On Aug 13, 11:18*pm, rich wrote:
I did some of the body work myself as I built, and when the parts were all done, I took it to a body shop. The guy's painting it complete for $4K. And I'm real happy with that. He's done a great job of doing the finish work, and it's ready for paint now. At first, they sanded right through my wing fillets. But I took some of the cloth out there and showed them how thin it was and from then on they did good work. And one nice thing about composites is they repair easily. I started building the 3 in 1991, afterwards the kids came into my life, plus working full time, but I kept at it. But one thing I did find kind of strange is with the parts all out at the paint shop, I've been so used to being able to walk out to my shop and work on the plane, it's strange having no project to work on. I'm sure once it's flying, going out to the airport and tinkering with it will keep me busy. I know what you mean about the mods, I've done some of those too. Most from the advise of other builders I'd talk to at LAL and OSH. The thing is with a Glasair, the final assembly can't be completed until the thing is painted. Unless it's put together complete, then taken to an aircraft painter. And they all charge $12K to paint a composite plane. Good luck finishing your KIS Cruiser.... You know, when I started the Glasair 3, I thought it would take me 5 years to build. Now 18 years later I see I made a big miscalculation! Rich On Thu, 13 Aug 2009 07:35:50 -0700 (PDT), BobR wrote: Rich, First I would like to congratulate you on finishing your plane. *I am also building a KIS Cruiser and have been working on it for almost 14 calendar years. *I suspect that life has gotten in the way of your completing your project earlier as it has with my project. *The fact that you continued to completion says a lot about you and your dedication to seeing it through. There are several issues that I have repeatedly seen with composite aircraft that I have not seen as frequently with the RV's which seem to be the dominate kit on the market. The first has to do with quality of the supplied molded parts. Because of the low volumes most kit manufacturers have to deal with, they have little incentive to invest in the best quality molds and the refinements needed to make parts that require little additional work prior to assembly. *This means that the builder must spend substantial time in cleanup, fit and finish. *Every composite kit company that I know of still has extensive labor involved and can not automate their processes like Van's has done with much of his fabrication process. The second is builder enhancements (modifications) to the original design. *These changes can be anything from a minor change to some major redesign to the entire airframe. *I have seen hundreds of RV's over the years and few of them make anything beyond cosmetic changes and those that do are usually experience builders on their n'th build. *I know in my own case that I have made dozens of changes, mostly minor, that have cumulatively added several hundred hours to my build time. *If I had exactly followed the original plans...I would have been flying already. There are many more differences but the last that I will hit on is Finish. *That is where almost every time gain a composite builder may have achieved in the construction process is wiped out. *The standards for finishing a composite aircraft are unreal and really totally unnecessary. *With a few notable exceptions the builders of the RV's will complete and fly their planes with no paint or will spend little time and effort beyond having a paint shop spray them. *That's not saying they aren't great looking planes but they don't get anal about a rivet showing or a slight ripple in the wing or fuselage surface. That is expected when working with metal. *The glass builders seem obsessed with producing a finish that has the quality of a fine mirror. *Gawd forbid that the fabric weave should happen to show through. Having said that, I must admit that I have already got a couple hundred hours into the fill and sand process that preceeds the primer and more fill and sand. *I just can't help myself. Finally, there are still a lot of composite kits being built. Lancair, Glassair, Velocity, TeamTango, CompAir, and a host of others come to mind. *They will continue to be a major player in the market but lets also admit that when it comes to great, affordable, and buildable aircraft...Van's Aircraft are the dominate company as of now.- Hide quoted text - - Show quoted text - Yep, when I started my goal was "Oshkosh 2000 by Gosh". Now my goal is simply to finish and I no longer try to project a date. There are just too many things that get in the way. Right now, the project is in a hangar that is an hours drive from my house. I can work on some things at the house but most of the work is at the hangar now and I can only get down there on some weekends. When I started, all the work was done in a nice large garage with my airport less than five minutes away. A job change and relocation put the project in storage for almost five years and financial problems with some family members ment another two years of inactivity. I am limping along now making progress as the money becomes available but it remains a slow process. Enjoy your new plane when you finally get it flying and keep us up on how the flights are going. Bob |
Why GA is Dying | Kyle Boatright | Piloting | 420 | August 1st 06 09:50 PM |
Early Composite homebuilts - was Need help please | [email protected] | Home Built | 12 | January 25th 05 05:24 AM |
Too many soldiers are dying in the "War on terror" !!!! | MLenoch | Military Aviation | 0 | March 26th 04 12:14 PM |
Is this newsgroup dying? | vzlion | Military Aviation | 22 | February 7th 04 04:24 PM |
