Thin Airfoil and Climb Performance
Old March 28th 08, 01:59 AM posted to rec.aviation.soaring
Brad[_2_]
Default Thin Airfoil and Climb Performance
As a guy who has flown thick airfoil ships and currrently owns a ship
with a 17% airfoil, I am curious what kind of performance in climb I
might see with a 14% airfoil section.
Brad
Old March 28th 08, 04:46 PM posted to rec.aviation.soaring
Brad
Take a look at SZD 56 Diana. It has 13% thick airfoil and climbs like
a bird.
Jacek
Pasco, WA
Old March 28th 08, 05:02 PM posted to rec.aviation.soaring
Brad
The amount of camber in the airfoil, flaps/no flaps, wing loading and
aspect ratio are also important factors...
Bill
Old March 29th 08, 01:23 AM posted to rec.aviation.soaring
Dan G
Brad
Someone on here mentioned a presentation by Loek Boermans at the
recent SSA conference, where he stated that modern, thin, laminar-flow
sections don't climb as well as they theoretically should in bumpy
gusty thermals. Apparently research into ways round that are ongoing,
but the Jonker brothers stumbled across an airfoil for the JS-1that
doesn't suffer from this by accident!
Maybe someone who attended could expand on what was said? It sounded
very interesting.
Old March 29th 08, 01:40 AM posted to rec.aviation.soaring
Brad
Bill
Probably the 17% airfoil has a higher CL number but that would occur
in a unusable angle of attack. Generally speaking the thicker the
airfoil the broader is the low drag bucket (for laminar sections of
course).
Basically the climb ratio is governed by the wing loading, the aspect
ratio and the wing planform. The main enemy here is the induced drag.
Getting a low wing loading and high A/R is the way to go up. Given no
variable camber (ie flaps) the airfoil characteristics have a small
impact. Otherwise in the high speed section of flight having a high
wing loading and an airfoil tailored for hi-speed (thin and low
camber) is desirable. That´s why the sailplanes are in the cutting
edge of aircraft design, since they have to accomplish a very broad
mission envelope with a light empty weight and a high relative payload
(water+pilot).
wladimir
Old March 29th 08, 06:50 AM posted to rec.aviation.soaring
Bruce
I'd take the accident part with a pinch of salt. They may have been pleasantly
surprised, but what I know of those two involves many years of meticulous
research and testing. Luck often plays a role, but like Edison and the lightbulb
there is a lot of plain hard work behind the "chance" discovery.
But yes the JS1 climbs well, and runs (exceptionally) well, and in the hands of
one of the Jonkers is hard to beat.
The most critical thin laminar wing I have seen is the Diana 2 - The only time I
could see relative performance I was in a Duo Discus, and the Diana had a Dr
Kawa installed so it is probably not a good comparison. However the Diana had
absolutely no difficulty outclimbing a lightly loaded Duo in light ridge/thermal
conditions. Indications are that a well designed thin section can be made to
climb well. Conversely both the DG600 and ASW24 had difficulty in strong
turbulent thermals, and suffer in South Africa. (Except when there is a
Goudriaan installed in the ASW)
So - I think the wing section does make a difference, but I strongly believe
that the difference is very small and insignificant relative to personal
performance for most of us - The software is the diagnostic bit when it comes to
ultimate performance.
A good person to ask might be Kolie (skylinesoaring.org) -he just moved from a
LS3 to a Diana 2. So far I have not heard ANY complaints about the Diana's climb
performance.
Bruce
Brad
very interesting.
Old March 29th 08, 03:35 PM posted to rec.aviation.soaring
Eric Greenwell
gusty thermals.
I attended Boerman's lecture. The problem isn't thin, laminar flow
airfoils in general, but some specific designs over the last two decades
or so that have a "flat spot" in the lift coefficient (Cl) curve as the
angle of attack (AOA) approaches stall. Normally, the Cl increases with
increasing AOA, but in the flat spot region, it remains constant (or
nearly so) even as the AOA increases. Past this region, Cl begins to
increase again with AOA at the usual rate.
While thermalling, the glider's AOA will be near this region. If a gust
increases the AOA enough to enter the region, the climb rate is reduced
momentarily. By the top of the thermal, repeated gusts mean the glider
hasn't climbed as quickly as it might have.
In gusty conditions, the climb rate can be improved by thermalling a bit
faster, so this region is avoided (gusts can't increase the AOA enough
to enter the region). Because the "flat spot" is wider in the
thermalling flap setting and diminished or not present with more
negative flap settings, using the neutral flap setting in gusty
conditions will also avoid (or at least improve) the situation.
Old March 29th 08, 03:43 PM posted to rec.aviation.soaring
Eric Greenwell
I should add that designers were aware of the flat spot years ago, but
did not appreciate the problems it could cause in gusty conditions.
Old March 29th 08, 04:26 PM posted to rec.aviation.soaring
performance.
Bruce
bit
enough
I've had my Diana 2 almost two years - moved up from a 304cz. The
Diana 2 has climbed
out of valleys late in the day that would have swallowed the cz.
Remember the Diana is 25 years younger
(and how many generations?) than the cz... The 304cz is a great glider
and I loved mine dearly. When the
lift gets strong and bumpy here in SoCal, one needs to speed up to
maintain control anyway.
As I said in an earlier post, and Wladimir expanded on, it isn't just
the airfoil that determines climbing performance.
Bill
Old April 1st 08, 12:00 AM posted to rec.aviation.soaring
Dan G
Yeah, "by accident" was a poor choice of words (though the original
poster, iirc, implied that the Jonkers were interested in Boerman's
lecture as it provided an explanation for what they'd found). The JS1
looks very impressive and I wonder if it will become the "Diana 2 of
the 18 m Class".
climb performance Jet vs Prop xerj Piloting 11 July 7th 06 06:31 AM
Duo Turbo Climb / Altitude performance Gary Emerson Soaring 16 November 28th 05 08:19 AM
relative climb performance Soaring 8 September 17th 05 07:21 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
172 N Climb Performance Roger Long Piloting 6 September 10th 03 11:18 PM
