#21
On Jan 28, 12:04 pm, Larry Dighera wrote:
Is Branson going to certify White Knight Two and SpaceShipTwo? I believe the FAA has issued rules allowing private suborbital spacecraft to carry paying passengers using a launch license rules rather than aircraft certification. Essentially, launch licenses only require the operator to certify that the uninvolved public will not be unduly put in danger by the flight- they do *not* require the operator to prove that the passengers will not be endangered. I believe there's a requirement that the pax sign releases saying that they understand the terms under which the flight is being conducted, but I could be wrong. There was actually a fairly big argument in the nascent suborbital passenger community a few years ago as to whether suborbital operations should be covered under certification or launch licenses. Burt Rutan (designer of the WK/SS1 system) actually wanted to implement something akin to certification, arguing that the new industry had to be safe for passengers or it would never get off the ground. Most other would-be suborbital operators disagreed, arguing that there was not enough data currently available on suborbital ops to even define what certification standards should be in that regime, let alone determine whether or not their vehicles met those standards, and that if they were required to certify their vehicles it would effectively strange the industry in its cradle by delaying revenue- producing flights for too long. The launch license guys have won out for the moment, although I believe there's a Congressman who keeps trying to legislatively change the rules. -JTD |
On 28 Jan, 18:25, Bertie the Bunyip wrote:
Larry Dighera wrote : Is Branson going to certify White Knight Two and SpaceShipTwo? You are dead inside, Larry. Dead Bertie Pure class! You are of course a right Royal Pain in the Ass. But worth it:-) |
On Mon, 28 Jan 2008 17:04:14 GMT, Larry Dighera
wrote: Is Branson going to certify White Knight Two and SpaceShipTwo? Shareholders? http://www.heraldtribune.com/article...0838/-1/HELP07 NEW YORK -- A select group of rich tourists may be blasting into space within a few years in a craft that developers say is about 70 percent complete. British billionaire Richard Branson and the aerospace designer Burt Rutan on Wednesday unveiled a model of SpaceShipTwo, the vehicle they hope will be able to take passengers about 62 miles above Earth for the fun of it, with test flights possibly beginning this year. ... About 200 prospective passengers from 30 countries have made reservations, shelling out $200,000 each. But: http://www1.airweb.faa.gov/REGULATOR...6?OpenDocument Part 91 GENERAL OPERATING AND FLIGHT RULES Subpart D--Special Flight Operations Sec. 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate-- (1) For other than the purpose for which the certificate was issued; or -- (2) Carrying persons or property for compensation or hire. (b) No person may operate an aircraft that has an experimental certificate outside of an area assigned by the Administrator until it is shown that-- (1) The aircraft is controllable throughout its normal range of speeds and throughout all the maneuvers to be executed; and (2) The aircraft has no hazardous operating characteristics or design features. (c) Unless otherwise authorized by the Administrator in special operating limitations, no person may operate an aircraft that has an experimental certificate over a densely populated area or in a congested airway. The Administrator may issue special operating limitations for particular aircraft to permit takeoffs and landings to be conducted over a densely populated area or in a congested airway, in accordance with terms and conditions specified in the authorization in the interest of safety in air commerce. (d) Each person operating an aircraft that has an experimental certificate shall-- (1) Advise each person carried of the experimental nature of the aircraft; (2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator; and (3) Notify the control tower of the experimental nature of the aircraft when operating the aircraft into or out of airports with operating control towers. [(e) No person may operate an aircraft that is issued an experimental certificate under §21.191 (i) of this chapter for compensation or hire, except a person may operate an aircraft issued an experimental certificate under §21.191 (i)(1) for compensation or hire to- (1) Tow a glider that is a light-sport aircraft or unpowered ultralight vehicle in accordance with §91.309; or (2) Conduct flight training in an aircraft which that person provides prior to January 31, 2010. (f) No person may lease an aircraft that is issued an experimental certificate under §21.191 (i) of this chapter, except in accordance with paragraph (e)(1) of this section. (g) No person may operate an aircraft issued an experimental certificate under §21.191 (i)(1) of this chapter to tow a glider that is a light-sport aircraft or unpowered ultralight vehicle for compensation or hire or to conduct flight training for compensation or hire in an aircraft which that persons provides unless within the preceding 100 hours of time in service the aircraft has- (1) Been inspected by a certificated repairman (light-sport aircraft) with a maintenance rating, an appropriately rated mechanic, or an appropriately rated repair station in accordance with inspection procedures developed by the aircraft manufacturer or a person acceptable to the FAA; or (2) Received an inspection for the issuance of an airworthiness certificate in accordance with part 21 of this chapter. (h) The FAA may issue deviation authority providing relief from the provisions of paragraph (a) of this section for the purpose of conducting flight training. The FAA will issue this deviation authority as a letter of deviation authority. (1) The FAA may cancel or amend a letter of deviation authority at any time. (2) An applicant must submit a request for deviation authority to the FAA at least 60 days before the date of intended operations. A request for deviation authority must contain a complete description of the proposed operation and justification that establishes a level of safety equivalent to that provided under the regulations for the deviation requested. (i) The Administrator may prescribe additional limitations that the Administrator considers necessary, including limitations on the persons that may be carried in the aircraft.] -- Posted via a free Usenet account from http://www.teranews.com |
Larry Dighera wrote: But that doesn't address Sec. 91.319's prohibition against flying paying passengers in experimental aircraft, does it? You just have to get a letter authorizing the carrying of paying passengers. The Collings Foundation B-24J is licensed in the experimental category yet is allowed to carry paying passengers. |
Dale wrote:
In article , Larry Dighera wrote: But that doesn't address Sec. 91.319's prohibition against flying paying passengers in experimental aircraft, does it? You just have to get a letter authorizing the carrying of paying passengers. The Collings Foundation B-24J is licensed in the experimental category yet is allowed to carry paying passengers. Passengers can pay for fuel and maintenance costs. The rest goes for training. |
On Tue, 29 Jan 2008 19:18:27 -0800, "Marc J. Zeitlin"
wrote in : Larry Dighera wrote: So it would seem that the operator of an ostensibly uncertified aircraft, that can truly be considered experimental in my opinion, is authorized by the FAA to "verify" the spacecraft is safe for flight. Yes, with a substantial amount of FAA/AST oversight and signoff of the analysis/verification. But that doesn't address Sec. 91.319's prohibition against flying paying passengers in experimental aircraft, does it? While the aircraft (mothership) is certificated in the experimental R&D category, no paying passengers will be carried. Once the Launch License is granted (after testing as Exp. R&D and further testing with a Launch Permit) the paying passengers can be carried ONLY WHILE ON A LAUNCH MISSION under the Launch License - NOT under the Exp. R&D certificate. I suppose the rational for this policy of somewhat lower standards for spacecraft is due to the limited technical information available to would be certifiers and their limited experience in this field, the uniqueness of each vehicle, and the desirability to foster growth in the fledgling, domestic space flight marketplace. Also, it would appear that Sec. 91.319 is concerned with the safety of those over whom experimental aircraft fly. Spacecraft operations obviate that issue, as they are restricted to spaceports, IIUC. Thank you for your input. Are you affiliated with the space flight industry? |
![]() "Marc J. Zeitlin" wrote I work for Scaled on the Spaceship/Mothership project, currently. he says, modestly. To be slightly more accurate, he is one of the top, key members of the team. Anything he says about what goes on at Scaled, if coming right (almost) from the horse's mouth. He knows of what he speaks. I am thankful you stop in, occasionally. If I ever get a chance, I'll buy you a beer or three. g -- Jim in NC |
#29
On Wed, 30 Jan 2008 17:38:27 -0800, "Marc J. Zeitlin"
wrote in : Larry Dighera wrote: ... Are you affiliated with the space flight industry? I work for Scaled on the Spaceship/Mothership project, currently. So do the Commercial Space Transportation Regulations http://www.faa.gov/about/office_org/headquarters_offices/ast/regulations/ supercede the Part 91 regulations, or augment them? |
#30
Larry Dighera wrote in
: On Wed, 30 Jan 2008 17:38:27 -0800, "Marc J. Zeitlin" wrote in : Larry Dighera wrote: ... Are you affiliated with the space flight industry? I work for Scaled on the Spaceship/Mothership project, currently. So do the Commercial Space Transportation Regulations http://www.faa.gov/about/office_org/.../ast/regulatio ns/ supercede the Part 91 regulations, or augment them? DEAD! Bertie |
Experimental aircraft and towing | Marc Ramsey | Soaring | 8 | January 28th 17 08:23 AM |
Can Branson Charge For Flights In An Experimental Aircraft? | Larry Dighera | Piloting | 32 | January 31st 08 10:53 PM |
Flying Club with Experimental Aircraft | Jeff | Home Built | 6 | October 5th 05 09:16 PM |
Financing for Experimental Aircraft | James Keane | Owning | 2 | September 1st 04 02:18 AM |
Experimental Aircraft Pictures | Jay Honeck | Piloting | 0 | December 5th 03 10:12 PM |
