2-33 battery installation
Old January 25th 04, 04:57 PM
Kurt
Default 2-33 battery installation
We are going to install a panel mount radio etc. in our 2-33. Where
is a good place to mount the battery? We want to be able to remove it
easily for charging.
Thanks
Kurt
Old January 25th 04, 05:53 PM
BTIZ
One consideration would be aft of the front seat.. on a cross member..
forward of the rear stick, attached to the front seat back, be sure to
provide a suitable battery box, and check that the rear stick movement is
not limited by the box. That means it will have to be low, on the floor.
Also forward of the stick will help protect it from the rear seat pax (CFIG)
boots on entry and exit.
The thinking here is to not put to much weight forward, it's a CG issue,
placing a battery forward near or over the current ballast box just ads to
forward CG when flying heavy front seat pax or students..
Another thought is to build a battery box up behind the rear seat, behind
the head liner. The problem there is you are constantly removing the fragile
plastic to get to the battery unless you have a hanger and power system to
be able to recharge the battery without removing it.
Would like to see what you come up with.
BT
"Kurt" wrote in message
om...
Thanks
Kurt
Equipment Installation Stan Prevost Owning 0 November 16th 04 05:28 PM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
