An Air Canada DC-8 crashed in 1970 because spoilers were deployed
before landing, which "by the book" is a definite no-no (cf. Air Canada 621 disaster). How come the first officer (with over 5500 hrs with that type of aircraft) made such a decision to deploy spoilers while still in the air? What else, when full flaps and idle power aren't enough, can a pilot use to handle a too high/too fast final approach if not deploy spoilers? As a side question, what is the functional difference between spoilers and airbrakes? |
Hi,
In article , wrote: As a side question, what is the functional difference between spoilers and airbrakes? Just read that section of the book for my PPL exam. I *think* that spoilers can be used differentially for roll control, whereas speedbrakes both pop up together so can't control roll. But I'm probably wrong ![]() Andy |
![]() "Andy Hawkins" wrote in message ... Hi, Just read that section of the book for my PPL exam. I *think* that spoilers can be used differentially for roll control, whereas speedbrakes both pop up together so can't control roll. But I'm probably wrong ![]() Andy, Spoilers deploy together symmetrically. What you are thinking of are Spoilerons. Spoilerons come into play at slower speeds (typically when the flaps are deployed beyond a certain point) to improve roll control at slower airspeeds. Instead of the spoiler panels coming up symmetrically on both wings to kill lift, only the panel on the wing with the "up" aileron will deploy. Next time you are in an airliner watch the aileron/spoileron panels work together at slower speeds. When the aileron moves up the corresponding spoileron panel will move with it. Mish |
work together at slower speeds. When the aileron moves up the corresponding spoileron panel will move with it. Aren't spoilerons ailerons that can move UP together, killing lift? Bartek |
and airbrakes? Spoilers reduce lift. Speed brakes create drag. ...and each might do a little of both. Bob F. |
Amine wrote:
An Air Canada DC-8 crashed in 1970 because spoilers were deployed before landing, which "by the book" is a definite no-no (cf. Air Canada 621 disaster). How come the first officer (with over 5500 hrs with that type of aircraft) made such a decision to deploy spoilers while still in the air? What else, when full flaps and idle power aren't enough, can a pilot use to handle a too high/too fast final approach if not deploy spoilers? Go around. -- Dudley Henriques |
"Dudley Henriques" wrote in message ...
Amine wrote: An Air Canada DC-8 crashed in 1970 because spoilers were deployed before landing, which "by the book" is a definite no-no (cf. Air Canada 621 disaster). How come the first officer (with over 5500 hrs with that type of aircraft) made such a decision to deploy spoilers while still in the air? What else, when full flaps and idle power aren't enough, can a pilot use to handle a too high/too fast final approach if not deploy spoilers? Go around. -- Dudley Henriques My thought exactly! |
On Feb 7, 3:35 pm, Dudley Henriques wrote:
Go around. Well, let's play the devil's advocate... What if you can't go around? (E.g. because of engine failure or in a glider). I mean, I understand why you don't want to deploy spoilers if you're below minimums or if you're flirting with stall speed. But if you're well above minimums, with no risk of stalling, I don't see any reason why you shouldn't use spoilers to bleed the extra momentum/altitude. The only disadvantage would be that the final approach will be steeper and thereby would not have the elegance of the perfect glide slope. But that's seems to be more a matter of taste (and possibly performance) than an actual safety issue. After all, the "no-spoiler-in-midair"dogma isn't built in the design of the pilot interface. If there truly was a physical reason why spoilers should not come out in the air, it would have been an engineering requirement to systematically disable their mechanism unless, say, the gear is down and the wheels rolling. |
On Feb 8, 6:57*am, Amine wrote:
Go around. Well, let's play the devil's advocate... What if you can't go around? (E.g. because of engine failure or in a glider). I mean, I understand why you don't want to deploy spoilers if you're below minimums or if you're flirting with stall speed. But if you're well above minimums, with no risk of stalling, I don't see any reason why you shouldn't use spoilers to bleed the extra momentum/altitude. The only disadvantage would be that the final approach will be steeper and thereby would not have the elegance of the perfect glide slope. But that's seems to be more a matter of taste (and possibly performance) than an actual safety issue. This paragragh has several misconceptions as it relates to the OP. First, An engine out missed in a DC8 or even a two engine jet is doable and it is practiced all the time in the sim. Spoiler usage in sailplanes is a completely different kettle of fish and it is normal to use them into the touchdown in most ships. The crash discused in the OP happened many years ago and it has been standard in the industry as long as I can remember (I go back 20 years) to be on glidpath, on speed, and fully configured with the landing checklist complete by 1000 AGL (An exception to this is that in VMC you dont have to be on speed but you must be slowing). No Ifs or Buts. The use of spoilers below certain RAs and past certain flap settings is prohibited in the Boeing products and you would be hard pressed to find both a captain and fo who would ignore operating limitations. So its not just a mater of taste. . If there truly was a physical reason why spoilers should not come out in the air, it would have been an engineering requirement to systematically disable their mechanism unless, say, the gear is down and the wheels rolling. Actually, this is the way it works. Only some of the spoilers deploy inflight (Either through the spoiler handle or the Aileron/Spoiler mixer ). The rest of the spoilers will not deploy until the plane is on the ground. F Baum |
On Fri, 8 Feb 2008 07:40:33 -0800 (PST), "F. Baum"
wrote: . If there truly was a physical reason why spoilers should not come out in the air, it would have been an engineering requirement to systematically disable their mechanism unless, say, the gear is down and the wheels rolling. Actually, this is the way it works. Only some of the spoilers deploy inflight (Either through the spoiler handle or the Aileron/Spoiler mixer ). The rest of the spoilers will not deploy until the plane is on the ground. Or an airspeed lockout. If memory serves they won't deploy, even for roll assistance, above a certain speed either. Don't they also deflect at different angles depending on what system is activating them? Highest angle off the wing is for full in-flight spoiler handle (and some don't even come up for that), inboard segments deflect at a greater angle than outboards for roll assistance (which is about 1/2 the angle off the wing compared to full spoiler), and everything comes up at full for weight-on-wheels spoiler system? |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Open Spoilers Alarm on tow | tango4 | Soaring | 12 | March 17th 04 06:18 PM |
Spoilers on Laister Nugget? | Stewart Kissel | Soaring | 1 | January 28th 04 12:47 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
