Battery 6ah vs. more
Old April 24th 08, 09:51 PM posted to rec.aviation.soaring
SoaringXCellence
Default Battery 6ah vs. more
On Apr 24, 1:28*pm, Marc Ramsey wrote:
Sorry, didn't mean to start an argument. Maybe my caution regarding
flying with R/C (foil bag) LiPo batteries is a little over the top. I
can live with erring on the side of caution. To each his own.
I'm not trying to get into an argument either, just making the point
that most of us already carry several foil bag lithium polymer batteries
in our gliders. *The original metal case lithium ion batteries haven't
been used in consumer products for years, mostly because we want
everything light (remember 8 lb laptops?).
R/C batteries have a high (explosive 8^) failure rate mostly due to the
various kinds of abuse they are subject to, incorrect charging,
continued use after being damaged in crashes, overly high discharge
rates, full short circuits, etc. *If someone knows what they are doing,
there shouldn't be a problem. *But, I agree, if you don't know, don't do
it. *I, for one, wouldn't want a pack large enough *to power a radio and
transponder in my glider...
Marc
I have done the RC thing for over 45 years. I've observed that as the
use of LiPo cells have progressed the rate of failure has decreased.
Inspite of that I would also either use a metal cased cells or a pack
in a metal box if I were to use them in an aviation application.
Istalled in the PDA or Cell phone they have some puncture protection
and that seems to be one of the major hazards to their use.
On the same idea; the A123systems cells are metal cased and at $110
for six (2.3 Ah) of them is a pretty good deal as far as lithium cells
go. I'm planning on getting several "Developer Kits" to assemble
several packs for the glider. Four cells, each a little larger than a
AA Alkaline, means that I can get a pretty good serial/parallel
battery setup and fit the individual battery packs into small
spaces.
The BIG handicap is the cost; to assemble 3 packs will cost $220 plus
assembly and wiring, for a 7.2AH pack.
Old April 25th 08, 01:52 AM posted to rec.aviation.soaring
Bill Daniels
"SoaringXCellence" wrote in message
in our gliders. The original metal case lithium ion batteries haven't
rates, full short circuits, etc. If someone knows what they are doing,
there shouldn't be a problem. But, I agree, if you don't know, don't do
it. I, for one, wouldn't want a pack large enough to power a radio and
Marc
spaces.
It would be cheaper to buy a pair of DeWalt 36V LiFePo4 power tool batteries
from eBay for around $150. Each pack contains 10 A123 Systems 3.6V 2.3AH
cells. A 4x5 pack would be a nice 14.4V, 11.5AH glider battery.
Bill D
Old April 25th 08, 03:41 AM posted to rec.aviation.soaring
sisu1a
Marc
spaces.
Bill D
Here's another source for LiFePo cells, that offer pre-fab batteries
of higher density/$ ($200/10AH as opposed to $220/7AH + assembly/
wiring) for although they claim not to be able to take on any new
customers, I bet they could be talked into coming off some:
http://www.powerstream.com/LLL.htm
Paul Hanson
Udo
I want to second Bill's comment.
A123 cells are also "much less" sensitive to charging error, as well
they can be discharged at a higher rate. They are 20% heavier
everything else being equal then the Polymer cells. They have no
memory and 1000 plus cycles. The last I heard the Dewalt pack of 10
cells can be had for about $100.00 but that was six month ago.
Udo
I have done the RC thing for over 45 years. *I've observed that as the
go. *I'm planning on getting several "Developer Kits" to assemble
several packs for the glider. *Four cells, each a little larger than a
spaces.
from eBay for around $150. *Each pack contains 10 A123 Systems 3.6V 2.3AH
cells. *A 4x5 pack would be a nice 14.4V, 11.5AH glider battery.
Bill D- Hide quoted text -
- Show quoted text -
Old April 25th 08, 04:09 AM posted to rec.aviation.soaring
sisu1a
Here is a great resource site for info on converting DeWalt batteries:
http://www.slkelectronics.com/DeWalt/index.htm There is lots of
useful info that could potentially save someone from doing something
unintentional and unfortunate.
Paul
Old April 25th 08, 07:07 AM posted to rec.aviation.soaring
nimbusgb
Udo
spaces.
http://www.lange-aviation.com/htm/en...ry_system.html
Antares flys on Lithium Ion batteries. I have no problem with my light
current draw, aluminium boxed, low current consumption LiPo pack that
is always within eyesight in the cockpit.
At worst I can stuff it out of the clear view panel!
Ian
Battery Connectors Paul Remde Soaring 1 September 15th 06 09:46 PM
battery self-destruct [email protected] Owning 13 June 13th 06 11:04 PM
Battery Source Mike the Strike Soaring 81 October 28th 05 12:46 AM
Battery Chargers Stan Amyett Soaring 2 March 12th 04 05:27 AM
2-33 battery installation Kurt Soaring 2 January 27th 04 01:36 PM
