USB to RS-232 Serial Adapter Advice
Hi,
I have a friend that has an LX Colibri (the older model without a USB connector) and he is having a tough time getting it connected to his new laptop. The manual I found online for the laptop does not show it having a PC Card (PCMCIA card) slot or an ExpressCard slot. I have had the best luck connecting to soaring instruments using either a PC card serial port or an ExpressCard serial port. I have not had any real success using a USB to RS-232 Serial adapter cable. However, I have seen postings on this newsgroup from glider pilots that have found USB to serial adapters that work well for them. Please let me know if you have found a USB to Serial adapter that works well for you with soaring instruments. Please include the make and model #. Thank you, Paul Remde Cumulus Soaring, Inc. |
We are using a Keyspan USA-19HS USB to Serial adapter with an LX7000
computer to download flights. Haven't had any issues with a variety of different PC's and seems to work with Windows XP and Vista. -Kevin |
I mainly use a Iomega GUC232A adapter, but I also have an EasySync ES-
U-1001-R10. The main difference between the two is that the Iomega uses aProlific PL2303 chip, while the EasySync uses a FT232RQ chip. I've always been able to connect to RS232 devices with either adapter, under both Win98SE and XP Pro. Can't be positive, but I think the keys a 1. follow the instructions and install the driver FIRST before plugging the adapter in, and 2. use Device Manager to change the adapter's Com port to something between Com 1 and Com 4. Hope this helps. -John On Feb 23, 12:55 pm, "Paul Remde" wrote: Please let me know if you have found a USB to Serial adapter that works well for you with soaring instruments. Please include the make and model #. |
On Feb 23, 10:03*am, KevinFinke wrote:
We are using a Keyspan USA-19HS USB to Serial adapter with an LX7000 computer to download flights. Haven't had any issues with a variety of different PC's and seems to work with Windows XP and Vista. -Kevin I use the same adapter to connect to an LX 7000 - no problems. I use SeeYou to connect, rather than the LX software which is kind of klunky. 9B |
Forgot to mention that a USB-Serial adapter will ONLY work if the
program on the PC is written for Windows. A program written for DOS will go straight to the hardware, which doesn't exist when you use a USB-Serial adapter. To get the hardware for DOS programs, you need something like a PCMCIA to serial adapter. -John On Feb 23, 1:16 pm, jcarlyle wrote: I mainly use a Iomega GUC232A adapter, but I also have an EasySync ES- U-1001-R10. The main difference between the two is that the Iomega uses aProlific PL2303 chip, while the EasySync uses a FT232RQ chip. I've always been able to connect to RS232 devices with either adapter, under both Win98SE and XP Pro. Can't be positive, but I think the keys a 1. follow the instructions and install the driver FIRST before plugging the adapter in, and 2. use Device Manager to change the adapter's Com port to something between Com 1 and Com 4. |
Paul,
I don't have make, model & serial numbers with me (I can get those to you later), but all three of the USB-RS232 adapters I've used had one trait in common: the PC would *think* they were working properly, but without the manufacturer's driver installed (go figure). But with the driver(s) installed, they always worked flawlessly. I know one is the aforementioned Keyspan. 2NO |
On Feb 23, 10:35*am, jcarlyle wrote:
Forgot to mention that a USB-Serial adapter will ONLY work if the program on the PC is written for Windows. A program written for DOS will go straight to the hardware, which doesn't exist when you use a USB-Serial adapter. To get the hardware for DOS programs, you need something like a PCMCIA to serial adapter. -John [snip] I could not resist the ONLY in caps. That would be only EXCEPT if you run Windows (or even real MS-DOS) within a VMware virtual machine with the USB-serial adapter running on the host OS. Then the software in the virtual machine won't care and cannot tell there is a USB adapter involved. I use a Keyspan USA-19HS on my MacBook Pro and can connect Windows running in a VMware Fusion virtual machine to this device on the Host OS. Software in the virtual machine will see a standard UART physical interface and cannot tell there is a USB adapter involved so should work fine with MS-DOS or Windows applications. It has worked for the serial apps I've tried to a C302. Virtual is the new physical. Darryl |
I stand corrected! What I was trying to do was to try and prevent
someone not as well versed as you to buy a USB serial adapter, plug it into Windows running as the sole OS, and then wonder why his DOS program wouldn't talk to his SN10. Naturally, there are many ways to skin a cat - especially if you are a computer expert. -John On Feb 23, 1:54 pm, Darryl Ramm wrote: I could not resist the ONLY in caps. That would be only EXCEPT if you run Windows (or even real MS-DOS) within a VMware virtual machine with the USB-serial adapter running on the host OS. Then the software in the virtual machine won't care and cannot tell there is a USB adapter involved. |
On Feb 23, 11:07*am, jcarlyle wrote:
I stand corrected! What I was trying to do was to try and prevent someone not as well versed as you to buy a USB serial adapter, plug it into Windows running as the sole OS, and then wonder why his DOS program wouldn't talk to his SN10. Naturally, there are many ways to skin a cat - especially if you are a computer expert. -John On Feb 23, 1:54 pm, Darryl Ramm wrote: I could not resist the ONLY in caps. That would be only EXCEPT if you run Windows (or even real MS-DOS) within a VMware virtual machine with the USB-serial adapter running on the host OS. Then the software in the virtual machine won't care and cannot tell there is a USB adapter involved. Your advice was great. My expectation is that many users have problems with USB adapters, even with plain Windows apps. And many of those users will give up because dealing with Windows device management is too hard and they did not realize they probably needed to load drivers. In Mac land, the Keyspan is one of the few (only mainstream?) USB adapter that has driver support. It works but has a few bugs (The Keyspan driver can panic OS X if I do unnatural things to the device at very high baud rates, much faster than any flight computer can talk. It has never failed in normal use). I have notes on using this and debugging general serial port things that I keep meaning to finish and post on my blog. Darryl (Who remembers writing MACRO-11 and FORTAN code to talk to DHV11 serial muxes on RT-11. And is now feeling old.) |
On Feb 23, 2:07*pm, jcarlyle wrote:
I stand corrected! What I was trying to do was to try and prevent someone not as well versed as you to buy a USB serial adapter, plug it into Windows running as the sole OS, and then wonder why his DOS program wouldn't talk to his SN10. Naturally, there are many ways to skin a cat - especially if you are a computer expert. -John Warning, further confusion posted above... * ILEC SN10 software includes versions for 32-bit Windows AND 16-bit Windows/DOS. * DOS versions of SN10 and many other programs run great under "simulated" DOS, including: - DOSbox (runs your ILEC software on a Mac with no Windows) - PC emulators that run on PDAs (as above) - etc. For PCs, we recommend Belkin USB-to-serial adapters, as Belkin drivers have fewer bugs, exist for 64-bit windows, etc. Many adapters will only function correctly at certain settings, which *might* be what you need - or not. For Mac, we recommend Keyspan. Many adapters have drivers for only one OS (ie, Windows or Mac), so you have to be a bit careful ! Hope this helps, Best Regards, Dave "YO electric" |
Similar Threads | ||||
USB to Serial Converter | RN | Soaring | 12 | March 16th 08 12:21 AM |
Sell:Brass Male Adapter,Swivel Female Adapter,Flare Adapter,Tee,Connector,Barbed Tee,Elbow,, | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
GTX 327 serial input? | weebee | Owning | 1 | December 19th 05 01:04 AM |
How get get serial number of GNS-430? | Andrew Gideon | Owning | 15 | September 26th 05 11:49 PM |
How get get serial number of GNS-430? | Andrew Gideon | Products | 15 | September 26th 05 11:49 PM |
