#21
At 1,000 MHz, RG-58 has a loss of about 15 db per 100 feet. So, a 10 foot
run would represent 1.5 db. That is an acceptable loss. It will reduce the range a bit. Generally, if the control cables are not resonant and not in the same plane as the antenna (horixontal controls, vertical antenna), there should be minimal interference. There are a number of antenna plotting programs arund that would allow you to plot the potential interference. to determine the possible interference. Colin Lamb |
On Sun, 15 Jun 2008 11:39:22 -0700, COLIN LAMB wrote:
At 1,000 MHz, RG-58 has a loss of about 15 db per 100 feet. So, a 10 foot run would represent 1.5 db. That is an acceptable loss. It will reduce the range a bit. Generally, if the control cables are not resonant and not in the same plane as the antenna (horixontal controls, vertical antenna), there should be minimal interference. There are a number of antenna plotting programs arund that would allow you to plot the potential interference. to determine the possible interference. That's exactly what I wanted to know. Many thanks. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
Alan wrote:
In article brianDG303 writes: Is there a downside to mounting on a ground plane inside the fuselage of a non-carbon glass glider? Since the ground plane should extend at least 23 inches in each direction around the antenna, it is probably hard to get that inside the glider. That sounds like a dimension for the aircraft communication radio, working in the 120-130 mhz range. The transponder uses 1090 mhz, about 10 times higher. That indicates a 2.3" radius ground plane would be adequate, or the 6" diameter Marc points out as commonly used. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 06:03 PM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
Blade type VHF antenna? | JFLEISC | Home Built | 6 | December 13th 03 04:28 AM |
