Looking for a good set of parasol plans
Old December 18th 06, 08:02 PM posted to rec.aviation.homebuilt
Mike Gaskins
Default Looking for a good set of parasol plans
I'm looking for a good set of parasol plans that would be reasonably
easy to follow for a first time builder. I don't really care about
speed or cross country capability - just something to putz around the
pattern and sight-see. I'm thinking that tube and fabric would be my
preferred materials (low cost and high strength), but I'm open to any
suggestions. Single or double place is fine. Most of the people who
would go flying with me wouldn't do so in an open cockpit plane
anyways, so a second seat would usually sit empty .
The two designs that have initially peeked my interest are the Pober
Pixie and the Starlet SA500. I've also looked at the Baby Ace. Anybody
have any opinions on these plans in regards to ease of construction for
a first timer?
Also I doubt I'd have the space to complete the whole wing in one
piece, so extra points if the wing can be built in sections.
Thanks.
Mike Gaskins
Old December 18th 06, 08:29 PM posted to rec.aviation.homebuilt
Anthony W
a first timer?
Thanks.
Mike Gaskins
Look here. http://www.pressenter.com/~apietenp/
The Pietenpol Aircamper has a reputation that's hard to beat.
Tony
Old December 18th 06, 11:45 PM posted to rec.aviation.homebuilt
Dear Mike,
Then by all means, start with the Wag-Aero Cub and work your way down.
Wag-Aero offers an excellent set of plans at a very fair price,
allowing you to study the standard against which all other parasols
have been judged for the last 60 years. If you decide to go with the
Cub you will have the option of buying those components you feel are
best left to a more experienced fabricator, reserving the easier but
more labor-intensive tasks for yourself.
Should you decide the Cub is more airplane than you need (it isn't, but
for the sake of argument...) then you will have a basis on which judge
other designs.
As for the engine, there's far more of them out there than most folks
realize, for despite all talk to the contrary our numbers continue to
fall and the smaller, older engines continue to become available, often
at give-away prices.
-R.S.Hoover
Old December 19th 06, 02:53 AM posted to rec.aviation.homebuilt
Ed Sullivan
On 18 Dec 2006 14:45:57 -0800, "
-R.S.Hoover
By definition a Cub couldn't really be described as a parasol, a high
winged monoplane yes.
Old December 19th 06, 03:41 AM posted to rec.aviation.homebuilt
Richard Isakson
"Ed Sullivan" wrote ...
-R.S.Hoover
I don't know Ed. Haven't you ever flown a J-3 with the door open and the
window down? That's got to be pretty close to a parasol.
Rich
Old December 19th 06, 06:21 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
-R.S.Hoover
The change from a Parasol of the A-2/E-2 to the "razorback" J-2 was
merely cosmetic. You can very easily build a parasol from the Wag Aero
plans by omitting the upper fairingof the aft fuselage WITH NO
STRUCTURAL CONSEQUENCES.
http://www.goldenageair.org/collection/1932taylore2.htm I say that is
a parasol. A Super Cub has, for all intents and purposes, the same
structure, but with a non-structural cosmetic fairing on the fuselage.
Bob's point was the quality of the plans. Other points I'll add are
wide availability of pre-made parts.
Another design the original poster might think about: Stewart Headwind.
And the steel tube fuselage version of the Piet, the Grega Gn-1 (well,
there is a wood version too, you chose) is set up to use A-65 engines,
and wings from whatever air-knocker is hanging around the hanger. The
GN-1 is also set up to use a lot of pre-made parts from Piper Cubs,
allowing you to trade money for build time, if you've got more of the
former than the later.
http://www.stewartaircraft.com/main.html
http://www.gregagn-1.com/index.php
Old December 19th 06, 03:16 PM posted to rec.aviation.homebuilt
Mike Gaskins
other designs.
-R.S.Hoover
The Wag-Aero Super Trainer looks kinda interesting (who wouldn't want a
Super Cub and if I'm building a tube and fabric plane from scratch
anyways . . . ), but their website looks moreso to be selling lots of
component kits. I've ordered the catalog so maybe that'll have
something additional, but I wasn't actually able to locate a plans set
anywhere on there.
Mike Gaskins
Old December 19th 06, 07:02 PM posted to rec.aviation.homebuilt
Mike Gaskins wrote:
The Wag-Aero Super Trainer looks kinda interesting... but their website looks moreso to be selling lots of
component kits.... I wasn't actually able to locate a plans set
anywhere on there.
Dear Mike,
Don't give up so easily :-)
If you go to Wag-Aero's 'on-line' catalog, look for Sport Trainer (or
whatever) you'll get a list of 44 items, one of which is the DRAWINGS.
Their catalog number is Q-001-000, price is $125. And yes, you really
CAN build your very own Super Cub, should you wish to do so. :-)
However, since a lot of people already hold drawings for the Cuby,
Sport Trainer, et al, you can probably find a set to study within your
local EAA chapter. Making up a couple of test-ribs is always fun and
even if you elect not to build, they look good on the wall of the
hangar. The real key is the engine. Find a suitable engine and you're
half-way home.
I should mention here that yes, the Cub has flown behind a BIG VW
conversion... but not very well. A big-bore stroker such as an 84 x 94
(142cid) is a close match to the Lycoming O-145 (which many people will
literally GIVE you to get rid of them) but simply does not have the
low-rpm torque needed for this type of airframe. Ditto for the little
1834cc conversions, which are a close match for the A-40a (ie, 112cid).
Basically, you'll end up with a single-place Cub having a minuscule
ROC that needs its valves topped every 200 hours. Cheap, but you can't
fly it off floats, haul a heavy, etc.
The best part of the joke is that unless you are up to your elbows in
old Volkswagens, rebuilding a run-out O-200 will usually cost LESS
than building up a RELIABLE good big-bore stroker :-)
Either way, you've got some fun ahead of you. Good luck with it.
-R.S.Hoover
Old December 19th 06, 07:28 PM posted to rec.aviation.homebuilt
Scott[_1_]
Me! I think a Cessna 180 would be 3 times the airplane for about the
same or 1.5 times the cost of a "Super" Cub Personal preference I
suppose
Scott
anyways . . .
Mike Gaskins
Old December 19th 06, 07:30 PM posted to rec.aviation.homebuilt
Mike Gaskins
Sounds like fun . I've actually been very interested in the idea of
using one of the Corvair conversions in a plane for a long time.
I'll likely hold off a bit on engine choice until I have a good
semblance of an airplane built, but these engines usually give 110-115
hp which should be rather nice for a Cub airframe.
Mike Gaskins
That Didn't Look Good (long) Mary Daniel or David Grah Soaring 1 September 23rd 06 05:09 AM
Can anyone send me some good flight plans to learn from Dave Schwartz Simulators 5 April 14th 04 02:12 PM
Modifying Vision plans for retractable gear... Chris Home Built 1 February 27th 04 10:23 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 08:20 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 09:52 PM
