Some time ago there was a discussion about influence of (thin) airfoil on
climb performance of sailplane. I am not a regular reader of the group, so my post is slightly delayed. Influence of airfoil characteristics on climb performance and final cross-country speed was the main objective studied during design of Diana-2 sailplane. The paper on this subject was presented at OSTIV Congress and published in Technical Soaring. The paper can be download now from http://www.dianasailplanes.com/Tech_Soar_KK.pdf May be someone will find it interesting. In my opinion there is nearly no room for further improvement of sailplane performance measured by e.g. max. L/D. But there is a relatively large space for improving final cross-country speed by better utilization of thermals. Diana-2 was just an attempt to perform this. Krzysztof Kubrynski |
![]() In my opinion there is nearly no room for further improvement of sailplane performance measured by e.g. max. L/D. Wow, how many times has THAT old line embarrassed someone in the past? (rhetorical..) Perhaps this may be true for CURRENT traditional materials and established dogma, but besides Windward Performance (who now has the DuckHawk turning from a 'paper airplane' to a flying machine) who makes eintire gliders out of PREPREG carbon, you will only find an occasional aileron or rudder made out of this VERY UNDERUTILIZED spaceage material. Considering that prepregs have appx double the strength of the traditional wet layup construction that just about every composite glider is made with (including the lovely Dianna 2), I see much room for improvement in ALL aspects of soaring performance enhancement. And this is even with materials that have already been discovered (but as mentioned, other than some fancy trim parts have been studiously ignored by 'most' designers). In case the significance of what double the strength to weight ratio means when applied to sailplane structures is not grasped by someone out there, it is this: The structural minimum just got that much closer to the aerodynamic optimum. Personally, I see no end to improvements since our materials will continue to advance, thus continuing to push the all important structural minimum closer to that (also ever advancing) theoretical aerodynamic optimum. How about once carbon nanotube fabric is available, then in prepreg form? Still no room for improvement then? Paul Hanson "Free your mind and your a$$ will follow"--George Clinton |
Paul -
You're missing out on a key point: Changing materials to a lighter structure does not change the aerodynamics of the wing. It changes the wing-loading - but that's no different from adding or removing water ballast. As long as the wing SHAPE remains the same, a different weight/wing-loading simply shifts the polar. It doesn't create an improvement. Wing efficiency is affected by the shape of the airfoil, the wing planform (and how the two add together to become a total 3-d package), the smoothness of the skin/surface, the surface-area/skin drag, and numerous other smaller factors. Existing composite materials can be made to follow complex curves and result in an extremely smooth surface, so changing to a fancier material does nothing to improve the efficiency of the wing. The reason that Pre-Preg and other fancy/costly exotic materials aren't commonly in use is because they aren't NEEDED to achieve aerodynamic optimums. Fancy materials are mostly used for manufacturing reasons, to carry higher loads, to have more specific stiffness in a particular load direction, etc. Aerodynamics doesn't enter into the equation. Small, incremental advances in overall performance have been made over the last 20 years; but they are pretty tiny in comparison to the performance jumps that were seen from the 50's to the late 70's (when glide ratios doubled or tripled). We're down to the point where we're fighting physics every step of the way in order to see any improvements. And in order for theoretical gains to be realized in actual flight, the tolerances are getting so tight that normal manufacturing techniques cannot be applied. And with tolerances that tight you also end up fighting the fact that the air gliders move through is not sitting still. At some point the turbulence and natural air movement disrupts the pristine theoretical predictions of how the air will behave as the sailplane passes through it, rendering supposed performance gains null (and in some cases causing an actual performance penalty - see the part of the Diana 2 paper where they talk about lift minimums in certain airfoils at high Cl). Take care, --Noel |
P.S. Note that in the paper that they talk about little improvement
in basic airfoils or passive boundary layer control. They leave the door open to performance improvements via active boundary layer control methods (turbulators, Sinha's "de-turbulator" tape, etc). The trick to active boundary layer control is in making it both reliable and efficient over the wide speed band and aerodynamic conditions that sailplanes fly. |
On May 5, 9:23 am, "noel.wade" wrote:
Paul - You're missing out on a key point: Changing materials to a lighter structure does not change the aerodynamics of the wing. I did not miss the original point, I just don't agree with it. Clearly you miss mine though. If structure does not change the aerodynamics of a wing, then why are modern hot ships still made of wood, or metal? The fact of the matter is that the aerodynamic optimum will never agree with the structural minimum, but the more that materials advance, the closer to that optimum designers can get. It most certainly does affect the areodynamics of a wing, so long as the wing is designed specific to the materials it is made from. It changes the wing-loading - but that's no different from adding or removing water ballast. As long as the wing SHAPE remains the same, a different weight/wing-loading simply shifts the polar. It doesn't create an improvement. Huh? Wing loading? Again, you are way off my point. Advances in structure ALLOWS changes in shape, which most certainly can lead to improvement. Any racing ship will have the ability to change it's wing loading with ballast, but since we're on the subject of wing loading, by using prepreg your dry weight can be significantly lower, thus 'possibly' allowing a wider range in wing loading and thus a ship adaptable to a wider range of conditions. Wing efficiency is affected by the shape of the airfoil, the wing planform (and how the two add together to become a total 3-d package), the smoothness of the skin/surface, the surface-area/skin drag, and numerous other smaller factors. Precisely. And by using prepregs a designer can go with a less compromised foil since the material is so much stronger, not to mention they have the ability to be smoother (and stay that way!), much less affected by weather/heat (they are not room temp cured so at normal runway temps are not even close to getting soft and you will never be complaining about the dreaded 'spar hump' for that matter). This all means nothing of course if the design blows... Existing composite materials can be made to follow complex curves and result in an extremely smooth surface, so changing to a fancier material does nothing to improve the efficiency of the wing. As can prepregs, although it is a good bit more work. However 'fancier' materials allow the designer to make a wing that looks a lot more like the airfoil they really wanted to use, instead of the one it had to be mutated into to allow for the safe amount of structure. The reason that Pre-Preg and other fancy/costly exotic materials aren't commonly in use is because they aren't NEEDED to achieve aerodynamic optimums. Fancy materials are mostly used for manufacturing reasons, to carry higher loads, to have more specific stiffness in a particular load direction, etc. Aerodynamics doesn't enter into the equation. Absolutely incorrect. The reason they are not used is because their significance is not widely recognized enough for customers to expect any different. Most big manufacturers have their entire infrastructure built around traditional wet layup. In fact some of them even were the original pioneers of these now widely utilized, current industry standard materials and techniques. They are not about to fire all their workers, sell off all their equipment and revamp their entire existence around this "new" material, and anything short of that would yield no results. It is a completely different ballpark, and there is only one manufacturer who is setup for it, although it is now becoming commonplace to be used in flight control surfaces for obvious aerodynamic reasons (flutter?). Small, incremental advances in overall performance have been made over the last 20 years; but they are pretty tiny in comparison to the performance jumps that were seen from the 50's to the late 70's (when glide ratios doubled or tripled). We're down to the point where we're fighting physics every step of the way in order to see any improvements. And in order for theoretical gains to be realized in actual flight, the tolerances are getting so tight that normal manufacturing techniques cannot be applied. And with tolerances that tight you also end up fighting the fact that the air gliders move through is not sitting still. At some point the turbulence and natural air movement disrupts the pristine theoretical predictions of how the air will behave as the sailplane passes through it, rendering supposed performance gains null (and in some cases causing an actual performance penalty - see the part of the Diana 2 paper where they talk about lift minimums in certain airfoils at high Cl). I agree that the performance leaps will probably never be as rapid as the transition from wood/metal to glass period (which was essentially due to "new fancy materials" allowing the structures to come much closer to the aerodynamic optimums and thus allowing the new aerodynamic advances of the time to enter the equation, leading to more aerodynamic research...), and I am not saying otherwise. I AM saying though, that L/D WILL continue to improve, especially at higher speeds. The initial L/D's will be slowly creeping up while the polars are getting flatter. As new materials come along, so do new design possibilities that were once ruled out due to structural considerations. Not to mention possible advances in aeroelastic skins (morphing wing/fuse shapes) and as mentioned de-turbulation. I guess it comes down to the simple fact that I just think we have more to look forward to in the future than others may. Paul Hanson PS. In the late 50's, the world's leading aerodynamicists dismally predicted L/D's around the 40 mark were thought to be "the plateau" designers and ships would get stuck at. Luckily new designers came along that hadn't heard the rules so were not bound by them... |
On May 5, 10:26 am, sisu1a wrote:
On May 5, 9:23 am, "noel.wade" wrote: Paul - You're missing out on a key point: Changing materials to a lighter structure does not change the aerodynamics of the wing. I did not miss the original point, I just don't agree with it. Clearly you miss mine though. If structure does not change the aerodynamics of a wing, then why are modern hot ships still made of wood, or metal? The fact of the matter is that the aerodynamic optimum will never agree with the structural minimum, but the more that materials advance, the closer to that optimum designers can get. It most certainly does affect the areodynamics of a wing, so long as the wing is designed specific to the materials it is made from. It changes the wing-loading - but that's no different from adding or removing water ballast. As long as the wing SHAPE remains the same, a different weight/wing-loading simply shifts the polar. It doesn't create an improvement. Huh? Wing loading? Again, you are way off my point. Advances in structure ALLOWS changes in shape, which most certainly can lead to improvement. Any racing ship will have the ability to change it's wing loading with ballast, but since we're on the subject of wing loading, by using prepreg your dry weight can be significantly lower, thus 'possibly' allowing a wider range in wing loading and thus a ship adaptable to a wider range of conditions. Wing efficiency is affected by the shape of the airfoil, the wing planform (and how the two add together to become a total 3-d package), the smoothness of the skin/surface, the surface-area/skin drag, and numerous other smaller factors. Precisely. And by using prepregs a designer can go with a less compromised foil since the material is so much stronger, not to mention they have the ability to be smoother (and stay that way!), much less affected by weather/heat (they are not room temp cured so at normal runway temps are not even close to getting soft and you will never be complaining about the dreaded 'spar hump' for that matter). This all means nothing of course if the design blows... Existing composite materials can be made to follow complex curves and result in an extremely smooth surface, so changing to a fancier material does nothing to improve the efficiency of the wing. As can prepregs, although it is a good bit more work. However 'fancier' materials allow the designer to make a wing that looks a lot more like the airfoil they really wanted to use, instead of the one it had to be mutated into to allow for the safe amount of structure. The reason that Pre-Preg and other fancy/costly exotic materials aren't commonly in use is because they aren't NEEDED to achieve aerodynamic optimums. Fancy materials are mostly used for manufacturing reasons, to carry higher loads, to have more specific stiffness in a particular load direction, etc. Aerodynamics doesn't enter into the equation. Absolutely incorrect. The reason they are not used is because their significance is not widely recognized enough for customers to expect any different. Most big manufacturers have their entire infrastructure built around traditional wet layup. In fact some of them even were the original pioneers of these now widely utilized, current industry standard materials and techniques. They are not about to fire all their workers, sell off all their equipment and revamp their entire existence around this "new" material, and anything short of that would yield no results. It is a completely different ballpark, and there is only one manufacturer who is setup for it, although it is now becoming commonplace to be used in flight control surfaces for obvious aerodynamic reasons (flutter?). Small, incremental advances in overall performance have been made over the last 20 years; but they are pretty tiny in comparison to the performance jumps that were seen from the 50's to the late 70's (when glide ratios doubled or tripled). We're down to the point where we're fighting physics every step of the way in order to see any improvements. And in order for theoretical gains to be realized in actual flight, the tolerances are getting so tight that normal manufacturing techniques cannot be applied. And with tolerances that tight you also end up fighting the fact that the air gliders move through is not sitting still. At some point the turbulence and natural air movement disrupts the pristine theoretical predictions of how the air will behave as the sailplane passes through it, rendering supposed performance gains null (and in some cases causing an actual performance penalty - see the part of the Diana 2 paper where they talk about lift minimums in certain airfoils at high Cl). I agree that the performance leaps will probably never be as rapid as the transition from wood/metal to glass period (which was essentially due to "new fancy materials" allowing the structures to come much closer to the aerodynamic optimums and thus allowing the new aerodynamic advances of the time to enter the equation, leading to more aerodynamic research...), and I am not saying otherwise. I AM saying though, that L/D WILL continue to improve, especially at higher speeds. The initial L/D's will be slowly creeping up while the polars are getting flatter. As new materials come along, so do new design possibilities that were once ruled out due to structural considerations. Not to mention possible advances in aeroelastic skins (morphing wing/fuse shapes) and as mentioned de-turbulation. I guess it comes down to the simple fact that I just think we have more to look forward to in the future than others may. Paul Hanson PS. In the late 50's, the world's leading aerodynamicists dismally predicted L/D's around the 40 mark were thought to be "the plateau" designers and ships would get stuck at. Luckily new designers came along that hadn't heard the rules so were not bound by them... Paul, You have some nerve.....when Mr. Kubrynski is talking most of people familiar with his work are listening....well, maybe you need to become aerodynamicist and prove us all wrong....the field is wide open. Jacek Pasco, WA |
sisu1a wrote:
On May 5, 9:23 am, "noel.wade" wrote: Paul - You're missing out on a key point: Changing materials to a lighter structure does not change the aerodynamics of the wing. I did not miss the original point, I just don't agree with it. Point/counterpoint snipped... Perhaps it may be useful to imagine using the material 'Unobtainium' to design sailplanes having zero structural restraints/considerations (e.g. infinitely thin airfoils, tailbooms, vertical stabs, whatever...) influencing its aerodynamics...in other words, imagining 'the perfect aerodynamics' designed to extract soarable energy from the atmosphere while still enclosing a pilot. Such a plane will probably be instantly recognizable to our eyes today as a 'sailplane'...simply because the design will still have to deal with physics...but my money is on it looking 'different' too. Maybe the Bruce Carmichaels and Al Bowers of the world already have such ship in their back pockets waiting for the material to arrive! (Remember that 'wonderfoil' designed by [I think it was] someone at Douglas or Boeing with startlingly high 2D L/D values for its time [late '70's/early '80's?]...but which couldn't be built for lack of Unobtainium?) Regards, Bob W. |
today as a 'sailplane'...simply because the design will still have to deal with physics...but my money is on it looking 'different' too. Maybe the Bruce Carmichaels and Al Bowers of the world already have such ship in their back pockets waiting for the material to arrive! (Remember that 'wonderfoil' designed by [I think it was] someone at Douglas or Boeing with startlingly high 2D L/D values for its time [late '70's/early '80's?]...but which couldn't be built for lack of Unobtainium?) Regards, Bob W. Thanks Bob, perhaps your clarifying and endorsing of my point will hold more water than my untrained/unprofessional/non-aerodynamicist opinion will (Bob Whelen IS an aerodymicist as well as a published author for those who don't know). In quite typical fashion, your post cuts right to a point that was attempted but with far less clutter. Jacek, relax. I'm not knocking Polish gliders or aerodynamics FWIW, I love Diana 2, and own an SZD-59 that I'm quite happy with. I'm just saying I think there is more hope on the horizon than predicted, thats all. We ALL have things to look forward to, it's a good thing. Mebelieves the Dianna 2 represents the plateau for traditional wet layup (or very very close to it at least) and is a wonderful machine. My drool has had to be wiped off of the wings of the Diana 2 at the convention on more than one occasion. Once we do have "Unobtanium" though, there will be better ships yet! I'm sure the Pols' will be in on it too! ; ) With Respect, Paul Hanson |
sisu1a wrote:
If structure does not change the aerodynamics of a wing, then why are modern hot ships still made of wood, or metal? When the shift from wood and metal to fiberglass occurred, a huge factor was cost: it was much cheaper to build a glider to the tolerances required in molded fiberglass than the other materials, and it retained the shape better. At that time, you could build a lighter aluminum glider of the same performance, but it was a constant effort to keep the airfoil correct. I don't know if this is still true for carbon fiber versus aluminum; regardless, I think the cost would still favor the molded construction. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On May 5, 9:23*am, "noel.wade" wrote:
Existing composite materials can be made to follow complex curves and result in an extremely smooth surface, so changing to a fancier material does nothing to improve the efficiency of the wing. Maybe someone will come up with an affordable combination of new materials and new processes that will give us sailplanes that keep the complex curves intended by the designer for more than a few months after delivery. Andy |
Thin Airfoil and Climb Performance | Brad[_2_] | Soaring | 16 | April 3rd 08 05:50 AM |
climb performance Jet vs Prop | xerj | Piloting | 11 | July 7th 06 06:31 AM |
Duo Turbo Climb / Altitude performance | Gary Emerson | Soaring | 16 | November 28th 05 08:19 AM |
relative climb performance | Soaring | 8 | September 17th 05 07:21 PM | |
172 N Climb Performance | Roger Long | Piloting | 6 | September 10th 03 11:18 PM |
