Early Composite homebuilts - was Need help please
Old January 20th 05, 04:12 PM
Default Early Composite homebuilts - was Need help please
Gene Sheehan is alive and well
Old January 20th 05, 04:41 PM
jls
In what context?
And what is the earliest powered composite homebuilt aircraft? I'm
thinking it's a Rutan Eze, but maybe there's something older.
Old January 20th 05, 05:48 PM
RST Engineering
I'm guessing VariViggen.
Old January 20th 05, 10:04 PM
Ed Sullivan
On Thu, 20 Jan 2005 09:48:49 -0800, "RST Engineering"
I may be wrong, but I think the original Viggen was wood frame and
plywood. Some of the European powered sailplanes might be first.
Ed Sullivan
Old January 21st 05, 01:39 AM
StellaStar
Jim sez:
Alex, the question is "What do you call a vegetarian who eats no eggs or dairy
and builds small airplanes?" They're kinda thin and pale, but at the sight of
rivets or a whiff of solder flux, their cheeks pink right up...
Old January 21st 05, 02:58 AM
Dave Hyde
Ed Sullivan wrote...
How many Europeans does it take to power a sailplane? g
It wasn't ex-am, but when was the Windecker Eagle
certified? ISTR it was pre-EZ, but I'm not sure.
Dave 'wayback' Hyde
Old January 21st 05, 04:14 AM
Jerry Springer
Ed Sullivan
You are right Ed. I was at Oshkosh the first year Burt flew it there. It
was an impressive airplane in the early 70s.
Jerry
Old January 21st 05, 06:59 AM
On Thu, 20 Jan 2005 11:41:02 -0500, " jls" wrote:
In what context?
As you say, "context". My vote is on the Jupiter J-1. 1959. Won at Rockford
for "Outstanding new design." Several layers of fiberglass were laid-up on a
flat sheet, then glued to a wing as the skin.
The Rand KR1 appeared at Oshkosh in 1972. Like the Jupiter, though, it's
primary structure was wood.
Varieze made its debut in June '75.
Old January 22nd 05, 10:01 AM
First composite sailplanes were Libelle (1964), Phoebus (1964)
First composite homebuilt Vari-Eze (1975 from memory) (ignoring Jupiter and
KR-1 which we really wooden)
First Certificated composite aircraft Windecker Eagle (Circa 1967).
Even composites are not new anymore .... 41 years since the first composite
gliders appeared. Of course the materials have come a long way in this time.
"richard riley" wrote in message
On Fri, 21 Jan 2005 06:59:58 GMT, Ron Wanttaja
:On Thu, 20 Jan 2005 11:41:02 -0500, " jls" wrote:
:In what context?
:And what is the earliest powered composite homebuilt aircraft? I'm
:thinking it's a Rutan Eze, but maybe there's something older.
:As you say, "context". My vote is on the Jupiter J-1. 1959. Won at
Rockford
:for "Outstanding new design." Several layers of fiberglass were laid-up
on a
:flat sheet, then glued to a wing as the skin.
:The Rand KR1 appeared at Oshkosh in 1972. Like the Jupiter, though, it's
:Varieze made its debut in June '75.
The Dyke Delta belongs somewhere in the mix. Steel tube frame,
fiberglass skins. Mid 1960's. Ron Scott's "Old Ironsides" is
similar, but I'm not sure when it rolled out.
Old January 22nd 05, 03:44 PM
Bob Korves
"......... :-))" wrote in message
u...
and
Well, not quite. There was the Glasflugel BS-1, the first production
composite sailplane, first built in 1962
http://www.sailplanedirectory.com/glasflugel.htm
which was preceded by the Akaflieg (technical high school) Stuttgart FS-24
Phoenix, built in 1958 and already having a l/d (glide ratio) of 38:1. This
was truly a composite homebuilt, but not powered as was requested by this
thread. For an overview of composite sailplane design history see
http://www.raeng.org.uk/news/publica...Darlington.pdf
These were beautiful aircraft, not crude in any way, that led the way to the
fantastic sailplanes we have today. In many ways it has been sad to see the
homebuilding movement in this country continue again and again to reinvent
the wheel WRT composite structure when the German sailplane manufacturers
had it pretty well figured out by the mid '60s. Most of those early
Libelles and other composite sailplanes are still flying.
-Bob Korves
Conditional inspections on composite aircraft Sonex655 Home Built 0 December 8th 04 02:11 AM
Marske Composite workshop mat Redsell Home Built 0 October 20th 04 02:06 PM
Composite Construction CD and Resin Infusion Steve G Home Built 1 March 18th 04 08:32 PM
Homebuilts by State Ron Wanttaja Home Built 14 October 15th 03 08:30 PM
Composite Workshop/Flymarket - Marietta, GA Kyle Boatright Home Built 0 September 26th 03 05:29 AM
