New Vent!
Old December 7th 10, 02:37 AM posted to rec.aviation.soaring
sisu1a
Default New Vent!
http://tinyurl.com/337bok7 ...I'm sure it works like a champ. Nice
work John/Hank/Dick!
Old December 7th 10, 02:56 PM posted to rec.aviation.soaring
Andy[_1_]
Default New Vent!
On Dec 6, 7:37*pm, sisu1a wrote:
http://tinyurl.com/337bok7* *...I'm sure it works like a champ. *Nice
Looks nice but where do I put all the stuff that now sits in the over-
spar storage area? I don't think I want to discard my landout kit so
I can fit a vent system that has an unknown (to me) performance
advantage.
For me to be interested in a kit for the ASW-28 it would have to
extend the storage area aft so that, with the vent kit installed, at
least the same storage volume was still available, preferably more.
There is lots of room to extend backwards as is done in the 27's.
Unlike shorter pilots there in no room behind my seat and everything I
carry has to go just forward of, or over the spar.
Where can I find a picture of the installation looking aft into the
spar area?
Andy
Old December 7th 10, 03:46 PM posted to rec.aviation.soaring
Mike the Strike
Default New Vent!
http://tinyurl.com/337bok7**...I'm sure it works like a champ. *Nice
spar storage area? *I don't think I want to discard my landout kit so
advantage.
spar area?
Andy
An interesting gadget. However, wouldn't it be more logical to vent
nearer the rear of the fuselage, say in the lower tail?
Old December 7th 10, 04:24 PM posted to rec.aviation.soaring
sisu1a
Default New Vent!
An interesting gadget. *However, wouldn't it be more logical to vent
Absolutely not... and this one of the major contributing factors to
why most glider's vent do not work. That's where designers have been
sticking them ever since Wil Shuman put one on his Libelle.
-Paul
Old December 7th 10, 04:40 PM posted to rec.aviation.soaring
jcarlyle
Default New Vent!
Paul,
The non-technical write-up at DG on the Mandl air extractor
experiments backs up your position ( http://www.dg-flugzeugbau.de/mandl-absaugung-e.html
). But graph 7a in Prof. Boermans' paper ( http://frotor.fs.cvut.cz/doc/37.pdf
) suggests that the tail position is on a par with the pressure in
back of the wing.
-John
-Paul
Old December 7th 10, 04:52 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default New Vent!
Isn't there a lot of drag in a long, narrow tail boom that will restrict
the amount of air flowing to the tail? Also, how big of an exhaust
outlet can you put back there?
Also, I don't think the Boersmans graph shows pressure on the top of the
fuselage, where these outlets are located.
On 12/7/2010 8:40 AM, jcarlyle wrote:
Paul,
back of the wing.
-John
-Paul
Old December 7th 10, 05:45 PM posted to rec.aviation.soaring
sisu1a
Default New Vent!
experiments backs up your position (http://www.dg-flugzeugbau.de/mandl-absaugung-e.html
). But graph 7a in Prof. Boermans' paper (http://frotor.fs.cvut.cz/doc/37.pdf
back of the wing.
Well I wish he would have told my glider that news, cause it
apparently didn't get the memo My tail vent does not work -at all.
Like most gliders with tail vents... My forward located vent does,
like a champ. It also works on other gliders, and the difference is
not subtle.
Even if the pressures were equal, the forward spot still wins by a
long shot since the air doesn't have to travel such a long distance,
past obstacles, down a tapering duct (ducting adds significant static
resistance, a tapered one even more so, and bulkheads with holes in
them are dealbreakers...), and out an orifice that even if coupled to
the same differential pressure is not a shape that is as conducive to
generating low pressure (not efficiently anyhow...).
The low pressures being generated by these shapes are small. The
penalties of inefficient routing like the same old standard tail
configuration adds however are not. But as I understand it, the
pressure at the tail is kinda on a ship by ship basis. Some ships even
suck water up the tailpipe when blowing ballast, which is a pretty
good indicator of a poor choice for a 'low pressure' location. Also,
whenever I've looked at color coded pressure distribution charts I've
never seen it as hot at the base of the rudder as it is on the dorsal.
When I look at the Beorman graph however, I see a spike in pressure at
the tailvent location, up to +.175 or so... the numbers on the left
get smaller moving up... There *is an unexpected low pressure knee
back there, but it is well before the end of the tail where vents
would be and the same ducting/obstacle penalties still apply.
-Paul
Old December 7th 10, 07:16 PM posted to rec.aviation.soaring
Default New Vent!
advantage.
spar area?
Andy
Mike- Hide quoted text -
- Show quoted text -
I have an exit vent in the lower aft area of the fuselage of both my
'27 and '28. With all the other stuff done sealing rudder hinge,
elevator drive, horn splitters, etc, it improved negative pressure and
flow and resulted in less noise. This vent is a huge ass ache to put
in with the associated nozzle, has significant structural implications
requiring reinforcement, and simply, is not for the faint hearted.
The new vent on top is in a low pressure area which helps a lot with
getting flow and reduced cockpit pressure. It also takes an hour and a
half to install instead of about 10 hr. It's structural implications
are minimal. It slightly reduces available baggage storage in the top
center 4 inches.
Both my gliders will have rear vents closed this winter and '28 will
get top vent.
FWIW
UH
Old December 7th 10, 08:47 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default New Vent!
Do you blokes suffer from major flatulence problems? Seems a lot of effort
to remove air from the cockpit but I could understand if the air was
contaminated in some way :-)
At 19:16 07 December 2010, wrote:
On Dec 7, 10:46=A0am, Mike the Strike wrote:
On Dec 7, 7:56=A0am, Andy wrote:
On Dec 6, 7:37=A0pm, sisu1a wrote:
http://tinyurl.com/337bok7=A0=A0...I'm sure it works like a champ.
=A0=
Nice
over-
spar storage area? =A0I don't think I want to discard my landout
kit
so
advantage.
I
spar area?
Andy
An interesting gadget. =A0However, wouldn't it be more logical to
vent
center 4 inches.
get top vent.
FWIW
UH
Old December 8th 10, 04:34 PM posted to rec.aviation.soaring
Mike Ash
Default New Vent!
Around here (northern Virginia) there's a month or two of summer where I
spend pretty much the entire flight with my hand stuck outside to get as
much air in as possible to try to stay cool. On one miserably hot day
this past July I had to cut a flight short as I began to seriously
overheat despite all my best efforts. I have one of Paul's extractors on
order and I'm hoping it'll make next summer much more pleasant.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Quiet Vent Ron (RW) Soaring 26 June 30th 18 04:31 PM
JS-1 Exhaust Vent sisu1a Soaring 16 July 27th 10 03:32 AM
Quiet Vent Ramy Soaring 6 October 27th 06 05:27 AM
337 for vent covers? Robert M. Gary Owning 14 November 12th 05 05:31 PM
Eye Ball Vent B. Iten Soaring 4 September 4th 04 09:38 AM
