gun discharge in cockpit.
Old April 1st 08, 04:01 PM posted to rec.aviation.piloting
Dan[_10_]
Default gun discharge in cockpit.
On Apr 1, 10:48 am, Gig 601Xl Builder
Also, there is no technical reason the 9mm couldn't have been beefed up
to near .45 specs. The .38 Super +P almost does it. The problem was the
legacy 9mm guns out there that couldn't deal with the added pressure and
Sig 229s are P rated.
  #322
Dan[_10_]
On Apr 1, 10:15 am, Dylan Smith wrote:
On 2008-04-01, Dan wrote:
KE is not universally accepted as the measure of bullet effectiveness,
but it is an interesting data point.
Yes, I understand that - what I was alluding to was the original
calculation which was just mass * velocity was pretty much totally
useless in indicating anything in particular, other than mass * velocity
equals some number. To come up with a good definition of 'stopping
power', kinetic energy would make a far better starting point than a
naive calculation of simple mass times velocity.
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
Agreed
  #323
Dan[_10_]
This analysis is flawed. Kinetic energy isn't just mass x velocity.
K = 0.5 mv ^ 2
I thought Kinetic energy = 1/2 x (mass x velocity squared)...?
0.5 is the same as 1/2.
Sorry - mis-read the formula.
  #324
Old April 1st 08, 04:48 PM posted to rec.aviation.piloting
Gig 601Xl Builder
To get to the power level of .45 a 9mm would have had to go up to +++P
or +PPP (however they did that).
There were some people that tried it for a while about 16 or 17years ago
in IPSC and they ended up banning the practice because of some pretty
catastrophic weapons failures.
  #325
Old April 1st 08, 04:54 PM posted to rec.aviation.piloting
Dan[_10_]
On Apr 1, 11:48 am, Gig 601Xl Builder
Again, the "power level" is not an adequate measure of effectiveness.
Sig P229s are rated for +P 9mm ammo.
  #326
Old April 1st 08, 04:56 PM posted to rec.aviation.piloting
Gig 601Xl Builder
Well you keep saying that but then why come out with +P ammo if it isn't
going to help?
  #327
Old April 1st 08, 05:05 PM posted to rec.aviation.piloting
Dan[_10_]
On Apr 1, 11:56 am, Gig 601Xl Builder
going to help?
Because you said that 9mm's can't handle the P charge.
Most of the current crop of quality 9mm's can handle +P, IF that's
something the shooter thinks is important.
I think all this talk about "power factor" ad naseum is blather - only
ONE factor counts in handguns -- shot placement.
Dan Mc
  #328
Old April 1st 08, 05:17 PM posted to rec.aviation.piloting
Dan[_10_]
On Apr 1, 12:10 pm, Nomen Nescio wrote:
For those fractions of a second, you can't beat a big, slow, heavy lump of
lead to screw up someone's plans.
The weight differences between the combat rounds (9mm, .40, and .45)
is about 50 grains.
There's NO handgun that shoots a "heavy lump of lead."
As a friend once told me about an experience in Vietnam, he "shot daylight"
through a NVA soldier with his M-16 and didn't stop him. His CO put the guy
down with one shot from a .45.
These stories have been in circulation since Sam Colt. I suppose the
daylight through the NVA didn't have any effect?
The 9mm v .40 v .45 wars won't be solved here.
Reasonable people should determine the mission profile, asses his/her
own capabilities, level of proficiency, and then choose any one of the
combat calibers and not be "wrong."
Those that claim one is "obviously superior" over the other are
typically Gun Store Commandos, who spend more time drooling over ads
than firing at the range.
Dan Mc
  #329
Old April 1st 08, 05:40 PM posted to rec.aviation.piloting
Gig 601Xl Builder
going to help?
No, what I said was that the 9mm legacy handguns couldn't handle the
pressure needed to be equal to a .45acp. I used the .38 Super +P as a
gun that could use the same size bullet and equal the .45.
And IPSC shooting takes that into account because a shot in the "A"
zones count the same for major and minor ammo.
  #330
Old April 1st 08, 05:52 PM posted to rec.aviation.piloting
Gig 601Xl Builder
is about 50 grains.
Well 124 grains of the 9mm compared to the 230 of the .45 is a pretty
significant difference.
And the light weight (62 grains FMJ) of the 5.56 punches right through
and unless it hits something either directly or via the shock
cavity(which is pretty large due to the bullet's speed) it isn't going
to do much immediate damage.
But here is where the power factor comes in again the 5.56 NATO has a
Power factor of around 192,000.
Dan Mc
Static Discharge gman Piloting 12 March 24th 07 07:56 PM
IFR static discharge [email protected] Home Built 0 April 2nd 06 08:06 PM
The Vanishing Honorable Discharge Otis Willie Naval Aviation 0 October 29th 04 02:58 AM
