Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 17th 08, 02:51 AM posted to rec.aviation.ifr
Sam Spade
Default Garmin 430 rquestion- does the approach always have to be activatedvia "activate approach"?
John Collins wrote:
When an approach is loaded, it is appended to the flight plan after the
destination airport. As stated earlier, the waypoints in the original flight
plan will sequence normally until the destination airport is reached, at
which time the 430 will navigate direct to the IAF waypoint and
automatically "activate" the approach sequence.
To cut to the chase, those of us familiar with using FMSes know to clear
the destination airport from the flight plan once the approach is
loaded. In a full-press FMS, this is known as a route-discontinuity.
And, clearing that discontinuity in a full-press FMS or a Garmin panel
mount will get it all to work as a flight plan with continuity.
Old February 17th 08, 03:05 AM posted to rec.aviation.ifr
Sam Spade
John Collins wrote:
Sam, This is
necessary when the controller clears the pilot direct-to an IF (Intermediate
Fix) that is not an IAF.
When is an IF also an IAF and what do you do then?
Old February 17th 08, 04:45 AM posted to rec.aviation.ifr
Stan Prevost
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
"Sam Spade" wrote in message
flight plan will sequence normally until the destination airport is
reached, at which time the 430 will navigate direct to the IAF waypoint
and automatically "activate" the approach sequence.
the destination airport from the flight plan once the approach is loaded.
In a full-press FMS, this is known as a route-discontinuity. And, clearing
that discontinuity in a full-press FMS or a Garmin panel mount will get it
On a GNS430, activating the loaded approach is simpler. PROC, ENTER.
Old February 17th 08, 09:44 AM posted to rec.aviation.ifr
Thomas Borchert
Sam,
loaded.
Ah, now I see. As STan says, activating is easier on the 430, IMHO.
Thomas Borchert (EDDH)
Thomas Borchert
John,
Thanks, that was just my understanding, too.
Old February 17th 08, 01:09 PM posted to rec.aviation.ifr
Sam Spade
the destination airport. As stated earlier, the waypoints in the
original flight plan will sequence normally until the destination
airport is reached, at which time the 430 will navigate direct to the
IAF waypoint and automatically "activate" the approach sequence.
clear the destination airport from the flight plan once the approach
is loaded. In a full-press FMS, this is known as a
route-discontinuity. And, clearing that discontinuity in a full-press
FMS or a Garmin panel mount will get it all to work as a flight plan
with continuity.
Like many things, there is more than one way to skin the cat with a Garmin.
Old February 17th 08, 01:10 PM posted to rec.aviation.ifr
Sam Spade
Thomas Borchert wrote:
Sam,
loaded.
Could be. Some shave with one hand, some with the left, others with
both. ;-)
Old February 17th 08, 01:13 PM posted to rec.aviation.ifr
Sam Spade
John Collins wrote:
An Intermediate Fix may also be an Initial Approach Fix.
A typical example is a T style approach, where both the right base and the
left base ends are IAFs and the top center of the T is an IF, but not an
IAF. See http://204.108.4.16/d-tpp/0802/05726R5.PDF
There are numerous examples of the top center being both an IF and an IAF.
See http://204.108.4.16/d-tpp/0802/05683R28.PDF
When an IF is also an IAF, you can select the IF(IAF) in the select approach
dialog.
Actually, it is only (and always) when it has a hold-in-lieu course
reversal.
Next question: If a controller clears you directly to an IF/IAF do you
always disregard the hold-in-lieu course reversal and go straight-in?
  #29
Old February 17th 08, 01:51 PM posted to rec.aviation.ifr
Sam Spade
with continuity.
I took another look at it and disagree. Once the IAP is selected
removing the airport can be done prior to a critical phase of flight,
then everything sequences without pilot intervention.
  #30
Old February 17th 08, 03:08 PM posted to rec.aviation.ifr
Mitty
On 2/17/2008 8:57 AM, John Collins wrote the following:
Regardless,
The pilot should be prepared to fly direct to the non IAF type IF to join
the approach.
Yes, and I'm not sure why this is such a big deal here. It's the same thing you
do on any reroute. Just add the IF to the flight plan and activate that leg.
It doesn't matter whether there is an approach farther down the list or not.
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 03:45 AM
