Can Branson Charge For Flights In An Experimental Aircraft?
Old January 28th 08, 05:04 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
Default Can Branson Charge For Flights In An Experimental Aircraft?
Is Branson going to certify White Knight Two and SpaceShipTwo?
http://www.heraldtribune.com/article...0838/-1/HELP07
NEW YORK -- A select group of rich tourists may be blasting into
space within a few years in a craft that developers say is
about 70 percent complete.
British billionaire Richard Branson and the aerospace designer
Burt Rutan on Wednesday unveiled a model of SpaceShipTwo, the
vehicle they hope will be able to take passengers about 62 miles
above Earth for the fun of it, with test flights possibly
beginning this year. ...
About 200 prospective passengers from 30 countries have made
reservations, shelling out $200,000 each.
But:
http://www1.airweb.faa.gov/REGULATOR...6?OpenDocument
Part 91 GENERAL OPERATING AND FLIGHT RULES
Subpart D--Special Flight Operations
Sec. 91.319
Aircraft having experimental certificates: Operating limitations.
(a) No person may operate an aircraft that has an experimental
certificate--
(1) For other than the purpose for which the certificate was
issued; or
-- (2) Carrying persons or property for compensation or hire.
(b) No person may operate an aircraft that has an experimental
certificate outside of an area assigned by the Administrator until
it is shown that--
(1) The aircraft is controllable throughout its normal range of
speeds and throughout all the maneuvers to be executed; and
(2) The aircraft has no hazardous operating characteristics or
design features.
(c) Unless otherwise authorized by the Administrator in special
operating limitations, no person may operate an aircraft that has
an experimental certificate over a densely populated area or in a
congested airway. The Administrator may issue special operating
limitations for particular aircraft to permit takeoffs and
landings to be conducted over a densely populated area or in a
congested airway, in accordance with terms and conditions
specified in the authorization in the interest of safety in air
commerce.
(d) Each person operating an aircraft that has an experimental
certificate shall--
(1) Advise each person carried of the experimental nature of the
aircraft;
(2) Operate under VFR, day only, unless otherwise specifically
authorized by the Administrator; and
(3) Notify the control tower of the experimental nature of the
aircraft when operating the aircraft into or out of airports with
operating control towers.
[(e) No person may operate an aircraft that is issued an
experimental certificate under §21.191 (i) of this chapter for
compensation or hire, except a person may operate an aircraft
issued an experimental certificate under §21.191 (i)(1) for
compensation or hire to-
(1) Tow a glider that is a light-sport aircraft or unpowered
ultralight vehicle in accordance with §91.309; or
(2) Conduct flight training in an aircraft which that person
provides prior to January 31, 2010.
(f) No person may lease an aircraft that is issued an experimental
certificate under §21.191 (i) of this chapter, except in
accordance with paragraph (e)(1) of this section.
(g) No person may operate an aircraft issued an experimental
certificate under §21.191 (i)(1) of this chapter to tow a glider
that is a light-sport aircraft or unpowered ultralight vehicle for
compensation or hire or to conduct flight training for
compensation or hire in an aircraft which that persons provides
unless within the preceding 100 hours of time in service the
aircraft has-
(1) Been inspected by a certificated repairman (light-sport
aircraft) with a maintenance rating, an appropriately rated
mechanic, or an appropriately rated repair station in accordance
with inspection procedures developed by the aircraft manufacturer
or a person acceptable to the FAA; or
(2) Received an inspection for the issuance of an airworthiness
certificate in accordance with part 21 of this chapter.
(h) The FAA may issue deviation authority providing relief from
the provisions of paragraph (a) of this section for the purpose of
conducting flight training. The FAA will issue this deviation
authority as a letter of deviation authority.
(1) The FAA may cancel or amend a letter of deviation authority at
any time.
(2) An applicant must submit a request for deviation authority to
the FAA at least 60 days before the date of intended operations. A
request for deviation authority must contain a complete
description of the proposed operation and justification that
establishes a level of safety equivalent to that provided under
the regulations for the deviation requested.
(i) The Administrator may prescribe additional limitations that
the Administrator considers necessary, including limitations on
the persons that may be carried in the aircraft.]
Old January 28th 08, 07:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
cavalamb himself[_2_]
When has FAA ever been involved space craft systems?
Old January 28th 08, 05:31 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Gig 601XL Builder[_2_]
Damn now I have to back up Larry.
http://www.faa.gov/about/office_org/...e_flight_reqs/
Old January 28th 08, 05:54 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
On Mon, 28 Jan 2008 11:31:55 -0600, Gig 601XL Builder
wrote in
The regulations also establish requirements for crew notification,
medical qualifications and training, as well as requirements
governing environmental control and life support systems. They
also require a launch vehicle operator to verify the integrated
performance of a vehicles hardware and any software in an
operational environment. An operator must successfully verify the
integrated performance of a vehicle's hardware and any software in
an operational flight environment before allowing any space flight
participant on board. Verificatioin [sic] must include flight
testing.
So it would seem that the operator of an ostensibly uncertified
aircraft, that can truly be considered experimental in my opinion, is
authorized by the FAA to "verify" the spacecraft is safe for flight.
But that doesn't address Sec. 91.319's prohibition against flying
paying passengers in experimental aircraft, does it?
Old January 28th 08, 06:26 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bertie the Bunyip[_22_]
Larry Dighera wrote in
wrote in
http://www.faa.gov/about/office_org/...ast/human_spac
e_flight_reqs/
testing.
Oh you better get out to Mojave and warn Burt about this, Lar.
Don't forget to bring your speed gun.
Bertie
Old January 29th 08, 07:24 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Dale[_3_]
You just have to get a letter authorizing the carrying of paying
passengers. The Collings Foundation B-24J is licensed in the
experimental category yet is allowed to carry paying passengers.
Old January 29th 08, 11:52 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Passengers can pay for fuel and maintenance costs.
The rest goes for training.
Old January 28th 08, 08:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Ahh! Just last year...
Old January 28th 08, 05:51 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steven P. McNicoll
"cavalamb himself" wrote in message
From the start.
Old January 28th 08, 05:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steve Foley
From the start.
Did the Soviets check with the FAA when they launched Sputnik?
Experimental aircraft and towing Marc Ramsey Soaring 8 January 28th 17 08:23 AM
Can Branson Charge For Flights In An Experimental Aircraft? Larry Dighera Piloting 32 January 31st 08 10:53 PM
Flying Club with Experimental Aircraft Jeff Home Built 6 October 5th 05 09:16 PM
Financing for Experimental Aircraft James Keane Owning 2 September 1st 04 02:18 AM
Experimental Aircraft Pictures Jay Honeck Piloting 0 December 5th 03 10:12 PM
