
OK, and the final question: It looks like in order to fit it in, I'll
need to pull the ancient Foster Loran and it's tray out. That's
surely going to need somebody's sign-off. Does that have to be pulled
by an avionics shop (it does have a connection to the autopilot
switch), or can that be done under an A&P's supervision and signature
as well? I figure I'll replace the Loran antenna with a comm antenna
and leave the end available on the panel for my handheld.
An A&P can do that. You can do all the work, just have him look it over
and sign it off. He'll have to change the placard on the autopilot
switch to reflect that the loran was removed.
Old August 20th 07, 10:08 PM posted to rec.aviation.piloting,rec.aviation.owning
Larry Dighera
Is your aircraft certified or experimental?
Here's an article from AOPA on the subject:
http://www.aopa.org/whatsnew/newsite...0201parts.html
Don't take panel-mount option out of portable GPS, AOPA tells FAA
Think your portable GPS would work great mounted to your old Cessna
172's instrument panel? If the FAA has its way, you won't be able to
mount it. The parts — panel dock and connective wiring — needed to
mount your portable GPS would either no longer be available or be too
expense to buy.
The FAA's proposal would make it illegal for manufacturers to produce
a replacement or modification part if they know (or should know) the
part would end up installed in a certified aircraft — that is unless
they obtain production approval from the agency. But that costs tens
of thousands of dollars, something many companies can't afford.
While AOPA agrees production approval is necessary for critical parts
like connecting rods and cylinders, it isn't needed for non-critical
parts like a portable GPS panel dock or traffic detector that enhance
pilot safety.
"This [rule] would basically require any person who manufactures a
part, like a light bulb, smoke detector, entertainment system, or
other non-critical part that has not been identified as a 'standard or
commercial part' to obtain a production approval from the FAA if the
part is to be installed in a type-certificated product," Gutierrez
said in formal comments opposing the proposed rule.
Also under the rule, parts listed on the design approval for one
aircraft couldn't be used as a replacement in another aircraft.
For example, let's say Cessna installs GE light bulbs in the
aircraft's instrument panel and lists the bulb in its design approval.
Well, you wouldn't be able to use that same type of light bulb to
replace the burned out one in your old Bonanza.
These proposals "would substantially increase the cost of general
aviation parts and unnecessarily stifle the development and
availability of safety and operational enhancement modifications,"
Gutierrez told the FAA. "AOPA requests that the FAA revise this
proposal to ensure that replacement and modification parts remain
affordable and available to GA aircraft owners."
February 1, 2007
AOPA's response to FAA NPRM: Docket No. FAA-2006-25877; Notice of
Proposed Ruelmaking; Production and Airworthiness Approvals, Part
Marking, and Miscellaneous Proposals:
http://www.aopa.org/whatsnew/newsite...rts-letter.pdf
Enter docket number 25877 he
http://dms.dot.gov/search/searchFormSimple.cfm
And you can read the NPRM and comments.
http://www.faa.gov/about/office_org/...M_Briefing.ppt
http://search.google.dot.gov/FAA/FAA...ntend&oe=UTF-8
Summary of Proposals
14 CFR Part 45 Continued
New Part Marking Requirements
Manufacturer & Part Number Req?d
Delete ?FAA-PMA? Markings
Delete ?installation eligibility? ? PMA
Project Status
Currently On Track ?
NPRM and Implementation Advisory Circulars Available for Comment at
http://dms.dot.gov, docket numbers 25877 and 25882
Final Rule to be published by April, 2008
Effective Date of Final Rule is set for October, 2009
Mounting cameras keithw Soaring 2 December 3rd 05 05:02 PM
GPS mounting bracket Michael Ware Owning 3 November 5th 05 11:30 PM
PDA mounting alternatives Jack Glendening Soaring 15 October 14th 05 08:03 PM
Mounting my GPS Charles Talleyrand Owning 8 November 19th 03 11:51 AM
Mounting my GPS Charles Talleyrand Piloting 8 November 19th 03 11:51 AM
