On Nov 13, 7:20*pm, wrote:
How does a person determine what the proper height of an engine should be when building an airplane? If a particular engine design mandates the prop is 4 inches, say, lower than where it would be with the engine originally installed, what effect will it have on handling, and what changes in downthrust might be advised? We are building a Pegazair, and my Corvair engine would need to have the cowl higher than ideal to keep the crank centerline at the same hight as say, an O200. Weight wize, the engines are just about identical as equipped Have not determined the center of gravity of the engine yet, to determine the overall length of the mount. For those unfamiliar with the plane it is a highwing STOL 2 placer roughly the same size as a Cessna 150 *(150 sq ft wing,33 ft wingspan, ) I've posted a spreadsheet to calculate a new thrust angle based on changing the waterline location of an engine. The data needed is horizontal distance from center of propeller to CG, original vertical distance from center of propeller to CG, original thrust angle, and new vertical distance from propeller center to CG. The formula is not sensitive to vertical CG location, an estimate will do. What matters is the change in the engine location. http://www.spiretech.com/~guynoir/sl...downthrust.xls |
On Sat, 15 Nov 2008 20:32:00 -0800 (PST), guynoir
wrote: On Nov 13, 7:20Â*pm, wrote: How does a person determine what the proper height of an engine should be when building an airplane? If a particular engine design mandates the prop is 4 inches, say, lower than where it would be with the engine originally installed, what effect will it have on handling, and what changes in downthrust might be advised? We are building a Pegazair, and my Corvair engine would need to have the cowl higher than ideal to keep the crank centerline at the same hight as say, an O200. Weight wize, the engines are just about identical as equipped Have not determined the center of gravity of the engine yet, to determine the overall length of the mount. For those unfamiliar with the plane it is a highwing STOL 2 placer roughly the same size as a Cessna 150 Â*(150 sq ft wing,33 ft wingspan, ) I've posted a spreadsheet to calculate a new thrust angle based on changing the waterline location of an engine. The data needed is horizontal distance from center of propeller to CG, original vertical distance from center of propeller to CG, original thrust angle, and new vertical distance from propeller center to CG. The formula is not sensitive to vertical CG location, an estimate will do. What matters is the change in the engine location. http://www.spiretech.com/~guynoir/sl...downthrust.xls Spreadsheet is not quite right.Prop center is BELOW the CG by about 13 inches. One inch change in prop height according to your spreadsheat makes a change of 2.14 degrees. I cannot buy that. Particularly since it would go from 1.5 down to .64 up. |
On Sun, 16 Nov 2008 00:58:06 -0800, John Kimmel
wrote: wrote: Spreadsheet is not quite right.Prop center is BELOW the CG by about 13 inches. One inch change in prop height according to your spreadsheat makes a change of 2.14 degrees. I cannot buy that. Particularly since it would go from 1.5 down to .64 up. Here is REV A, with a couple math errors fixed: http://www.spiretech.com/~guynoir/sl...thrustreva.xls That looks a lot closer. What is it based on? |
On Sun, 16 Nov 2008 00:58:06 -0800, John Kimmel wrote: wrote: Spreadsheet is not quite right.Prop center is BELOW the CG by about 13 inches. One inch change in prop height according to your spreadsheat makes a change of 2.14 degrees. I cannot buy that. Particularly since it would go from 1.5 down to .64 up. Here is REV A, with a couple math errors fixed: http://www.spiretech.com/~guynoir/sl...thrustreva.xls That looks a lot closer. What is it based on? "Vector Mechanics For Engineers: Statics and Dynamics", by Beer and Johnston, 5th edition, Chapter 4: "Equilibrium of Rigid Bodies", page 126, equation 4.1. Equation 4.1 can be easily found on the internet, just type "statics" into Google and go to the first hit, which should be Wikipedia. All my spreadsheet does is keep the distance from the thrust line to the CG the same with different engine locations, so that the sum of moments about the CG remains the same (as in: Zero. See equation 4.1). -- John Kimmel I think it will be quiet around here now. So long. |
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
Has something changed | [email protected] | Soaring | 10 | May 3rd 05 08:34 PM |
High thrust line on canard design? | Shin Gou | Home Built | 4 | March 5th 05 03:06 AM |
Getting students to line up with the center line | BoDEAN | Piloting | 27 | April 21st 04 11:23 AM |
I want to tell you something that has changed my life! | C J Campbell | Owning | 11 | January 29th 04 11:34 PM |
