Hello, Usenet, Jay, Marry, Montblack, And Friends!!!
Since Comcast is so lame and Lost the HF thread will start my own. HF-Box build project, Goal is to simplify next flight T182T to Qatar next week!!! and return airline flight home with equipment not broken. Most all you know what I do for a living fun, fun, fun, :-) yep mostly Single Engine Piston Aircraft Over Oceans it some times requires an HF Radio! Well I got tired of always fumbling with HF wiring Special Flight Permit Allows!! A Power Drop For HF When Tanked!! So I decided to package it all in to one small portable airline carry on size case case. I used a Pelican case just incase I may be harassed and asked to check it as I have in the past (Thanks!! Delta, Virgin, and TSA A-holes) This Case Will Not Be Water Tight It Requires Drilling Holes!!!! Pelican Unconditional Warranty Still Applies Leaving Holes To Min. MADE IN USA WITH GREAT WARRANTY!!! Supply List, Pelican 1450 Case About $75.00 Shipped (No Foam) HF Radio ICOM 706MKIIG 100 Watt $949.00 On Sale Ham Radio Outlet (Remote Mount Kit Required It's UsuallyFree + a $50 to $100 Rebate) Look Here http://www.icomamerica.com/amateur/hf/index.html#706 Automatic Antenna Tuner SGC 237 100 Watt (or 239) $359.00 Astron 24 to 12V Converter 20 Amp 24 Peak About $150.00 2 Nice Size Pieces Of Aluminum ($ Varies Mine Was Donated By Horizon Air Trash Can! Yea, I Dumpster Diving Again!!) A Bunch Of Mics. Items Don't feel like Listing them All Use Your Brain!!! (Jacks PL235 1000UF 25V Cap And 10K Resister, 1 or 2 Computer Fans Etc.) MCM, Norvac, Etc. ($$ Varies) Tools, Tin Snips Left, Right, Straight, Soldering Iron, Solder, Drill And Assorted Bits, Rivet's And Rivnuts...Lots of Heat Shrink, Epoxy, Your Brain, and Harbor Freight If you have a local one!!! (My Case Friends Snap-On Truck & My Own Good Tool Collection) You will need Soldering Skills, An Adult Beverage I Like Whiskey, Kitchen (Aka, Workshop) And AN Understanding Wife!!! For making a Big Mess!!! This Pelican Case will give you enough Space to Pack The Radio, Long Wire Antenna, Tools, And Universal Mounting Hardware Cessna, Piper, Grumman, Etc... Single And Multi All Connections Antenna's. Power, Ground And Control head will be External Mount Quick Connect. Photos Will Be Out Of Numerical Order, The Case, Pelican 1450 Perfect Size About $70.00 No Foam http://www.internationalferryflights...X/S4010546.JPG http://www.internationalferryflights...X/S4010544.JPG Take You Sheet Of Aluminum Cut it To Fit The Bottom Of the Pelican Case. Don't Cut your Fingers....I did not want to use my CNC mill for this to much work to clean the Garage to get to the dam thing. Ok, Mount the Radio Mount To This!!! I Used 1/8" Pop Rivets... http://www.internationalferryflights...X/S4010541.JPG http://www.internationalferryflights...X/S4010542.JPG Verify Fit In Case, Looks Ok! http://www.internationalferryflights...X/S4010545.JPG Remove Frome Case and Mount Radio http://www.internationalferryflights...X/S4010547.JPG http://www.internationalferryflights...X/S4010548.JPG Verify Fit In Case, You want About 1/2 Inch for Cable Clearance On Front Remote Mount Cable. http://www.internationalferryflights...X/S4010549.JPG http://www.internationalferryflights...X/S4010550.JPG Time To Mount The Antenna Tuner, Ok I used scotch bright pads with a right angel die grinder to remove the paint off the bottom of the SGC-237 (No Photo) because if you have not guessed it by now we are using the aluminum sheet as a ground for this project. A good ground with a wire antenna is key for this set up. http://www.internationalferryflights...X/S4010552.JPG Verify Fit In Case, Make Another Adult Beverage!!! http://www.internationalferryflights...X/S4010553.JPG http://www.internationalferryflights...X/S4010554.JPG Find A Spot For Cooling Fan Placement, (I Do Have A Guard For The Fan) http://www.internationalferryflights...X/S4010555.JPG Remove Lid Re Clock 180 Degrees Add Auto Tune Cap & Resister To the Inside Of Tuner At The Terminal Connector. http://www.internationalferryflights...X/S4010559.JPG More Inside the SGC237 http://www.internationalferryflights...X/S4010560.JPG Preview Of Mounting Astron Voltage Converter to lid Of SGC-237 Antenna Tuner, http://www.internationalferryflights...X/S4010557.JPG http://www.internationalferryflights...X/S4010558.JPG Tomorrow!!! Mounting Voltage Converter, And Selector Switch 14v or 28v Systems, Adding External Fuse's, Cutting Top Plate, Adding Antenna And Power Connectors, Airflow Cooling Tests, Etc... You, Want to use Nylon Screws When Mounting the Astron Voltage Converter dure to the High Voltage In The Antenna Tuner. This box is nowhere done I may find problems and Issues along the way and correct...will post trial and error. I will try and be strait fwd as possible.. All input will be accepted. Used?? BBL!!! Photo's Of Diesel 182 Coming Soon Trip to Tanzania is Delayed Due to FAA B.S. Supplemental Type Cert Update From SMA!!! Oops!!! OH!! Jay, You Will get To see the Tanzinia Bird, Tanked and all when I stop by for a night at my favorite hotel..... What room do I wanna stay in this time? Lets See if I can sleep in them all by 2009 hahaha !! |
Portable/handheld radio | Danny Deger | Piloting | 15 | February 22nd 07 05:10 PM |
Portable Radio | Waduino | Soaring | 12 | September 14th 05 06:36 PM |
Portable radio scanners | Casey Wilson | Piloting | 1 | August 1st 05 02:05 PM |
Portable XM Radio receiver in the cockpit? | Peter R. | Piloting | 13 | September 4th 04 03:46 AM |
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO | Ron | Restoration | 0 | October 26th 03 12:02 AM |
