#21
I think we should clarify by "electric" we actually mean "audio" Most
electric varios still get there information by pnuematics ie a static and TE probe and are driven electrically. I had an electrically compensated Ball vario (no TE Probe and absolutly hated it. Its compensation changed during the flight with temperature and was very confusing. Using the SN10 now and 66's discarded Sage from a glider or two ago. I use the Sage mostly when low and scratching to help center small lift and the SN10 for everything else. At 21:55 16 July 2008, kirk.stant wrote: On Jul 16, 4:35=A0pm, Ian wrote: On 16 Jul, 20:37, Bruce wrote: So why install mechanical varios in a new high tech glide? Convince me. How well do electric ones react to nearby lightning bolts? Apart from that, isn't it an awful lot easier to fit a mechanical vario than it is to fit a complete second electrical system? Ian "All mechanical cockpit" J I'm totally in the "all electric" camp. Tossed my mechanical 8 years ago, replaced with a nice Ilec electric backup (with audio), and haven't had a problem since. Primary is an SN10. Both agree all the time. And 2 electrical systems are only slightly more work than one, if done at the same time. Given more funds, I would replace the Ilec with something that has electronic TE, so that losing the probe wouldn't fail both varios - my current single point of failure... Mechanical varios belong with barographs - on the shelf behind the club bar. Especially on club ships, where good varios with audio are really needed, yet rare (at least in the US). Cheers, Kirk 66 |
On Jul 17, 9:26*am, Cliff Hilty
wrote: I think we should clarify by "electric" we actually mean "audio" Most electric varios still get there information by pnuematics ie a static and TE probe and are driven electrically. I had an electrically compensated Ball vario (no TE Probe and absolutly hated it. Its compensation changed during the flight with temperature and was very confusing. Using the SN10 now and 66's discarded Sage from a glider or two ago. I use the Sage mostly when low and scratching to help center small lift and the SN10 for everything else. The Sage is probably the only mechanical vario I would consider using (fast response plus high "cool" factor) but I didn't have room for it (it's a big SV) in my small LS6 panel - plus it's being put to much better use in CH's Ventus! Kirk 66 |
What caught my eye is that there appears to be four (4) varios in the
What caught my eye was that the LS4 is obviously looping a loop, considering this glider is not rated for it... As others said: There are many different things a vario can be set to display: Actual, integrated, netto, speed to fly... Besides, the picture is a fine example for the word "lag". |
and the yaw string is not straight, screwed up loop
BT "John Smith" wrote in message . .. What caught my eye is that there appears to be four (4) varios in the What caught my eye was that the LS4 is obviously looping a loop, considering this glider is not rated for it... As others said: There are many different things a vario can be set to display: Actual, integrated, netto, speed to fly... Besides, the picture is a fine example for the word "lag". |
.... Why would anyone put four varios in a single glider ?
Only one possible reason. Deep, deep, insecurity. See ya, Dave "YO electric" |
One good reason for using 2 electric varios is that you dont require a
Flask. I have seen gliders recently whose fancy electric varios/ FComputers costing a lot of money were compromised by splitting the TE line too close to the instruments. The flask in the mechanical will then adversely affect the electronic one. see point 5 in Borgelts excelent article on vario leak/problem finding. Given he makes these things I suspect that he knows what he is talking about.. http://www.borgeltinstruments.com/Leaks.html This made a huge diff to my last glider whose varios did some very strange things and once I found the leak in the ASI caused by a loose glass and moved the split in the TE behind the seat it was transformed. Personally I fly with 3 effectively 2 dials Driven off an LX 7000 one showing net the other normal. This is an arangement I inherited and I actually find it quite intuitive although I wouldnt miss losing one particuarly. The 3rd is a B40 which has its own battery when required in the event of a power failure. Far more useful IMHO than a mechanical in that it is a better vario and it has audio. Try thermaling without an audio once you have got used to it... |
Offtopic... Forget the 4 varios and the sloppy loop in the LS-4.
Check out the Airbus A320-211, second from last. http://preview.tinyurl.com/4yevhp http://preview.tinyurl.com/6mmpyq Left seat, Bacardi badge lanyard. Nice flair, no big deal. Off his left hand, is that... a rum and coke? Dude, I know that the industry is a mess right now, but can't it wait for the hotel bar... j/k On Jul 16, 11:57*am, ContestID67 wrote: http://www.canadabizmart.com/bootstr...ectacular-cock... This web site has some nice pictures of aircraft cockpits, including two gliders. *If you scroll down you will find an LS-4 flying inverted. What caught my eye is that there appears to be four (4) varios in the instrument panel. *My soaring friends have been scratching our heads trying to understand why you would ever need four varios in a single glider. Can anyone give some valid reasons why this would be useful? Thanks, John DeRosa |
Sage Varios-Williams Soaring | Tom Hubbard | Soaring | 0 | April 2nd 07 07:12 PM |
How about this for computing power in your glider cockpit | Gary Emerson | Soaring | 9 | May 17th 06 08:56 PM |
What camera for pictures from a glider cockpit? | Eric Greenwell | Soaring | 34 | December 10th 05 06:19 AM |
Opinions on Varios | Bruce | Soaring | 8 | March 1st 05 03:57 PM |
Super Varios | John Scott | Soaring | 1 | February 25th 05 02:14 AM |
