#21
It's probably worth trying to use the LXe software to connect. It is
shipped with the Colibri and may be more flexible in the ports it can use. "I used a Belkin adapter with mixed results with the Colibri. One of the things to look at is the port that it gets assigned to. The Belkin would get assigned comm port 3 or 4 and SeeYou would only let you have options of =A00 and 1 so would not recognise the unit. SeeYou would allow more port options. =A0I could hard reassign the ports and make it work." |
On Feb 23, 4:45*pm, Big Wings wrote:
It's probably worth trying to use the LXe software to connect. *It is shipped with the Colibri and may be more flexible in the ports it can use.. "I used a Belkin adapter with mixed results with the Colibri. One of the things to look at is the port that it gets assigned to. The Belkin would get assigned comm port 3 or 4 and SeeYou would only let you have options of =A00 and 1 so would not recognise the unit. SeeYou would allow more port options. =A0I could hard reassign the ports and make it work." I've had the same trouble with my Volkslogger. I got a docking station for my laptop that has a serial port and has worked fine. I do wish I had an adapter that worked. Any suggestions? Dan Rihn WO |
On Feb 23, 10:37*pm, Dan wrote:
On Feb 23, 4:45*pm, Big Wings wrote: It's probably worth trying to use the LXe software to connect. *It is shipped with the Colibri and may be more flexible in the ports it can use. "I used a Belkin adapter with mixed results with the Colibri. One of the things to look at is the port that it gets assigned to. The Belkin would get assigned comm port 3 or 4 and SeeYou would only let you have options of =A00 and 1 so would not recognise the unit. SeeYou would allow more port options. =A0I could hard reassign the ports and make it work." I've had the same trouble with my Volkslogger. *I got a docking station for my laptop that has a serial port and has worked fine. *I do wish I had an adapter that worked. *Any suggestions? Dan Rihn WO I don't own or regularly use any of the electronic instruments, so I can't speak from direct soaring experience, but I use the Keyspan KS-19a with Apple and Wintel laptops for programming microcontrollers (Atmel AVR via STK500 or AVRISP, if anyone's counting). I switched to this unit from a Belkin on the advice of some folks in the DIY electronics community, and I'm very satisfied. I've even made it work with a few Windows apps emulated through WINE on my Macbook. Through WINE, I can just assign it to COM1. Not sure what the situation is like on Windows, but I bet there's some Device Manager trickery to do the same. Ryan Spicer |
Hi Paul, I had trouble with easily-found USB-to-Serial interface
cables from Circuit City and BestBuy, trying to connect from a PC laptop to my Volkslogger (a finicky piece of equipment), using StrePla. One problem was Microsoft ActiveSynch, which does funny things (I'm a techno-bozo and that's as good as the description gets). If I disabled ActiveSynch, things generally went better (and better yet when I was trying to load my IPAQ 3955 with Pocket StrePla, but that's another thread). The best serial adapter I've used is found at http://www.pfranc.com/cgi-bin/P/USB_...min-GPS-cables ; they also make a bunch of different Garmin plugs for cabling. They have worked for me, and several friends. I recommend them - I have no financial interest (I'd like them to be around for a long time). They make 4 inch and 6 foot ones (handy to put laptop on wing if downloading from the glider). On one laptop, I had to re-install drivers (available from the same site at http://www.pfranc.com/usb/usb.shtml#drivers) before it worked. You might want to search on your drivers, and update them - outside chance it'd work. You might want to become a Pfranc too! Dan |
I talked with Larry Berg at Pfranc in October 2008 about buying his
USB to serial converter. Unfortunately, he no longer sells them. He was unhappy because the manufacturer wouldn't support the drivers, and didn't want his name associated with them anymore. He recommended any adapter with the Prolific PC2303 or higher chip set, as long as it had current XP or Vista drivers (he said that the drivers are the primary source of trouble). -John ======= On Feb 24, 12:54 pm, wrote: Hi Paul, I had trouble with easily-found USB-to-Serial interface cables from Circuit City and BestBuy, trying to connect from a PC laptop to my Volkslogger (a finicky piece of equipment), using StrePla. One problem was Microsoft ActiveSynch, which does funny things (I'm a techno-bozo and that's as good as the description gets). If I disabled ActiveSynch, things generally went better (and better yet when I was trying to load my IPAQ 3955 with Pocket StrePla, but that's another thread). The best serial adapter I've used is found athttp://www.pfranc.com/cgi-bin/P/USB_G4/garmin-GPS-cables; they also make a bunch of different Garmin plugs for cabling. They have worked for me, and several friends. I recommend them - I have no financial interest (I'd like them to be around for a long time). They make 4 inch and 6 foot ones (handy to put laptop on wing if downloading from the glider). On one laptop, I had to re-install drivers (available from the same site athttp://www.pfranc.com/usb/usb.shtml#drivers) before it worked. You might want to search on your drivers, and update them - outside chance it'd work. You might want to become a Pfranc too! Dan |
On Feb 24, 11:10*am, jcarlyle wrote:
I talked with Larry Berg at Pfranc in October 2008 about buying his USB to serial converter. Unfortunately, he no longer sells them. He was unhappy because the manufacturer wouldn't support the drivers, and didn't want his name associated with them anymore. He recommended any adapter with the Prolific PC2303 or higher chip set, as long as it had current XP or Vista drivers (he said that the drivers are the primary source of trouble). -John One trick is to install the latest Prolific drivers if your converter is a generic type. I have a generic converter from Best Buy. It works fine with SeeYou and CAI but I could not get LXe to work with it even after installing the latest drivers from the converter manufacturer. I finally determined that it was using the Prolific chip set so I installed the latest drivers from Prolific and the converter began to work properly with LXe. Aren't there any other mac whackers out there besides me? |
On Tue, 24 Feb 2009 10:21:24 -0800, carbonprop wrote:
On Feb 24, 11:10Â*am, jcarlyle wrote: I talked with Larry Berg at Pfranc in October 2008 about buying his USB to serial converter. Unfortunately, he no longer sells them. He was unhappy because the manufacturer wouldn't support the drivers, and didn't want his name associated with them anymore. He recommended any adapter with the Prolific PC2303 or higher chip set, as long as it had current XP or Vista drivers (he said that the drivers are the primary source of trouble). -John One trick is to install the latest Prolific drivers if your converter is a generic type. I have a generic converter from Best Buy. It works fine with SeeYou and CAI but I could not get LXe to work with it even after installing the latest drivers from the converter manufacturer. I finally determined that it was using the Prolific chip set so I installed the latest drivers from Prolific and the converter began to work properly with LXe. Aren't there any other mac whackers out there besides me? I bought a pfranc converter in 2004 because the laptop I had then had a working USB socket but a dead serial port. I needed a serial connection at the time. Since then its worked whenever needed, including for hotsync into an iPAQ 3830. However, I must admit that I use it with Linux where it 'just works', no drivers needed. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
I sell a USB to serial converter with 30 days money back guarantee if it
does not work for you, but only in Continental Europe http://www.trautenberg.net/usb_index.htm nimbus schrieb: My portable PC (VAIO) runs on Vista. I bought a USB-RS232 cable (unknown trademark , manufactured in China), installed the driver ...and was not able to connect the Zander GP941 logger. Anyone with a reference for a cable that is working fine in this configuration? Regards, Bruno |
#29
Some Pfrancs still sell these converters and the driver support by MCT
got back to the old good level. Hans Pfranc of Germany jcarlyle schrieb: I talked with Larry Berg at Pfranc in October 2008 about buying his USB to serial converter. Unfortunately, he no longer sells them. He was unhappy because the manufacturer wouldn't support the drivers, and didn't want his name associated with them anymore. He recommended any adapter with the Prolific PC2303 or higher chip set, as long as it had current XP or Vista drivers (he said that the drivers are the primary source of trouble). -John |
#30
Indeed. I have a Prolific PC2303 USB-232 cable delivered with a
installation CD. The installation CD contains a VISTA driver. After Installation, I can't connect my portable PC to the GP940 logger. I tired to install several other drivers but without success. Hopefully, I still have an old PC running XP with a serial connector. |
USB to Serial Converter | RN | Soaring | 12 | March 16th 08 12:21 AM |
Sell:Brass Male Adapter,Swivel Female Adapter,Flare Adapter,Tee,Connector,Barbed Tee,Elbow,, | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
GTX 327 serial input? | weebee | Owning | 1 | December 19th 05 01:04 AM |
How get get serial number of GNS-430? | Andrew Gideon | Owning | 15 | September 26th 05 11:49 PM |
How get get serial number of GNS-430? | Andrew Gideon | Products | 15 | September 26th 05 11:49 PM |
