Rust removal?
Old February 25th 09, 09:47 PM posted to rec.aviation.soaring
noel.wade
Default Rust removal?
Hi All,
Hopefully a simple quick question:
I pulled my glider out of the trailer after a long winter recently,
and found that I hadn't greased my lift-pins quite well enough. There
are a few small spots of surface corrosion on them, and I'd like to
get rid of it.
BUT, given the importance of the lift pins I don't want to just go
grinding on them. Anyone have any suggestions on the best/least-
destructive way to get rid of minor surface rust/corrosion on parts
like this?
Thanks a bunch,
--Noel
Old February 25th 09, 09:53 PM posted to rec.aviation.soaring
Craig[_2_]
On Feb 25, 12:47*pm, "noel.wade" wrote:
Hi All,
and found that I hadn't greased my lift-pins quite well enough. *There
get rid of it.
grinding on them. *Anyone have any suggestions on the best/least-
like this?
Thanks a bunch,
--Noel
A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good
job of pulling up surface corrosion without significantly influencing
the parent material.
Craig
Old February 25th 09, 10:12 PM posted to rec.aviation.soaring
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Good suggestion. But if that doesn't remove it all, try a fine steel
wool. Start gently, then buff and lubricate when satisfied.
Jeff 7JK
Old February 25th 09, 11:47 PM posted to rec.aviation.soaring
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Jeff * * 7JK- Hide quoted text -
- Show quoted text -
Naval Jelly, then rinse well
Aerodyne
Old February 26th 09, 03:26 AM posted to rec.aviation.soaring
JJ Sinclair
Come on guys, those pins are 10 times stronger than they need to
be..............sand off the rust with 220 or emery cloth and lube
them next time. I keep my pins in two large plastic tubes with lube
inside (duct-taped together) as I remove them they pick up just
enpough lube to shove them home.
JJ
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Aerodyne
Old February 26th 09, 12:48 PM posted to rec.aviation.soaring
JJ
Hey JJ - any reason to be concerned about the tightness of the fit of
the pins in the bushings? I'd think you wouldn't want a shimmy in
flight. Is there any risk of that?
Andy
Old February 26th 09, 03:31 AM posted to rec.aviation.soaring
ZZ
noel.wade wrote:
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Noel
To prevent this in the future try this. Mix some LPS 3 (very waxy) and
white lithium grease into a paste and coat any metal surface that you do
not want to rust. It's very effective, easy to remove in the Spring and
cheap.
Paul
ZZ
Rust in tight places mhorowit Home Built 12 May 19th 09 10:40 PM
Rust prevention: Inside fuselage Michael Horowitz Home Built 10 August 20th 07 11:33 PM
Rust Baver 2 acroman Aviation Photos 0 August 19th 07 05:00 PM
Shaking off the Rust john smith Piloting 22 March 1st 07 01:36 AM
Rust inhibitor? Steve Thomas Home Built 10 August 30th 03 10:34 PM
