Texas Parasol
Old August 12th 08, 01:45 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Default Texas Parasol
Fred the Red Shirt wrote:
What was the resolution of the supposed dimensional discrepency
discussed he
http://www.airtalk.org/next-vt20548....r=asc&start=15
Or has that been addressed over on the Yahoo TP group?
FF
And, since you butted in here...
I don't see you listed as an active builder.
So what do you want?
Old August 12th 08, 01:56 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
discussed he
http://www.airtalk.org/next-vt20548....torder=asc&sta...
Fred,
Do YOU know what he's talking about?
Not to the extent that Mr Hoover does, so if you are unclear
as to the details of points he has raised I suggest you ask
him to clarify.
I've just never seen anyone else including yourself, agree or
dispute the errors or suggest they have been resolved. That
seems peculiar.
IMHE in the nuclear industry I have never seen a drawing package
that size executed by one designer without numerous errors. That
is why we employed checkers.
FWIW, the 'designer' was typically not the person who actually
designed the systems. He/she was the person who executed the
formal top-level drawings based on one or more engineers' sketches
and descriptions.
FF
Old August 12th 08, 02:06 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
discussed he
Discussion
FF
Old August 12th 08, 02:59 AM posted to rec.aviation.homebuilt
Default Fred the Red Discusses...???
Discussion
FF
Ok, talk to us.
This being rec.aviation.homebuilt, why don't we start on topic?
What are YOU building?
What have you BUILT?
Richard
(remove the X to email)
Old August 12th 08, 04:06 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Discussion
Ok, talk to us.
Good.
Have you identified any errors in the plans that should be corrected?
An addendum of corrections would be a welcome adjunct to the CD
I bought from you a couple of years ago.
It was money well-spent regardless.
FF
Old August 12th 08, 01:23 PM posted to rec.aviation.homebuilt,[email protected]
Ok Fred. I guess I may owe you an apology for being a wee but
suspicious of your motives.
The one thing a man can never defend himself from is the mongrels
snapping at his heals.
But you kinda skipped over _MY_ questions:
I'd still like to know.
Ok,
Did you happen to notice the date on the rant you referenced up-thread?
This referenced stuff from five years ago.
Intentional or not, you are perpetuating an old and very tired vendetta.
Regardless of all the noise you have heard here, (and will continue to
hear) there really aren't any serious corrections to be made.
MISSION:
The airplane is not intended to be a high-tech, close tolerance, aero-
space machine. It is a low and slow fair weather baby buggy.
It was intended to be as inexpensive and simple to build as possible
while retaining good flying qualities.
It is not to "go places" in. It's for fun flying in the local area.
That's our Dreaded Mission Statement(tm) and I think we fulfilled those
requirements pretty darned well.
PLANS:
In the first printing...
I had left out the drawing for landing gear setup, but that was added
years ago. Check your copy and see if it's there.
There was one incorrect dimension of a vertical member back in the aft
fuselage. That was corrected years ago also. It was really obvious if
you actually laid the fuselage truss out on a table to build it.
I'm measuring to about 1/16" - not .001" ± a tenth.
I've had people write and ask if I could provide the drawings in DXF
format so they could have the CNC guys cut out all the parts for them.
That is absolutely NOT the way this thing is built.
Hacksaw and file and trim to fit are the orders for the day.
(Although a chop saw and belt sander make the job go a lot faster!)
This is not intended to be a high tech, close tolerance, aero-space
structure. It's basically South Texas farm technology.
It can be built by a single person who is handy with tools in something
like 6 to 8 weeks. First time builders usually take a LOT longer.
Chuck and I had them down to TWO weeks each for the kits. That was
complete all controls hooked up, no engine, gauges, or cover.
Two Weeks...
Lastly, on this particular subject, if you think my plans suck, take
a look at the late Graham Lee's plans for the Neiuport 11 Bebe.
I paid $145 for my copy. It was well worth the money too.
His work motic\vated me to try my project.
(Neither one of us meet Nuclear Regulatory standards though!)
FIT:
There are a few pointers I've described on the Texas Parasol group at
Yahoo Group.
For instance, some people were thinking that the verticals in the aft
fuselage were suppose to be riveted to the laterals as well as the
longerons. But he verticals are at a non-square angle that far back and
the laterals don't fit flat on the faces. If you try to rivet the
verticals to the laterals, IT WON'T FIT.
That seems to upset some people. But that's the way we build them.
I thought I had mentioned that pretty well in the manual, but it kept
coming up, so we posted some pictures to show how its supposed to go
together there. (A picture really is worth a thousand words)
BAD MODS:
One of the detail issues that self appointed experts want to change is
the cabane mounting brackets. Per plans, there are 8 little brackets
cut from 1"x1" angle and bolted to the top of the top longeron.
The cabane struts fit between each pair and are pinned with an AN-3 bolt
running longitudinally (fore/aft).
But the rule of thumb in aircraft design says thou shalt not put bolts
in tension. We violated that one intentionally because it simplifies
the construction - and puts the pin through the bottom end of the cabane
in double shear (stronger!)
One of the proposed "corrections" was to bolt a strap to the outside of
the vertical member near the mount point and bend it to meet the slope
of the cabane. The cabane tube is then bolted to the strap.
Problem with that: First and foremost, the cabane tube would be bolted
in single shear. That would create a serious moment trying to bend the
mount bolt and rip out (twist?) the end of the cabane tube (1" x .058
6061-T6).
This so-called "correction" to our original "mistake" is down right
dangerous and I resent the hell out of it being offered at all.
GOOD MODS:
Wing Strut fittings. Yes, a wrap around fitting would be technically
superior to the through bolted bracket. But if one were to go that
route, by the time he had all four brackets made, he'd understand why
we did it a simpler way. There is currently a BAD MOD sketch on the
Yahoo Group. It's a wrapper, but so poorly designed as to be of
questionable safety. I'd like to have it removed, but I don't run the
group.
WING SPARS:
Replacing the 2" spar tubes with 2-1/4" diameter tubes would be pretty
straight forward simple (if one can find 2-1/8" tube for the internal
sleeves). One clown claimed that would spoil the stall characteristics.
For two seat versions this is going to be absolutely necessary - but NO
we don't offer any help for building a Two. You want to do that, you
are designing your own project. At your own risk.
A better solution here is to simply keep the weight down and use the
wing as drawn. A Rotax 503 (NOT a VW) is the preferred power plant.
FLYING:
This is the kind of flying these very light airplanes are for:
http://www.youtube.com/watch?v=ckjqfUM5xlw
http://www.youtube.com/watch?v=vSxM-...eature=related
http://www.youtube.com/watch?v=eps0z...eature=related
http://www.youtube.com/watch?v=v-jrH...eature=related
EVIDENCE:
Excluding the Canadian two seater that crashed recently (not heard
anything more about it yet) - NO airplane built as drawn has had ANY
structural failures.
So help me out here, Fred.
What's my motivation for making a bunch of untested changes????
Or caving in to vindictive demands?
Not going to happen, folks.
FUTURE PLANS:
I'd really like to travel now. Visit some foreign countries with
interesting cultural hermitages and bitch slap a couple of the Queen's
subjects.
Richard
Old August 12th 08, 06:39 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
Default Background and experience (almost none for me)
I'll edit the subject line again, to make it a but more general.
Note also that Google handles the copy to yahoogroups differently
from your newsreader.
Of course. I was staying on-topic.
Cool. I had always had a casual interest in aviation. Back
a few years ago a cow-orker who is a pilot and a member
of a local flying club mentioned to me that they were working
on a replica of the Wright Flyer. The project was actually
building two wings for display purposes only at Kitty Hawk.
Being a woodworker, I found the construction techniques
to be quite interesting and, from my engineering background
had a minor epiphany, a wing is a beam.
Since then I have been studying homebuilts, primarily in regard
to construction technology. It is fascinating that so many diverse
technologies can be used to produce airframes, given the
rather extreme demands on the design. As to overall design,
aircraft may be second only to spacecraft design in terms
of multidisciplinary demands on the designer.
Aircraft design is also fascinating from the aspect of
optimization. There is no one design that does all things
well, which leads to a wonderful variety of approaches.
The TP fuselage is of interest as it appears to be one of the
easiest/quickest/cheapest to build, and the basic technique
can be adapted to other designs.
FF
Old August 12th 08, 07:18 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
Yes.
Did you notice that I participated in it, in a very minor way?
Actually, you posted the link to the aformentioned rant first. I just
copied it from your article. Further, I would like to help resolve
issue, not perpetuate it.
But wouldn't making thos less serious corrections be helpful
to future builders? Would it not save them the trouble of re-
making a couple of parts after finding that they don't fit?
That is all that Mr Hoover is talking about here, he's not
making any accusations of inadequacy in the design,
he wants to resolve what the design is, for the common
meaning of 'is'.
That is the sort of thing being discussed.
If I understand the issue correctly the motivation to
changing the plans is to correct errors in the drawings,
not in the design. IIUC the design in the published
plans is untested and untestable because a discrepency
in the dimensions makes it unbuildable to the plans.
These sound to be mostly minor changes in dimensions,
possibly due to typos
As you will recall, back in
http://groups.google.com/group/rec.a...n&dmode=source
You wrote, regarding how your planes were built:
" Because no two have been exactly alike"
Which kind of implies that the _exact_ design has never been built by
you. I never build anything exactly to plans nor any two exactly a
like either. That is not really a criticism. But it certainly can
explain
why on the plans the dimensions for two different sub-assemblies
don't match. IF it is true that they do not.
But back to the issue of dimensional discrepencies:
That is a situation that is frequently encountered in the
field or during assembly. Whenever possible the
drawings are revised to reflect the as-built condition.
As you know, the major nagging issue is the claim that
the dimensions for the carry through do not match the
dimensions for the fuselage so that if both are fabricated
according to the plans they won't fit together.
As you also know, this is entirely independent of the
claims from up North regarding the wing.
Perhaps a photo of that area would help?
Or would it be that hard to check the drawings for that
area against at least one (1) of the planes you built?
FF
  #29
Old August 12th 08, 07:56 PM posted to rec.aviation.homebuilt
good bye fred
  #30
Old August 12th 08, 08:15 PM posted to rec.aviation.homebuilt
Jay Maynard
On 2008-08-12, cavelamb himself wrote:
good bye fred
You know, Fred's asking reasonable questions...and all you're doing is
looking like you're stonewalling. What's so hard about answering what he's
asking?
You've gone a long way to slam the credibility of those who say the TP
plans as published have problems, without actually addressing the problems
they report. Why? You're only harming your own credibility by doing so.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
Heath Parasol plans, 103 trimmable? Chris Wells Home Built 2 July 1st 07 12:36 AM
Texas Parasol and 1/2 VW Engine...... WC Home Built 11 June 4th 07 09:39 PM
Looking for a good set of parasol plans Mike Gaskins Home Built 11 January 24th 07 04:10 AM
Texas Parasol Plans... Richard Lamb Home Built 82 March 12th 06 07:19 AM
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation Richard Lamb Home Built 12 August 9th 05 08:00 PM
