How come the wings bank when I use the rudder
Old October 21st 07, 05:50 PM posted to rec.aviation.piloting
Paul kgyy
Default How come the wings bank when I use the rudder
On Oct 21, 4:44 am, wrote:
I'm puzzled as to how you could be doing a solo X country and not know
this. Did you first lesson not include "effect of controls"? what
about your theory?
Cheers
He probably did, but that was in 1967... :-(
Old October 22nd 07, 02:55 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Dudley Henriques wrote in
Paul kgyy wrote:
On a 3 hour cross country today I was amusing myself by flying with
rudder pedals only (all right, OK, a little yoke usage to maintain
altitude). But then I got to wondering why applying rudder
pressure causes the plane to bank. All I could think of was that
rudder usage produces asymmetric lift because one wing is somewhat
blanked by the sideways motion induced by the rudder? Also, the
rudder surface is above the plane's center of lift but I don't know
how much of a
factor
that is.
It's called a yaw/roll couple. As you create yaw you acellerate
outside wing which then has more lift. It raises coupling with roll
and
you have turn.
Gotta disagree there Dudley. While it is true, and that's what
happening to some degree initially, the majority of the yaw roll
couple in lightplanes comes from the dihedral. the wing opposite the
direction of yaw has a higher angle of attack and generates more lift
then the opposite, which now has a lower alpha. Airplanes with no
dihedral will still roll slightly in the direction of yaw but it's
nearly zilch. can prove the first statement for yourself by
introducing the yaw so slowly as to make the diffrence in speeds
insignificant. The airplane will still roll in the direction of the
yaw. The V1 cruise missile had no dihedral and no ailerons and was
easily upset for this reason. Once it was off a wings level flight
path it's gyros had no chance of getting it back into straight and
level. Swept wing airplanes can have a huge yaw roll couple because
as you yaw, the forward moving wing's aspect ratio becomes massive
just as the aft moving's wing shrinks.(transonic ones have a reverse
effect couple at altitude, but that's another story)
Bertie
Not so much disagreement really. What you are saying is correct. All
these things happen.
Yep, but I think the airspeed portion is a minor one.
Technically however, the exact moment the yaw
induced higher angle of attack of the outside wing causes the excess
lift produced by the higher speed and alpha to introduce roll, a
couple has occurred and the aircraft is in an axis change from yaw
only to yaw/roll. It's a couple. Don't forget; there are complementary
couplings as well as adverse, and not all couplings result in
divergence or departure.
Yep, agreed. I stil think the speed element is insignificant in
practice. As a means of demonstration, the student can take the 172 or
whatever,and introduce some yaw smoothely and slowly whilst stopping any
roll with the ailerons.Then, leave the rudder in and nuetralise the
ailerons. With the yaw stabilised, i.e., no differnece in the speed
between the two wings, the roll will be almost as quick as if it was
introduced from co-ordinated S&L flight.
It's really a matter of semantics and amplified explanation.
The dihedral actually stabilizes the airplane in roll and acts as you
have said.
Oh I know it's picking a nit and from a practical point of view is
nearly immaterial, but I'm a chronic nit-picker. Can't help it!
A Cessna 195 would be one example of an airplane that will couple in
yaw without dihedral with no ill effect. A T38 however is an example
of an airplane that will couple in roll to departure if rolled at .9
mach with a full lateral stick throw.
OK, the 195 is a bad example because of it's parasol element and because
it's high wing and there are issues with blanketing and what not.
One of the midwing giant model airplanes they're flying aerobatics in
nowadays would be a better example.
Actually, are you sure the 195 is zero dihedral? Most high wing
airplanes that have zero dihedral look like they have anhedral. (Swick
T-cart, f'rinstance)
It's tapered as well. so even zero dihedral on top would still give some
below!
I've flown them, BTW Nice.
The T 38 example you're going to have to break down for me because:
a. I've not flown that class of airplane and
b. I'm full of whiskey.
Bertie
Old October 22nd 07, 03:31 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
how much of a
factor
that is.
and
you have turn.
Bertie
It is minor, especially for a light GA type airplane. High performance
airplanes get into a much more complicated dynamic concerning coupling.
As soon as you neutralize the aileron in this condition you are in
effect removing the opposing force preventing the coupling from
occurring . The airplane should instantly react to this by entering
into the couple which is consistent with your comment.
have said.
Don't think so. In fact, you're right on with this stuff.
Well, I would agree with this in that there are blanketing effects,
actually in high wings generally.
Could very well be.
below!
If I remember right, the 195 tapers all the way out and the wing's
thickness varies as well. I believe it is a 0 dihedral wing.
Never drink and fly the T38. Pull off to the side of the taxiway and
drink, then go fly.
The 38 has a high fuselage loaded mass IYMP (inertia yaw moment
parameter) which translated into normal language :-) means that at high
rates of roll, the airplane can actually suffer a divergence on the roll
axis as a coupling takes place with yaw and a new rolling axis is formed.
This can easily be visualized when you realize that at a speed around .9
mach, the roll rate of the airplane actually doubles with the last third
of a lateral stick throw. It's possible to get very close to 720 degrees
/sec roll rate out of a clean Talon.
The airplane is actually restricted to less than a full stick throw at
..9 for this reason.
When a coupling occurrs under these conditions, the 38 will depart, as
the offset roll axis produced by the coupling is unstable due to the
high mass loading of the fuselage vs the wing area.
It is however, a source of much amusement to bounce helmets off the real
canopy in this airplane even with a restricted roll rate.
Bertie
Dudley Henriques
Old October 22nd 07, 09:24 AM posted to rec.aviation.piloting
with rudder pedals only (all right, OK, a little yoke usage to
maintain altitude). But then I got to wondering why applying
rudder pressure causes the plane to bank. All I could think of
was that rudder usage produces asymmetric lift because one wing
is somewhat blanked by the sideways motion induced by the rudder?
Also, the rudder surface is above the plane's center of lift but
I don't know how much of a
factor
that is.
roll
and
you have turn.
the direction of yaw has a higher angle of attack and generates
more lift then the opposite, which now has a lower alpha. Airplanes
with no dihedral will still roll slightly in the direction of yaw
but it's nearly zilch. can prove the first statement for yourself
by introducing the yaw so slowly as to make the diffrence in speeds
reverse effect couple at altitude, but that's another story)
Bertie
coupling.
complementary couplings as well as adverse, and not all couplings
result in divergence or departure.
or whatever,and introduce some yaw smoothely and slowly whilst
stopping any roll with the ailerons.Then, leave the rudder in and
nuetralise the ailerons. With the yaw stabilised, i.e., no differnece
in the speed between the two wings, the roll will be almost as quick
as if it was introduced from co-ordinated S&L flight.
you have said.
because it's high wing and there are issues with blanketing and what
not.
Could very well be.
(Swick T-cart, f'rinstance)
some below!
Mayb, if it is, it's the top surface only. The thickness is also
tapered, so it has dihedral on the bottom .Not as much as a 172, but
it's there all the same.
drink, then go fly.
high rates of roll, the airplane can actually suffer a divergence on
the roll axis as a coupling takes place with yaw and a new rolling
axis is formed. This can easily be visualized when you realize that at
a speed around .9 mach, the roll rate of the airplane actually doubles
with the last third of a lateral stick throw. It's possible to get
very close to 720 degrees /sec roll rate out of a clean Talon.
.9 for this reason.
real canopy in this airplane even with a restricted roll rate.
OK, I think I have it. There're (roughly) similar problems with the
transonic stuff I fly but for some different reasons. Surely there are
some buffet isssues with the ailerons at large displacements as well?
Bertie
Old October 22nd 07, 12:53 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Jay Honeck writes:
In my case, my instructor NEVER discussed theories about flight. He
was a stick and rudder guy, could fly anything (and did), taught me
volumes, but rarely spoke about *why* certain things happened in
flight. I guess he just figured I would learn these things when
studying for the written.
I never did learn a lot of the subtle stuff (like why a rudder input
banks the wings) until much later. I suspect Paul is in the same
boat.
Most skills can be learned in a number of ways. Many skills are
taught in rote manner, i.e., "to accomplish x, do y," or "when the
aircraft does x, react with y." This is easy and fast to learn but
makes exceptions harder to handle. Skills can also be taught by
teaching theory and then letting the student apply the theory, but
this is rather tedious and slow, and the student must have good
reasoning ability in order to succeed. To address the largest
possible audience, rote learning tends to be preferred, but that does
occasionally leave competent and curious students wondering about
certain things.
You are an idiot.
You don't fly and you never will.
Bertie
Old October 22nd 07, 12:54 PM posted to rec.aviation.piloting
" wrote in
oups.com:
On Oct 21, 7:14 am, Mxsmanic wrote:
Jay Honeck writes:
He was a stick and rudder guy, could fly anything (and did), taught
me volumes, but rarely spoke about *why* certain things happened in
input banks the wings) until much later. I suspect Paul is in the
same boat.
certain things.
I feel Bertie about to make an entrance,,,,, ;)
Ta da!
Bertie
Old October 22nd 07, 01:28 PM posted to rec.aviation.piloting
Bertie
I've not noticed aileron buffet in the 38 even at max deflection. The
ailerons are extremely effective on the airplane.
About buffet; you actually work high performance jets like the 38 by
using the buffet boundary. You can pull the pole and feel the buffet
onset in pitch. It's a highly effective warning when maneuvering hard.
Dudley Henriques
  #29
Old October 22nd 07, 01:52 PM posted to rec.aviation.piloting
Dudley Henriques wrote in news:1dCdnWn-
Bertie
you're talking mach buffet now, right? not normal flow seperation..
I would have thought you might get buffet problems with large deflections
in and around transonic flight. We can, certainly, but our airplanes aren't
desingned for supersonic flight, of course..
bertie
The buffet limit is actually the subsonic buffet limit and defines the
lift limit line for the 38. In other words, below corner speed, you are
aerodynamically limited in maneuvering room by the lift limit line which
basically means you can pull to the buffet.
In effect, the tactical buffet line defines the left side of the T38's
flight envelope.
Dudley Henriques
  #30
Old October 22nd 07, 02:08 PM posted to rec.aviation.piloting
news
are some buffet isssues with the ailerons at large displacements as
well?
Bertie
The ailerons are extremely effective on the airplane.
hard.
deflections in and around transonic flight. We can, certainly, but
our airplanes aren't desingned for supersonic flight, of course..
bertie
are aerodynamically limited in maneuvering room by the lift limit line
which basically means you can pull to the buffet.
flight envelope.
Yeh, OK I understand buffet in relation to loading but the control
deflections have no effect on the onset of buffet? Is that not why you
have a limit when close to mach 1?
Bertie
GPS instead of turn and bank Danny Deger Piloting 52 February 8th 07 02:03 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
Bank Check Aviation Ron R Piloting 68 January 19th 05 01:30 AM
BREAKING THE BANK Cribsheet Piloting 0 December 22nd 04 06:27 PM
key bank CSA722 Piloting 0 July 14th 03 07:04 AM
