#21
What, like a Kitfox?
CH701. There's a guy has his own grass strip just east of Burnet (shows up as Deiterich on the San Anton sectional), he's got a 701 and I hope to go out and take a look at it pretty soon. Just need to find the time. It is very small but it looks quite fun for STOL operations. Only thing about it is that, even though you only need a short space to land in, if you do loose your engine there better be a field within a couple of miles -- glide ratio little better than a piano ... |
You'll get one of those thngs out of anywhere, but if the field is, say,
400 yards or more, you'll get an acrosport in and out of it easily. Even shorter if ou're sharp. Suffice to say I'm pretty excited about the AcroSport, it's performance, and how you can fly it. Plus, it's a fabric covered biplane. How kick azz is that? Well, very. It's a longer term project though. I wonder if you could use a Mazda 13B -- should fit in the weight / hp range. Not many moving parts to break, either. Hmm. Don't know if anybody's done aerobatics with a 13B though. I want to give a shot at plans building the 701. There's a nice set of videos that show quite a bit of the 701 construction sequence from those Canadian guys at Can Zac. I might buy some of it as a kit to save some time though. I suppose these thoughts are way off topic. To bring it back: I know of only one Zenith STOL that had structural failure probably due to flutter as a result of exceeding Vne: somebody dived an 801 at the ground and apprently ripped the wings off on the way down. NTSB report says both pilot and passenger had a good bit of THC in their blood ... only fatalities I know of in the STOL series from Zenith and clearly pilot caused. |
On Dec 26, 6:45 am, Bertie the Bunyip wrote:
WingFlaps wrote in news:7896a421-7658-44d1- : On Dec 26, 5:31 am, Bertie the Bunyip wrote: It's done all the time, but it doesn;t have to be at one end and it doesn't have to be a horn. It also doesn't have to be a 100% balance if the performance doesn't neccesitate it or if the stab or wing is rigid enough for flutter not to be an issue within the speed envelope. But for anythng that goes very fast, you have to have 100% balancing, which means it's statically balanced at the hinge line. Even more than 100% is needed in some common planes (e.g. the Bonanza). In this case a wing roll will be dampened automatically (I think) -I'd guess it makes the plane feel more docile, but perhaps you know this plane and can comment. But I disagree with you about one point, the center of lift of the control surface is still important. I think this is because the control linkages aren't stiff enough to stop a control surface flutter. (I am keeping to the question of control surface flutter and trying to avoid the coupling in of the flying surface the control is attached to.) I think you would agree that if the Cl of the surface were ahead of it's COG control surface flutter would be guaranteed (no linkages would be stiff enough to control it)? I believe that this mode may be excited by the disturbed air flowing through the gap between control surface and wing which slightly reduces the surface lift on one side which then couples into the potential for the flutter. It would be felt as a vibration in the stick whereas a wing flutter _might_ not be felt through the stick at all (esp. if the control surface is 100% balanced!!) Nice to have a bit of flying/tech discussion instead of troll lures. Anthony must be out begging. I was bored. Cheers leads to . I'll agree that normally the Cl will be behind the COG for a typical triangular section control surface but if a dynamically balanced design is sought, the Cl moves much closer to the hinge line and then the COG may not be far enough forward. I'd suspect this might have been a big problem with some early WW1 type rudders that looked to be highly balanced. Don;t think what you're saying about the Cl and the GG realationship of the surface is correct, but I don't know for sure. The way most control surfaces are constructed would pretty much gauruntee that that is the case ( skinny at the back) but it's the wing or stab that is th emore important ingredient there anyway. Yes, I agree that the wing or stab is important -but control surface flutter (maybe more common in models with loose linkages) is bad too. Loss of the elevator is probably a terminal failure. Big flexible surfaces can flutter all by themselves as shown in that clip of the A6 I posted and that might be what you mean about the Cl CG relationship. Yes that's what I'm thinking about. In fact that's one of the reasons that a wing mounted engine is a good idea and why the pods on jet airliners (which have the structural rigidity of Jel-lo) are mounted out in front. The change in CG helps dampen the flutter in the same way as mass balance on an aileron would. A good point, I hadn't thought about engine pylons serving that function. Cheers |
Bravo Two Zero schrieb:
What is rudder flutter ? This is rudder flutter. (Actually, it's aileron flutter, but the principle is the same.) http://www.youtube.com/watch?v=kQI3AWpTWhM I should add that this was a test flight done by the factory test pilot and the wings were reinforced for this test. Standard wings would have fallen off pretty quickly, as you can see in related videos. |
![]() Relative to where it would start unloaded. IOW if you were overspeeding as a result of an unusual attitude recovery and you were pulling like hell at the same time, the flutter would appear at a lower airspeed than it would if you were just in a dive with the wing loaded at 1 G. Both of these speeds should still be over red-line. Ah, I see, that makes it more clear. Interesting how flutter sounds so benign (like a butterfly!) but is actually more like a quick trip to the graveyard. However it must be a rare phenomenon because I never came across the term in my PPL training and I don't remember even seeing this topic discussed in any AOPA article in the last 2 years. |
On Dec 25, 10:45*am, Bertie the Bunyip wrote:
Big flexible surfaces can flutter all by themselves *as shown in that clip of the A6 I posted and that might be what you mean about the Cl CG relationship. In fact that's one of the reasons that a wing mounted engine is a good idea and why the pods on jet airliners (which have the structural rigidity of Jel-lo) are mounted out in front. The change in CG helps dampen the flutter in the same way as mass balance on an aileron would. Bertie, What are you trying to do here? Do you realize that your respectful aviation related post will ruin this list for guys like Jay and his petty abusive OT posts ? FB |
wrote in news:b98d38db-fc5c-4cc8-9272-
: You'll get one of those thngs out of anywhere, but if the field is, say, 400 yards or more, you'll get an acrosport in and out of it easily. Even shorter if ou're sharp. Suffice to say I'm pretty excited about the AcroSport, it's performance, and how you can fly it. Plus, it's a fabric covered biplane. How kick azz is that? Well, very. It's a longer term project though. I wonder if you could use a Mazda 13B -- should fit in the weight / hp range. Not many moving parts to break, either. Hmm. Don't know if anybody's done aerobatics with a 13B though. You could, but It's easier and cheaper to use an airplane engine at the end of the day. Unless it's your "thing" to mess with things like that. If you're just looking to save money, forget it. I want to give a shot at plans building the 701. There's a nice set of videos that show quite a bit of the 701 construction sequence from those Canadian guys at Can Zac. I might buy some of it as a kit to save some time though. Yeah, someone in my group built one fairly quickly. I haven't flown it but I've eyed them up over the years. Not very fast, though. You could prolly get an acrosport cheap enough partly finished or one needing a recover. I suppose these thoughts are way off topic. To bring it back: I know of only one Zenith STOL that had structural failure probably due to flutter as a result of exceeding Vne: somebody dived an 801 at the ground and apprently ripped the wings off on the way down. NTSB report says both pilot and passenger had a good bit of THC in their blood ... only fatalities I know of in the STOL series from Zenith and clearly pilot caused. Yipes.. The only thing I don;t like about those Zenairs is they are very light indeed. That 6061 is beer can stuff really, but the airplanes have a good record, so... You might not need the STOL performance unless you're flying out of your own driveway, though. they're pretty slow.... Bertie |
#29
#30
Can Washout Cause Flutter?? | DonMorrisey | Home Built | 12 | January 19th 07 02:32 AM |
WTD. SGS 2-33 Rudder | [email protected] | Soaring | 0 | December 20th 06 04:31 AM |
Counterweighting to prevent flutter | [email protected] | Home Built | 11 | June 10th 05 03:51 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Tail flutter! | I Can Computer Services | Home Built | 3 | November 24th 03 12:56 AM |
