Help estimating altitude without altimeter?
Old October 26th 09, 03:51 AM posted to rec.aviation.soaring
tstock
Default Help estimating altitude without altimeter?
Hi, as a beginner I am still a little rough at this. I've done 3
successful patterns with no altimeter, but today I failed one
miserably with my instructor. There were two issues which threw me
off. 1) we towed higher than the past attempts, and 2) instead of
entering the pattern at a familiar entry point, he had me circle
directly over the airport which made judging the angle a bit
difficult.
While we did eventually land safely, I failed miserably at setting up
the first pattern (way too high) and was forced to land on the
opposite runway (which left me way too low). A little scary but a
good learning experience... one I do not care to repeat anytime soon.
I know I should be looking for the landing strip to be about 30
degrees below the horizon. But how can I do this when circling
directly over the field looking down at it?
I made a second attempt and moved my circle so that the outermost edge
of the circle was where I would enter the downwind.. I succeeded this
time. Unfortunately we also only towed to 1500' AGL which left me
with a much smaller chance of messing things up... so I can't say I am
completely confident despite the success.
Are there any easy methods for estimating the angle from the horizon?
For example a fist at arms length is 10 degrees, but obviously I can't
hold my first at arms length through the canopy. The method I've
used is to wait until my aim point aligns with the outer most edge of
the air brakes. To measure 45 degrees I look directly over the top of
my shoulder... is there a better method?
Thanks
-tom
Old October 26th 09, 04:30 AM posted to rec.aviation.soaring
Darryl Ramm
On Oct 25, 8:51*pm, tstock wrote:
Hi, as a beginner I am still a little rough at this. *I've done 3
miserably with my instructor. * There were two issues which threw me
off. 1) *we towed higher than the past attempts, and 2) instead of
difficult.
opposite runway (which left me way too low). *A little scary but a
degrees below the horizon. *But how can I do this when circling
time. *Unfortunately we also only towed to 1500' AGL which left me
hold my first at arms length through the canopy. * The method I've
the air brakes. *To measure 45 degrees I look directly over the top of
my shoulder... *is there a better method?
Thanks
-tom
But but but...
You were flying with an instructor. Was this not addressed to your
satisfaction in the post-flight debrief? Its fresh in your mind then
and that's the time to get answers. Sorry but I cringe at these "where
was the instructor" questions on r.a.s.
If you are circling overhead you can use sized of common things (cars,
gliders, runway width (if known), runway markings, etc.) to judge
height. I think I saw some good slides on that once that Cindy
Brickner had.
But...You don't transition from just circling overhead to rolling out
on the runway. At some time you transition from that circle overhead
to picking up an the downwind or base or whatever leg and a relatively
steady state angle to the runway. Even if the whole approach is curved
your sight picture needs to transition from looking down to across at
that 30-45 degree picture. At that point if you look too high you
should be doing something about it, extend the leg, get on the
spoilers, slip, or all the above.
So you have at least two things to go over with the instructor.
Judging height from overhead and being on-top of altitude correction
in the pattern.
Darryl
Old October 26th 09, 05:00 AM posted to rec.aviation.soaring
Darryl Ramm
difficult.
Thanks
-tom
But but but...
Brickner had.
in the pattern.
Darryl
BTW you can't use the horizon. It is hard to know where the true
horizon often is. What if you are in mountainous areas. In smoke or
haze etc. (which will cause enough problems with depth/distance
perception as is). Same reason you don't want to set up behind the tow
plane based on where the horizon looks. Even if you knew the location
of the true horizon you would not be able to estimate your altitude
from that to anything like a useful accuracy.
Darryl
Old October 26th 09, 06:38 AM posted to rec.aviation.soaring
Andy[_10_]
difficult.
Thanks
-tom
But but but...
Brickner had.
in the pattern.
Darryl
Darryl
I agree with Darryl - angle below the horizon only tells you the angle
to the runway, not your height. You can be at the right height 2,000
feet laterally from the runway or 3x the right height a nautical mile
from the runway and the angles will be the same. You really need to
judge height by looking at the angle between two points a known
distance apart on the ground. This can be the wingspan of an airplane,
the distance between phone poles the width or length of a runway,
circular crop fields - whatever works. Try guessing your height 20
times over the course of a flight - especially when you are between
1,000 and 2,500 feet AGL. You will build a pretty good sense faster
than you think.
9B
Old October 26th 09, 09:04 AM posted to rec.aviation.soaring
John Smith
The vertical angle is all you need to know. Gliders tend to glide at an
angle.
Old October 27th 09, 02:13 PM posted to rec.aviation.soaring
Andy[_10_]
angle.
It helps when you are in the pattern, but the issue here is what to do
when you are away from the pattern. Also, I wouldn't necessarily
recommend that a student focus solely on the angle. I would not
consider it equally good piloting to enter the pattern at 3,000' AGL a
mile abeam of the runway as at 1,000' 1/3 mile abeam of the runway.
For the circling over the airport problem you can get some indication
of altitude by looking at the path the wingtip traces on the ground
from a known bank angle. Above a certain height the path will be
counter to the turning direction, below that height it will be in the
same direction. Do the math to convince yourself. (Note: This is one
cue that creates problems as it tends to make skidding turns down low
seem "normal". A pilot will over-rudder to make the wingtip move
backward -- don't do this). You also get altitude cues from the rate
that objects on the ground change angle in straight ahead flight at a
known airspeed. The least precise cue except at very low altitudes (or
for very big objects) is the included angle from one end of a ground
object to another. Use the length of the ramp, not the length of a
car.
Another big issue is gaining the experience to know when you need to
"head for home" from 10-20 miles away to hit a point that's 1,000' AGL
for pattern entry. The angle for most gliders is very flat but looks
flatter and flatter the farther away you get because the glide
terminates well above the ground. For instance, if your glider can go
7 miles for every 1,000' (L/D= 37) the angle will "look" roughly half
as steep from 20 miles as from 5 miles away. Fortunately this builds
in some conservatism in the pilot's judgement rather than the other
way around.
Try some of these techniques from different altitudes the next few
times you fly. Eventually it becomes (almost) second nature. Also read
Tom Knauff's fine text or one of the many others on the subject. They
are written by professionals.
9B
Old October 26th 09, 12:06 PM posted to rec.aviation.soaring
Tom[_9_]
You will find this information in the book, "Glider Basics From First
Flight To Solo," available at most gliderports or
www.eglider.org
Tom
Old October 26th 09, 12:40 PM posted to rec.aviation.soaring
tstock
Since using the horizon is not reliable, I suppose placing the airport
a certain position above my shoulder could be a good technique to
estimate the angle. My shoulder will always be in the same place
unless my head has been removed.
Old October 26th 09, 01:48 PM posted to rec.aviation.soaring
bildan
estimate the angle. *My shoulder will always be in the same place
I play a game with my students called "Guess our height" With the
student's altimeter covered, I ask them to guess our altitude and them
I tell them what the back seat altimeter says. (Of course, you must
HAVE a back seat altimeter.)
The first few guesses may be wildly wrong but they get better fast. A
few dozen repeats and they're pretty accurate. I'd never ask a
student to fly a no-altimeter pattern and landing until they were at
least passable in estimating altitude.
Bill D
Old October 27th 09, 04:32 AM posted to rec.aviation.soaring
Eric Greenwell
My strategy was to let the students decide when to end the lesson and
head back to the airport. I'd just keep telling them to do stuff, or
showing them stuff, until they said "we're going back", then I'd shut up
and let them do it.
Since we flew off two different runways in varying conditions, they had
a lot practice returning from different directions and altitudes. After
each landing, we'd discuss how it went, and alternate choices. I never
asked them to estimate altitude, and I'm not any good at it anyway. The
standard was to arrive on downwind with enough altitude to do a typical
pattern. Too high or too low might mean a longer discussion, if I
thought there was a problem and not just the normal variation.
They all were good enough at it by the time they went solo, it was never
an issue. By doing it every flight, as soon as they could guide the
glider in more or less in the intended direction, it wasn't anything
that had to be taught later, or something they feared; after all, they
did it every flight except the first 3 or 4. I think it's something you
really have to *do* to learn, and watching someone else make the
decisions isn't useful.
I should point out that, in addition to "as soon as they could guide the
glider in more or less in the intended direction", they'd also received
instruction on the ground and during the first few flights on basic
pattern planning: pick the stop point, pick the aim point, pick the base
direction, pick the downwind entry.
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
GPS altitude vs altimeter altitude Chris W Piloting 37 April 19th 06 10:45 AM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
